RUG/Pennsylvania/State College/Printers/PSU Unit Gold
Slicer Settings
Here are the Slicer settings of April 15, 2014: File:Gold config.zip
This page contains information about the PSU Unit Gold 3D printer.
Current Team
Lee Schwartz, Tony Armlin, Todd Troutman, Yuan Chai, Graham Deever
Log
Date | Modification / Problem |
12/06/2013 | The printer's extruder had a meltdown. Ian replaced it and it appears to be working well. |
09/04/2013 | The printer needs an extruder |
09/10/2013 | Extruder frame mostly assembled, end stops obtained and attached to mounts, arduino w/ driver obtained.
Next steps: Print large extruder gear, assemble and attach extruder, attach and wire endstops, attach and wire arduino. Also note: We need to add a bearing to the extruder and switch the carriage sides. |
02/17/2014 | The three brown wires linked PCB and nozzle caused some short circuit so that the PCB was overheat and COM port couldn't recognize it.
Solution: haven't fundamentally solve the problem, just shaking the wire so that it no longer short circuit. Other problem: the nozzle could correctly arrive the position of the main printing part, but sometimes it misses the supporting material's position (it means the same layer the part I want to print is perfect but just the supporting material could not put on the layer below it but put on the aside.) So I think the reason why it happened was related to the programming, the subroutine of motors working for support material may have some wrong calculations. |
04/08/2014 | The x-axis of the printer has been rebuilt and is printing well again but it is still having trouble printing exact circles. Further calibration is being done on the x-axis and y-axis currently in order to fix these small discrepancies. |
04/15/2014 | The nichrome wire that heats the extruder tip came off again but has been reapplied to the tip and is heating again. |
Operating Specifications
Design | Ohm |
Electronics | RAMPS 1.4 |
Firmware | Marlin |
Extruder | 0.35mm |
Extruder Temperature | 200 degrees Celsius |
Gallery
Modifications & Upgrades
- Quick-leveling Bed Thumbwheels
- Maximized Print Bed
- Spool Holder
