RAMPS-FD
Revision as of 15:34, 21 January 2013 by Bobc (talk | contribs) (Created page with '= RAMPS for Arduino Due = [http://arduino.cc/en/Main/ArduinoBoardDue Arduino Due]is the new Arduino board that is using an ARM Cortex M3 CPU. The Atmel SAM3X8E chip used on the…')
Arduino Dueis the new Arduino board that is using an ARM Cortex M3 CPU.
The Atmel SAM3X8E chip used on the Due operates at 3.3V and is not compatible with 5V. Therefore the RAMPS shield will not work with Due, and worse applying 5V to the Due's inputs will likely damage the chip.
Therefore it is proposed to create a new RAMPS variant which is compatible with the Due.
Significant differences between Arduino Mega and Arduino Due
  • CPU operates at 3.3V
  • High-current IO pins are capable of 15 mA source, 9 mA sink
  • Low-current IO pins capable of 3 mA source, 6 mA sink
  • CPU package has an absolute max of 130mA
Hardware changes required from RAMPS 1.4
  • MOSFETs need to be compatible with threshold voltage of 3.3V or better have a gate driver which allows any MOSFET to be used
  • Expansion pins need to be level-translated, but this depends on how they are used
Hardware features known to be compatible
  • The Allegro stepper drivers will run with VDD = 3.3V and the logic signals compatible with 3.3V. This should apply to all the Pololu style drivers.
  • Servos "should" be able to operate with +5V power and a PWM signal of 3.3V
  • Thermistors will operate at 3.3V but the Analog Ref is also 3.3V, so no changes should be necessary
Firmware changes
  • Firmware needs to be recompiled with ARM compiler (gcc)
  • Arduino libraries may be compatible
  • Any references to AVR CPU peripherals need to be ported
