RP alternatives
Many alternative parts exist to replace to the standard RP parts published in the wiki for each reprap platform. Users must be aware that simply because a part may be listed as an 'alternative,' it does not imply that the the part may be a full drop in replacement. Please use discretion if you are formulating a BOM for a new tool build!
Idea for this page (will remove later): If available, list the Pro's and Con's of the alternative piece.
Mendel
Prusa
Description | Links to alternative | Image of original |
coupling | Greg's 3 jaw coupling: http://www.thingiverse.com/thing:8675 Nophead's Z Coupling: http://www.thingiverse.com/thing:9622 |
endstop-holder | RP | ![]() |
x-carriage | RP | ![]() |
x-end-idler | RP | ![]() |
x-end-motor | RP | ![]() |
y-motor-bracket | Clip on prusa Y bracket: http://www.thingiverse.com/thing:10823 Prusa Y Motor Mount EZ: http://www.thingiverse.com/thing:13393 |
z-motor-mount | Integrated Z Motor Mount: http://www.thingiverse.com/thing:11838 | ![]() |
belt-clamp | Y Axis Belt Tensioner: http://www.thingiverse.com/thing:10274 | ![]() |
bar-clamp | 2-way Prusa Bar Clamp: http://www.thingiverse.com/thing:5786 | ![]() |
rod-clamp | RP | ![]() |
pulley | RP | ![]() |
frame-vertex with foot | MV6: http://www.thingiverse.com/thing:4773 Vik's Vertex: http://www.thingiverse.com/thing:2003 Triffid's Vertex: http://www.thingiverse.com/thing:12313 |
frame-vertex | MV6: http://www.thingiverse.com/thing:4773 Low Warp/Shelled: http://www.thingiverse.com/thing:2413 |
pla-bushing | RP-PLA | ![]() |
