Printrbot
Revision as of 23:33, 9 January 2012 by DaveX (talk | contribs) (Specifications)
Printrbot is the smallest, simplest, cheapest, RepRap 3D printer in the world.
UPDATE (11.17.2011)
The Printrbot just launched on kickstarter! Check it out and support, if you are inclined. http://www.kickstarter.com/projects/printrbot/1239090607
Lots of pictures and video available there.... the files are coming soon, so don't you worry! Happy Printing, Brook Drumm
UPDATE (11.09.2011)
Read more here: [1]
UPDATE (11.03.2011)
The "Ubis Hotend" has continued to undergo heavy testing from Printrbot beta testers and CArl, himself. Carl ran an HP failure lab for years before he retired, so this is his strong suit. He is drawing from as many off-the-shelf parts as possible and has made recent improvements, including a longer PTFE tube, brass barrell, brass tip and more.
The Heated Print Bed is milled 6x6 copper clad pcb board. We will eventually have them made, but for small numbers the mill gives an awesome product.
I tightened up the design for the "top end" - trimming out a few extra LM8UUs and settling on a very nice two piece design for the X-Carriage assembly. Any hot end should fit on this machine by designing a mount that will mate to the X-carriage.
Pictures will be coming soon!
UPDATE (10.02.2011)
We have discovered that, while using only 3 motors DOES work, it could bring potential problems for first-time builders. We added the 4th motor to stabilize the Z axis on the right. It adds only slightly to the bulk. It provides the opportunity to drop one printed part design and just use a copy of one of the printed parts from the other side. I had to redesign only one part (the X-Idler) and add a coupler and threaded rod. The good thing about this change is that it not only aligns itself with current convention, it GREATLY eases future expansion for those wishing to expand the printed area.
UPDATE (09.20.2011)
Printrbot is alive and well. We are starting our beta testing program with a few printers in the wild and being tested. Minor changes will follow, I am sure. Then off to a formal announcement and launch.
Project Goal
The overall goal is not to win the Gada Prize - although I would be proud :), rather, the goal is to offer a printer that kids can put together and operate. My dream is to provide every school with a Printrbot... and that every Printrbot will produce offspring that produces offspring (...etc....) until every home has a 3D printer.
Overview
One 3D Printer Per Home is a huge goal. In reality, only some students will even WANT a 3D printer, so that lowers the bar significantly. My short-term goal is to provide Printrbot 3D printers to any school interested-- AT COST, so that the students who want them can use the school Prinrbot to print the parts to make a Printrbot.... just add electronics, stepper motors, smooth and threaded rod. Through our "Print It Forward" program, we will ask each school to print, assemble and donate a Printrbot to 3 other schools. Although everyone is welcome to source their own parts, Printrbot.com will offer a student kit at the lowest possible cost to make this feasible. Printrbot is already at a SUB-$300 cost for all non-printed parts. A "Printrbot jr." is in the works to break the $200 price point for COST for all non-printed parts on the smaller model. By relying on schools and Printrbot owners to print 3 other sets of parts to construct a Printrbot, we hope to spread the RepRap love far and wide!
Project Description
Printrbot is a reality. While I am in a testing phase, this is a real 3D printer that prints TODAY. I have designed this printer myself, only using other people's work for optional items. The non-original parts I use are:
--Greg's Hinged Accessible Extruder by GregFrost (http://www.thingiverse.com/thing:8252)
--one optional Printable Ball Bearing Upgrade by GregFrost (http://www.thingiverse.com/thing:8574)
--two 10t XL Pulleys for SAE Prusa Mendel by BenJackson (http://www.thingiverse.com/thing:7454)
--a set of Herringbone Gears for Gregs Accessible extruder by Sublime (http://www.thingiverse.com/thing:5111)
Three Designs: Printrbot, jr. and Sr. The Printrbot is the original design that has a medium sized printbed. The Printrbot jr. is the ultra-small, ultra-cheap version that pushes the boundaries of size, cost and simplicity for a 3D printer. The Printrbot Sr. (Gada Edition) will be the special version built specifically for the Gada Prize. While I am grateful that the Gada prize is pushing the technology forward, I believe that 3D printers that have lesser specifications (than the Gada Prize rules dictate) will still be greatly useful for families everywhere. SO my first model will be the original "Printrbot" that aims at the sweet-spot between practicality and price. The Printrbot jr. version will be next to lower the barriers to entry for 3D printing at home. Then, finally, the Gada Prize version: Printrbot Sr.
NOTE: according to the official Gada Prize Rules here: http://humanityplus.org/wp-content/uploads/2011/02/HumanityRepRapGrandPersonalManufacturingPrize.pdf - I formally am using the "no derivatives for the Gada Prize” clause. I believe the approach I am using is unique and original to my design.
Specifications
Currently, I have a mechanically complete Printrbot and am working on lowering the part count and making the construction even simpler. The bot is being printed on a Makerbot Cupcake, so the parts are small and any machine can print them.
The part count is EXTREMELY low:
-18 Printed Parts (not including the extruder)
-3 Roller Bearings
-11 Linear Bearings
-1 two inch bolt
-Nuts & Bolts: 60
-Smooth/Threaded Rods: 12
-4 Nema17 motors (Z axis uses 2)
-Sanguinololu Electronics (Initially) and a new version of the Teensylu is planned including 100% surface mount parts and integrated stepper drivers. This will be an assembled board. (Board files at http://github.com/lwalkera/printrboard per http://printrbot.com/home/2012/1/1/the-end-the-beginning.html )
Hot End: Introducing the NEW "Ubis Hotend" - a super-efficient nichrome wire powered hotend. It can at 10 degrees celcius every 5 seconds. This will come assembled in the kit.
-PCB Heated print bed (5.5" x 5.5")
UPDATE: we are seriously looking at going with a bowden extruder.... stay tuned...
Extruder (Wade's Accessible):
-4 Printed Parts
-3 roller bearings
-1 Hobbed Bolt
-1 very short threaded rod
-a few washers, bolts and nuts to mount it
-1 Nema17 motor
Total part count (Sans motors, electronics, hot end): 101 ..... and shrinking.
