Profabb gate
Revision as of 06:21, 3 November 2013 by Profabb gate (talk | contribs) (Created page with "PROFABB GATE LE - DIY stable frame build with aluminium extrusions 40x20 buildig volume 190x200x220 designed for 1.75 mm filament (ABS, PLA and other up to 255 C. degree) eas...")
stable frame build with aluminium extrusions 40x20 buildig volume 190x200x220 designed for 1.75 mm filament (ABS, PLA and other up to 255 C. degree) easy removable extruder cable guides with easy mount 0.5Nm all steppers direct drive extruder with MK7 gear 10 and 12mm dia out linears step by step build instruction machnined, aluminium linear rod ends
