[>>populating data 5/26/2013- You are welcome to help. see [1]<<
This guide assumes a basically properly built and calibrated printer Main_Page.
If you have not read through and attempted a complete calibration, see the REPRAP wiki for Calibration instructions. Some common calibration issues as well as common build related issues however are discussed.
(Please note: This guide is for identified and resolved issues only. The more common the issue, the better. No questions or open issues belong here, go to the forums for interactive help. Use clear and concise language, only 6 pics or entries per issue.)
The following categories are used to help identify the print issue by either print defects or by cause (if known).
The print defects will point to identified causes and branch into individual examples and solutions:
CAUSES:
Material Feed
Excessive
Insufficient
Intermittent
Material Handling or Source
Material Contamination
Extruding Temperature
Too hot
Too cold
Clogged Extruder
Bed Adherence
Insufficient
Bed Adherence insufficient
Problem
Common Cause
Correction
Forum Link
Prints do not adhere to build platform.
Print head too high to push plastic against build platform
Change height settings to no greater than nozzle diameter above bed, calibrate bottom stop, level build platform
| Tall parts tend to detach before build is complete. | Too low of contact area for the height or too low adhesion. | Select to use a raft with a larger footprint to aid adhesion. | [7] |
</td>
</tr>
Corner Lift
File:?
Problem
Common Cause
Correction
Forum Link
Outside corners lift from build surface as build progresses.
Differential cooling of printed object.
Select to print a perimeter skirt in Skeinforge or brim in slic3r with a substantial height. The tall skirt/brim acts like a shell which holds in the heat and reduces corner lift.
[8]
Excessive
Bed Adherence Excessive
Problem
Common Cause
Correction
Forum Link
Printed parts adhere to the print bed too aggressively. Shown ABS printed on heated PC (polycarbonate) sheet.
Bed material selection needs to be compatible with material printed and temperature used.
PLA on heated glass works well as a build surface, Blue painters tape unheated works well for PLA, ABS on heated bed with Kapton tape works well, ABS on heated bed with PET tape works well. See build forum for examples and suggestions.
[9]
| Printed parts adhere too aggressively. Shown ABS on heated glass took chip out of glass. | ABS may adhere too aggressively on uncoated glass. | Use Kapton or PET tape on glass for ABS. See build forum for examples and suggestions. | [10] |
</td>
</tr>
Print Speed
Too Fast
Too Slow
Calibration
circularity
Non-circular Holes
Problem
Common Cause
Correction
Forum Link
Holes come out compressed in one direction (X or Y).
Loose drive train on the deformed axis.
Inspect the discrepant axis drive train for excessive slack in belt, loose gears on shafts or gear play then tighten as appropriate.
[11]
scale
Skipping Steps
Controller Overpowered
Controller Underpowered
Part Temperature
Too hot
Too cold
PRINT DEFECTS:
Surface Defects
Pitting/Holes
#Material Contamination
Small Single Filament
Large Area of Filament
Jagged/Waviness
Solidity of Surface
Strings
Blobs
Fineness of Detail
Filaments not Touching
Infill Gaps
Body Defects
Hole Size
Bridging Failure
Warping
#Part Temperature
Stepping/Offsetting
#Skipping Steps, Controller Overpowered
Interlayer Delamination
#Part Temperature
Failure at Height
#Part Temperature
Overall Disaster
