Printrboard
Description | Revision B
License | CC ShareAlike 3.0
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | Eagle
External Link |
Introduction
The Printrboard electronic set was designed by members of the Printrbot team in order to eliminate the production and functionality shortcomings of older RepRap electronics sets. Printrboard improves upon the previous production-grade electronics set (Gen6) by adding heatbed and SD card support, reverting to 1/16 microstepping Allegro stepper drivers, and improving connectivity reliability and reducing cost by elimination of the FTDI UART chip. Printrboard also has expansion headers supporting I2C, SPI, UART, and ADC pins. All extra I/O ports of the AT90USB have been broken out to headers for prototyping and expansion.
Printrboard is a derivative of Teensylu, an AT90USB1286 development board originally based on Sanguinololu. The Atmel AT90USB1286 MCU has on-chip USB, removing the need for the FTDI UART (USB-to-serial) IC. On-chip USB means dramatically faster firmware upload times and communication. The AT90USB connects at any baud rate regardless of firmware configuration, and operates virtually free of serial communication errors/pauses.
Features
- Atmel AT90USB1286 Microcontroller (or AT90USB1287 drop-in compatible for 20mhz support)
- -- Native USB interface. No FTDI serial-to-USB chip!
- -- 128kb Flash
- Four integrated Allegro A4982 Stepper Drivers (no Pololus needed)
- Thermistor Connectivity: 2
- 2 N-MOSFETs for Extruder and Heatbed control
- 1 N-MOSFET for low power Fan or motor
- Onboard SD card slot
- Four Endstop connectors supplied @ 5V. Includes X, Y, Z, and fourth endstop called E-Stop to be used as an emergency stop, or extruder stop (to be added in firmware).
- Supports multiple power configurations (Carried from Sanguinololu)
- -- Logic & Motors supplied by ATX or laptop power supply (12-20V 120W minimum)
- -- Logic supplied by USB bus (if enabled by solder jumper)
- -- Logic supplied by on-board voltage regulator
- -- on-board USB connectivity
- Edge connectors enabling right-angle connections
- 14 Extra pins available for expansion and development, with the following capabilities
- -- UART1 (RX and TX)
- -- I2C (SDA and SCL)
- -- SPI (MOSI, MISO, SCK)
- -- PWM pin (1)
- -- Analog I/O (6)
- -- JTAG (uses some of the ADC pins)
- Additional 14 pin header with remaining I/O for prototyping
- SMT Components sized at 0805, and no QFNs for easier soldering.
- 4-Layer PCB with proper ground plane and power distribution networks
- Small design - board is 100mm x 60mm (4" x 2.4")
Benefits of this Design
- Utilizes integrated Allegro 1/16 micro-stepping drivers for smooth operation.
- Integrated USB controller provides 12MBps bandwidth, instead of usual 38400-115200 baud via FTDI. Result: Virtually no serial communication errors (common with Sanguinololu and Generation_6_Electronics).
- Integrated micro-SD Card slot
- Uses small standard Molex connectors for motors, heater, and endstops.
- Lowest cost and greatest performance of all RepRap motherboards at time of release, March 2012.
Software
All preassembled Printrboards come pre-loaded with a bootloader and firmware. You may wish to use alternative (or newer) firmware, modify calibration data for use with another style of RepRap, or perhaps assemble your own board.
To use a Printrboard, you will need to load appropriate USB drivers. These are packaged with Atmel's FLIP software.
Compatible Firmware
- Sprinter Sprinter: Supported, use MOTHERBOARD == 9.
- Marlin Marlin: No official support yet, but works with Lincomatic's fork.
- Repetier List_of_Firmware#Repetier-Firmware: Supported, use MOTHERBOARD == 9.
- grbl List_of_Firmware#Grbl: No official support yet, but works with Lincomatic's fork.
(Other firmwares are currently untested but any firmware for an arduino mega should work with proper pin setup.)
Bootloaders
There is no native Arduino bootloader for the AT90USB series microcontrollers, however, there is excellent opensource support for the MCU and Arduino integration is easily achieved.
- LUFA's CDC Bootloader: Allows direct uploading of firmware through Arduino/avrude via avr109 protocol. Requires free Atmel drivers and Arduino 022 with modified Teensylu boards configuration. Avrdude within Arduino directory must also be upgraded to newest version.
- LUFA's HID Bootloader: No Arduino integration. No drivers required. Allows firmware to be uploaded by command prompt.
- Atmel's DFU Bootloader: Factory installed bootloader. No Arduino integration. Allows firmware to be uploaded by Atmel's free FLIP software (Windows only. See Teensylu#Sprinter for Mac equivalent "dfu-programmer".
Installing A Bootloader
If you wish to change to a different bootloader, you will need a USBtinyISP or equivalent ICSP or JTAG programmer. Note that USBTiny only officially supports MCU's with less <= 64K flash (the AT90USB1286 is a 128K chip!). Writing will work with a USBTiny, but read verification will always fail.
- Obtain a compiled bootloader (CDC, HID, or DFU). See Lincomatic's Bootloaders for AT90USB1286 article for pre-compiled copies of each bootloader.
- Remove the BOOT jumper from the Printrboard. Press the Reset button
- Connect the 6 pin programming cable to the Printrboard's ICSP header. Pin 1 (red wire) is closest to the SD card slot.
- Connect your programmer's USB cable.
- Run the following avrdude commands, where BootloaderNAME_HERE.hex is the name of the Bootloader file you wish to install
avrdude -c usbtiny -p at90usb1286 -U lfuse:w:0xDE:m -U hfuse:w:0x9B:m -U efuse:w:0xF0:m avrdude -c usbtiny -p at90usb1286 -U flash:w:BootloaderNAME_HERE.hex:i
- Replace jumper on the Printrboard. Press Reset again.
WARNING: Triple check the fuse values! Setting incorrect values will brick the microcontroller! Fuse values above are for the CDC and HID bootloaders. Fuses for the factory DFU bootloader should be set as
avrdude -c usbtiny -p at90usb1286 -U lfuse:w:0x5E:m -U hfuse:w:0x99:m -U efuse:w:0xF3:m
Loading Firmware (Windows)
To load new firmware to your Printrboard, first determine which bootloader your board uses. CDC or DFU are most likely.
Unlike older AVR microcontrollers, the AT90USB has a special HWB_ALU pin (Hardware Button) which must be tied to ground during a reset cycle in order to place the microcontroller into bootloader mode. This is accomplished by removing a jumper on the Printrboard called "BOOT". Firmware can only be loaded while the chip has booted into its bootloader:
- Remove the BOOT jumper.
- Press and release the Reset button. The AT90USB's bootloader will appear as a new USB device the first time you boot into the bootloader. Allow Windows to install the USB driver and note the new COM port number.
- Replace the BOOT jumper onto the board.
- Proceed to upload new firmware using the method relevant to your installed bootloader.
- CDC BOOTLOADER (Arduino Bootloader)
- In Arduino 022, open firmware
- Choose [BootloaderCDC]Teensylu/Printrboard from the Arduino Tools-->Board menu, and select the COM port associated with your Printrboard's bootloader. See Lincomatic's How to Program an AT90USB1286/Teensylu/Printrboard with Arduino article for help configuring Arduino.
- Click File --> Upload to Board.
- Arduino will compile and upload firmware. You should see an error a few seconds after the firmware compiles. This is because the AT90USB has successfully exited the bootloader.
- Press Reset. You may need to disconnect and reconnect the USB and power cables.
- HID BOOTLOADER
- Open a command prompt in the directory of the HID application.
- Compile firmware within Arduino. You will need to copy and paste the compiled .HEX file into the HID application directory. The HEX file is saved in the temp folder, C:\users\{currentuser}\appdata\temp\build1234567890\Firmware_Name_Here.cpp.hex
- Run the hid_bootloader_cli application, specifying your firmware and an mmcu of at90usb1286.
- Disconnect and reconnect the USB and power cables.
- DFU BOOTLOADER
- Open Atmel's FLIP software.
- Select the target device: AT90USB1286. Select Communication medium as USB. Click Open.
- Open compiled HEX file within the FLIP software.
- Make sure the Erase, Blank Check, Program, and Verify checkboxes are checked.
- Click the Run button
- When finished, disconnect and reconnect the USB and power cables.
Setup
Stepper Motors
Connect the X, Y, Z axis, and extruder motors to the matching headers at the top of the Printrboard (X-MOT, Y-MOT, Z-MOT, E-MOT). Headers are 4 wire Molex KK series, part# 0022013047) with 2759 series crimp terminals, part# 0008550101. Motor pinout is:
- A
- B
- C
- D
Endstops
Connect mechanical microswitches to the 3-pin Molex headers X-STOP, Y-STOP, Z-STOP at the bottom of the board. E-STOP is reserved for future use. Connect switches as follows:
- Switch NC
- No connection
- Switch COMMON
Heaters
Connect the heating element of your hotend (resistor or nichrome wire) to the 4-pin EXTRUDER header, positioned next to MOSFET Q1. Connect your heatbed to the HOTBED header, next to MOSFET Q2. Polarity here is unimportant; pinout is as follows:
- Positive
- Positive
- Negative
- Negative
Thermistors
Thermistor headers are 2-pin Molex headers at the right side of the board, located above the reset button.
Connect the heatbed thermistor to the header directly above the reset button. The hotend thermistor connects above the heatbed header.
Lower Power Fan
A 2-pin Molex header labelled FAN is located on the right side of the board, above the thermistor headers. This optional header can be used to power a fan or other small motor. Generally not used.
Board Power
All power is supplied through the 4-pin ATX style header at the upper left corner of the Printrboard, labelled PWR. Connect directly to any 12VDC power supply. Ground terminals are closest to the edge of the board (left); 12VDC+ terminals are at right.
USB
Connect a micro-USB cable to the USB jack at the bottom of the PCB. Note that a jumper should be installed on the "BOOT" pins for normal operation (see Printrboard#Bootloaders).
Schematic
EAGLE files for the Printrboard are on Github: [[1]]
Revision History
- RevC [April 2012]: Fixed manufacturability of SMT solder jumpers, MS-X, MS-Y, MS-Z, MS-E. Fixed "printrbot" logo on bottom silkscreen.
- RevB [February 2012]: First release to manufacturing (RTM), built for first batch of Printrbots. Each stepper driver IC utilizes an SMT solder jumper, MS-X, MS-Y, MS-Z, MS-E to set the microstepping ratio. These jumpers are manually soldered in production and will be eliminated in future batches.
Where to get it
- It is sold fully assembled with the Printrbot kits, and from the Printrbot store.
- Also available at RepRap-USA and MakerFarm
