RBS
Revision as of 23:49, 10 November 2009 by Sebastien Bailard (talk | contribs) (Entrepreneur-based research)
Action Items
  • Ask Forrest to make 2 gears which mesh, and are both bolted to a perforated sheet of metal.
  • Ask Forest to make up a set of pdf or SVG files I can use to make gears.
  • Find a friendly laser cutter. I favor South End Boston Fab Lab because they can follow along.
  • Make several hundred gears of all sizes.
  • Make a 500 feet of plastic gridbeam using the CNC router at architecture.
  • I want to move to an open source design system. I think blender is best because it is the open source modeling program with the most users and the biggest community.
  • Prepare a proposal for the BRL-CAD people to design a gear-cad module for blender.
    • First, see what has been done with blender.
  • Eventually, may want benchtop jewelry-scale sheet bend and brake, to make my own RBS parts.
Motivation
  • Merkur based apparatus for centrifugal casting of contact lenses by wichterle.jpg
  • TriLap is an idea for making a RepRap using RBS for the parts.
RepRap Building System
This is a cross between grid-beam and old-fasioned erector_set, but we will make RepRaps and TriLaps from it.
The 'RepRap Building System', aka 'RBS', aka 'Building System' is made from grid-beam type perforated beams, store-bought fasteners, and RepRap-printed parts like gears and fittings to hold stepper motors and smooth rods.
For more information, see TriLap.
RBS is a key element in the Education RepRap Education Initiative.
  • TriLap will be a steel square-tube CNC router made with tri-lapping joints, aka Tri-Joints with Image:NEED-trijoint example.jpg Note that this is slightly similar to LumenLab's RogR, but will be cross-fertile with RepRap.
We can if we want try to extend this use of gridbeam and erector-set like technology into a TriLap/Building_System system that levrages RepRap to make lots of mechatronic systems using grid beam and grid sheet, and 3D printed gears, etc., but that's sort of beyond the scope of this project. (Step 2, technically)
Development outline
  1. Make gears and beam to illustrate core concept.
  2. Sketch out a TriLap in gear and beam.
  3. Blog.
  4. Solicit domain experts for toy and model building systems. This means sending polite emails to Erector Set, Meccano, and Model Engineering geeks requesting critique. After further development, we will solicit user testing, i.e. 3rd graders.
If it is any good, we will have to make kits to test the ideas. This process will mean donating to 3rd graders. We have SETC fab lab do this; they are set up for it.
Documentaion
The primary documentation for RBS will be this wiki. Please share your ideas on thingiverse, google sketchup, and so on, but please first upload and share on this wiki. Thank you.
GPL.
