[>>populating data 5/26/2013- You are welcome to help. see [1]<<
This guide assumes a basically properly built and calibrated printer Main_Page.
If you have not read through and attempted a complete calibration, see the REPRAP wiki for Calibration instructions. Some common calibration issues as well as common build related issues however are discussed.
(Please note: This guide is for identified and resolved issues only. The more common the issue, the better. No questions or open issues belong here, go to the forums for interactive help. Use clear and concise language, only 6 pics or entries per issue.)
The following categories are used to help identify the print issue by either print defects or by cause (if known).
The print defects will point to identified causes and branch into individual examples and solutions:
CAUSES:
Material Feed
Excessive
Insufficient
Intermittent
Material Handling or Source
Material Contamination
Extruding Temperature
Too hot
Too cold
Clogged Extruder
Bed Adherence
Insufficient
Corner Lift
File:?
Problem
Common Cause
Correction
Forum Link
Outside corners lift from build surface as build progresses.
Differential cooling of printed object.
Select to print a perimeter skirt with a substantial height. The tall skirt acts like a shell which holds in the heat and reduces corner lift.
Excessive
Bed Adherence Excessive
Problem
Common Cause
Correction
Forum Link
Printed parts adhere to the print bed too aggressively. Shown ABS printed on heated PC (polycarbonate) sheet.
Bed material selection needs to be compatible with material printed and temperature used.
PLA on heated glass works well as a build surface, Blue painters tape unheated works well for PLA, ABS on heated bed with Kapton tape works well, ABS on heated bed with PET tape works well. See build forum for examples and suggestions.
[7]
| Printed parts adhere too aggressively. Shown ABS on heated glass took chip out of glass. | ABS may adhere too aggressively on uncoated glass. | Use Kapton or PET tape on glass for ABS. See build forum for examples and suggestions. | [8] |
</td>
</tr>
Print Speed
Too Fast
Too Slow
Calibration
circularity
scale
Skipping Steps
Controller Overpowered
Controller Underpowered
Part Temperature
Too hot
Too cold
PRINT DEFECTS:
Surface Defects
Pitting/Holes
#Material Contamination
Small Single Filament
Large Area of Filament
Jagged/Waviness
Solidity of Surface
Strings
Blobs
Fineness of Detail
Filaments not Touching
Infill Gaps
Body Defects
Hole Size
Bridging Failure
Warping
#Part Temperature
Stepping/Offsetting
#Skipping Steps, Controller Overpowered
Interlayer Delamination
#Part Temperature
Failure at Height
#Part Temperature
Overall Disaster
