RUG/Pennsylvania/State College/Printers/PSU Unit Gold
Revision as of 19:01, 24 April 2014 by Tmt5147 (talk | contribs) (Log)
Gold
Color: Gold
Extruder: .35mm
Temperature: 200C
Slicer Settings
Here are the Slicer settings of April 15, 2014: File:Gold config.zip
This page contains information about the PSU Unit Gold 3D printer.
Current Team
Lee Schwartz, Tony Armlin, Todd Troutman, Yuan Chai, Graham Deever
Log
Date Modification / Problem
12/06/2013 The printer's extruder had a meltdown. Ian replaced it and it appears to be working well.
09/04/2013 The printer needs an extruder
09/10/2013 Extruder frame mostly assembled, end stops obtained and attached to mounts, arduino w/ driver obtained.
Next steps: Print large extruder gear, assemble and attach extruder, attach and wire endstops, attach and wire arduino. Also note: We need to add a bearing to the extruder and switch the carriage sides.
02/17/2014 The three brown wires linked PCB and nozzle caused some short circuit so that the PCB was overheat and COM port couldn't recognize it.
Solution: haven't fundamentally solve the problem, just shaking the wire so that it no longer short circuit. Other problem: the nozzle could correctly arrive the position of the main printing part, but sometimes it misses the supporting material's position (it means the same layer the part I want to print is perfect but just the supporting material could not put on the layer below it but put on the aside.) So I think the reason why it happened was related to the programming, the subroutine of motors working for support material may have some wrong calculations.
Edit:It was found that the screw below the pcb was shorting it out. A piece of tape was used to solve the problem.
04/08/2014 The x-axis of the printer has been rebuilt and is printing well again but it is still having trouble printing exact circles. Further calibration is being done on the x-axis and y-axis currently in order to fix these small discrepancies.
04/15/2014 The nichrome wire that heats the extruder tip came off again but has been reapplied to the tip and is heating again.
Operating Specifications
Design Ohm
Electronics RAMPS 1.4
Firmware Marlin
Extruder 0.35mm
Extruder Temperature 200 degrees Celsius
Gallery
Modifications & Upgrades
