Printcore 3p2.py
Revision as of 11:19, 21 December 2011 by Radoslav (talk | contribs) (Created page with '<code> #!/usr/bin/env python from serial import Serial from threading import Thread import time import sys class printcore(): def __init__(self,port=None,baud=None): …')
  1. !/usr/bin/env python
class printcore():
       """Initializes a printcore instance. Pass the port and baud rate to connect immediately
       self.baud=None
       self.port=None
       self.printer=None #Serial instance connected to the printer, None when disconnected
       self.clear=0 #clear to send, enabled after responses
       self.online=False #The printer has responded to the initial command and is active
       self.printing=False #is a print currently running, true if printing, false if paused
       self.mainqueue=[]
       self.priqueue=[]
       self.queueindex=0
       self.lineno=0
       self.resendfrom=-1
       self.paused=False
       self.sentlines={}
       self.log=[]
       self.sent=[]
       self.tempcb=None#impl (wholeline)
       self.recvcb=None#impl (wholeline)
       self.sendcb=None#impl (wholeline)
       self.errorcb=None#impl (wholeline)
       self.startcb=None#impl ()
       self.endcb=None#impl ()
       self.onlinecb=None#impl ()
       self.loud=False#emit sent and received lines to terminal
       if port is not None and baud is not None:
           #print port, baud
           self.connect(port, baud)
           #print "connected\n"
   def disconnect(self):
       """Disconnects from printer and pauses the print
       if(self.printer):
           self.printer.close()
       self.printer=None
       self.online=False
       self.printing=False
   def connect(self,port=None,baud=None):
       """Set port and baudrate if given, then connect to printer
       if(self.printer):
           self.disconnect()
       if port is not None:
           self.port=port
       if baud is not None:
           self.baud=baud
       if self.port is not None and self.baud is not None:
           self.printer=Serial(self.port,self.baud,timeout=5)
           Thread(target=self._listen).start()
   def reset(self):
       """Reset the printer
       if(self.printer):
           self.printer.setDTR(1)
           self.printer.setDTR(0)
   def _listen(self):
       """This function acts on messages from the firmware
       self.clear=True
       time.sleep(0.5)
       self.send_now("M105")
       while(True):
           if(not self.printer or not self.printer.isOpen):
               break
           line=self.printer.readline()
           if(len(line)>1):
               self.log+=[line]
               if self.recvcb is not None:
                   try:
                       self.recvcb(line)
                   except:
                       pass
               if self.loud:
                   print(bytes("RECV: ","ascii")),line.rstrip()
           if(line.startswith(bytes('DEBUG_',"ascii"))):
               continue
           if(line.startswith(bytes('start',"ascii")) or line.startswith(bytes('ok',"ascii"))):
               self.clear=True
           if(line.startswith(bytes('start',"ascii")) or line.startswith(bytes('ok',"ascii")) or bytes("T:","ascii") in line):
               if (not self.online or line.startswith(bytes('start',"ascii"))) and self.onlinecb is not None:
                   try:
                       self.onlinecb()
                   except:
                       pass
               self.online=True
               if(line.startswith(bytes('ok',"ascii"))):
                   #self.resendfrom=-1
                   #put temp handling here
                   if bytes("T:","ascii") in line and self.tempcb is not None:
                       try:
                           self.tempcb(line)
                       except:
                           pass
                   #callback for temp, status, whatever
           elif(line.startswith(bytes('Error',"ascii"))):
               if self.errorcb is not None:
                   try:
                       self.errorcb(line)
                   except:
                       pass
               #callback for errors
               pass
           if bytes("resend","ascii") in line.lower() or bytes("rs","ascii") in line:
               try:
                   toresend=int(line.replace("N:"," ").replace("N"," ").replace(":"," ").split()[-1])
               except:
                   if "rs" in line:
                       toresend=int(line.split()[1])
               self.resendfrom=toresend
               self.clear=True
       self.clear=True
       #callback for disconnect
   def _checksum(self,command):
       return reduce(lambda x,y:x^y, map(ord,command))
   def startprint(self,data):
       """Start a print, data is an array of gcode commands.
       returns True on success, False if already printing.
       The print queue will be replaced with the contents of the data array, the next line will be set to 0 and the firmware notified.
       Printing will then start in a parallel thread.
       if(self.printing or not self.online or not self.printer):
           return False
       self.printing=True
       self.mainqueue=[]+data
       self.lineno=0
       self.queueindex=0
       self.resendfrom=-1
       self._send("M110",-1, True)
       if len(data)==0:
           return True
       self.clear=False
       Thread(target=self._print).start()
       return True
   def pause(self):
       """Pauses the print, saving the current position.
       self.paused=True
       self.printing=False
       time.sleep(1)
   def resume(self):
       """Resumes a paused print.
       self.paused=False
       self.printing=True
   def send(self,command):
       """Adds a command to the checksummed main command queue if printing, or sends the command immediately if not printing
       if(self.printing):
           self.mainqueue+=[command]
       else:
           while not self.clear:
               time.sleep(0.001)
           self._send(command,self.lineno,True)
           self.lineno+=1
   def send_now(self,command):
       """Sends a command to the printer ahead of the command queue, without a checksum
       if(self.printing):
           self.priqueue+=[command]
       else:
               time.sleep(0.001)
           self._send(command)
       #callback for command sent
   def _print(self):
       #callback for printing started
       if self.startcb is not None:
           try:
               self.startcb()
           except:
               pass
       while(self.printing and self.printer and self.online):
           self._sendnext()
       if self.endcb is not None:
           try:
               self.endcb()
           except:
               pass
       #callback for printing done
   def _sendnext(self):
       if(not self.printer):
           return
           time.sleep(0.001)
       self.clear=False
       if not (self.printing and self.printer and self.online):
           self.clear=True
           return
       if(self.resendfrom<self.lineno and self.resendfrom>-1):
           self._send(self.sentlines[self.resendfrom],self.resendfrom,False)
           self.resendfrom+=1
           return
       self.resendfrom=-1
       for i in self.priqueue[:]:
           self._send(i)
           del(self.priqueue[0])
           return
       if(self.printing and self.queueindex<len(self.mainqueue)):
           tline=self.mainqueue[self.queueindex]
           tline=tline.split(";")[0]
           if(len(tline)>0):
               self._send(tline,self.lineno,True)
               self.lineno+=1
           else:
               self.clear=True
           self.queueindex+=1
       else:
           self.printing=False
           self.clear=True
           if(not self.paused):
               self.queueindex=0
               self.lineno=0
   def _send(self, command, lineno=0, calcchecksum=False):
       if(calcchecksum):
           prefix="N"+str(lineno)+" "+command
           command=prefix+"*"+str(self._checksum(prefix))
           if("M110" not in command):
               self.sentlines[lineno]=command
       if(self.printer):
           self.sent+=[command]
           if self.loud:
               print("SENT: "),bytes(command,"ascii")
           if self.sendcb is not None:
               try:
                   self.sendcb(bytes(command,"ascii"))
               except:
                   pass
           # print(command)
           self.printer.write(bytes(command,"ascii")+bytes("\n","ascii"))
if __name__ == '__main__':
   #print "Usage: python printcore.py filename.gcode"
   #filename="../prusamendel/sellsx_export.gcode"
   #if len(sys.argv)>1:
   #    filename=sys.argv[1]
   #    print "Printing: "+filename
   #else:
   #    print "Usage: python printcore.py filename.gcode"
       #sys.exit(2)
   p=printcore('/dev/ttyACM0',115200)
   p.loud=False
   statusreport=False
   time.sleep(2)
   print(p.printer)
   #testdata=[i.replace("\n","") for i in open(filename)]
   #p.startprint(testdata)
   #time.sleep(1)
   #p.pause()
   #print "pause"
   #time.sleep(5)
   #p.resume()
   #try:
   #if statusreport:
   #        p.loud=False
   #        sys.stdout.write("Progress: 00.0%")
   #        sys.stdout.flush()
   #    while(p.printing):
   #        time.sleep(1)
   #        if statusreport:
   #            sys.stdout.write("\b\b\b\b%02.1f%%" % (100*float(p.queueindex)/len(p.mainqueue),) )
   #except:
   wait = 0
   while (not p.online or wait > 100):
       time.sleep(1)
       wait += 1
       print( str(wait) + "\n")
   if p.online:
   	p.printer.write(bytes("G1 X5\n","ascii"))
   #    print("move X")
   	time.sleep(2)
   	p.printer.write(bytes("G1 Y5\n","ascii"))
   	time.sleep(2)
   #    print ("move Y")
   	p.printer.write(bytes("G1 Z5\n","ascii"))
   	time.sleep(2)
   #    print ("move Z")
   p.disconnect()
