Prusa Mendel thereprapkitstore
Revision as of 03:29, 22 May 2012 by Roland (talk | contribs)
This page is about the Prusa Mendel version sold by thereprapkitstore.co.uk.
Assembly Instructions
The following steps refer to Prusa Mendel Assembly.
High resolution photos are published on the seller's page.
construction is discussed in the RepRap Forum
Instead of ordinary Washers, M8 Lock Washers are used.
Tightening the Frame
The outside frame jiging length is 290mm just like like in the wiki. But this build would allow a wider inside jiging length of up to 270mm whereas in the wiki, only 234mm are used. Maybe this build will allow a wider build volume. However, your print bottom plate is only 220mm wide, whereas the wiki-thing is 225mm wide.
people having such a Mendel
roland: forum - homepage: www.reprop.org - speaking: german, english - location: Germany --Roland 07:09, 22 May 2012 (UTC)
