RUG/Pennsylvania/State College/Base Plate
Revision as of 18:59, 20 April 2013 by Eky5006 (talk | contribs) (Machining Extruder Base Plate)
Milling Machine
Although our end goal in the RepRap world is to have everything printed, there are still some things that have to be machined. This page will walk you through the base plate machining process step by step. If you are a professional when it comes to machining, then you can just download the base plate specifications at the end of this article.
Before running any of the machines in the lab make sure you are following all the safety procedures. If you are unsure about anything or have questions, be sure to ask for help.
For machining the base plate you will be using a vertical milling machine.
We will be using a machine vice to hold the part so mount one to the table(5) if need be.
Plate Dimensions
Procedure:
1. Clamp the part in the vice using parallel shims to bring the part to the top of the vice.
2. You will need to turn your aluminum stock down making at least two opposite sides parallel. You can use a 2-flute bit or a fly-cutter to do this. Milling all 6 sides will give it a nice look, but is unnecessary.
3. Drill set holes in the appropriate places using the dimensions on this page. Note the middle hole is offset from the other two.
4. Drill holes using drill bit. (The two outer holes may be bigger if needed)
5. Tap the middle hole using a 5/16 24 Threads per inch tap. I found drill H works the best.
6. Add a slot for wire if want/needed.
Additional Notes:
The Learning Factory on campus has excellent milling machines with digital displays for dimensioning. If you aren't already trained, you can sign up at the Learning Factory to learn how to use their equipment.
When machining the plate, all the dimensions have a high tolerance. This means that the measurements don't have to be perfect except for the three drill holes. You must make sure all the drill holes are all separated by the exact amount according to their x and y axis. A picture of the before and after base plates can be seen below.
The plate on the right has been sandblasted to give it a mat finished look which is optional (if you do chose to sandblast the plate, make sure you re tap the tapped hole).
When using any drill bits or taps, make sure they are the correct sizes by either looking on the tap or measuring the drill bit diameter with calipers. People don't always put things back where they belong.
If you have access to a water jetting machine, this process can be made much faster. The Learning Factory has a water jetting machine, but keep in mind they charge for their water jetting service.
Before and After
SolidWorks Drawing File
File:Extruder Plate.SLDDRW
