Print Troubleshooting Pictorial Guide
Revision as of 22:26, 16 April 2013 by Rrr7 (talk | contribs) (Material Contamination)
[>>populating data 4/16/2013- You are welcome to help. see [1]<<
This guide assumes a basically properly built and calibrated printer Main_Page. If you have not read through and attempted a complete calibration, see the REPRAP wiki for Calibration instructions. Some common calibration issues as well as common build related issues however are discussed.
(Please note: This guide is for identified and resolved issues only. The more common the issue, the better. No questions or open issues belong here, go to the forums for interactive help. Use clear and concise language, only 6 pics or entries per issue.)
The following categories are used to help identify the print issue by either print defects or by cause (if known). The print defects will point to identified causes and branch into individual examples and solutions:
CAUSES:
Material Feed
Excessive
Material Feed, Excessive
Problem Common Cause Correction Forum Link
Wall thicknesses are coming out too thick, objects have outside dimensions consistently slightly too large and holes are slightly too small. Slicer software settings for perimeter widths are slightly too high. Reduce flow rate setting for perimeters. Skeinforge has these settings available to change.
Insufficient
Intermittent
Material Handling or Source
Material Handling, Material Contamination 01
Tiny filament width holes on print sides. Steam blow-outs or bubbles from water absorbed from the humidity in the air into the raw filament during storage prior to printing. PLA is more susceptible to this as it has an affinity for water. Proper handling of filament to reduce exposure to humidity. [2]
</tr>
Material Handling, Material Contamination 02
Extruder jamb without apparent cause is a symptom. After extruder hot section disassembly and clean out, no source of jamb commonly found. May be visible in transparent filaments and may be accompanied by gas bubbles. Test for condition: (may damage nozzle) while extruder hot, insert orifice size drill bit up nozzle. If ooze occurs then stops again after drill bit removal, foreign particle may be in melt chamber. Particulate inclusions in raw filament as purchased from source. Found in cheap filament (Chinese mfr) noted in PLA from Esun. Use quality filament from known sources. [3]
Indications of abrasion may be noticed internally in the thermal isolator of the hot end with the lines of abrasion in the direction of filament feed when disassembled. Print may show indications of intermittent plugging and unplugging of nozzle. Low melting point metal (likely solder) ball noted in ABS (mfr not determined).This may indicate sub-orifice size foreign particles passing through extruder.Use quality filament from known sources.[4]
</td>
Material Handling, Material Contamination 03
Popping sound from nozzle like air bubbles under pressure or popcorn popping. Causing blowouts and missing plastic in part buildup. Filament (ABS in this case) contains air bubbles from manufacturing process. Use quality filament from known sources [5]
Extruding Temperature
Too hot
Too cold
Clogged Extruder
Clogged Extruder
Extruder jambs at normal temperatures in the hotend's thermal isolator bore. Excessive thermal isolator bore diameter allowing too much molten plastic back flow too far up isolator bore causing jamb when it solidifies. Replace thermal isolator or isolator sleeve leaving .1 to .2mm only above filament diameter clearance for filament thermal expansion. (ex. 3.175mm for 3mm filament, filament is actually 2.9 +/-.1mm)
Bed Adherence
Insufficient
Bed Adherence, insufficient 01
Prints do not adhere to build platform. Print head too high to push plastic against build platform Change height settings to no greater than nozzle diameter above bed, calibrate bottom stop, level build platform
Excessive
Print Speed
Too Fast
Too Slow
Calibration
circularity
scale
Skipping Steps
Controller Overpowered
Skipping Steps, Controller Overpowered
printer head fails to keep its position and prints successive layers offset from lower layers. Frequently called skipping steps, joggle or offsetting. Several possible causes- This one was stepper controllers had their potentiometers (pots) adjusted too high (clockwise), causing overheating of stepper controller and causing a short controller reset to cool down. This high setting may also produce hotter stepper motors. Reduce pot setting (current) by carefully turning pot counter-clockwise. [6]
Controller Underpowered
Part Temperature
Too hot
Part Temperature, too hot 01
Prints warp at height Part temperature builds up as part is built Change settings to turn off or down temp of heated build platform after base layers are complete. Ex: with heat on all through print and off upon print start (starting at full temp but cooling as it goes) (pic01).  ?
Too cold
Part Temperature, Too Cold 01
Part warping and delamination as print progresses. Part cools too fast causing contration especially in ABS which has a higher glass transition temp of ~140C. Print perimeter surrounding skirt full height of part to keep the heat in. [7]
PRINT DEFECTS:
Surface Defects
Holes
Small Single Filament
Large Area of Filament
Waviness
Solidity of Surface
Strings
Blobs
Fineness of Detail
Filaments not Touching
Body Defects
Warping
#Part Temperature
Stepping/Offsetting
Interlayer Delamination
#Part Temperature
Failure at Height
#Part Temperature
Overall Disaster
If you are not certain about having correctly calibrated you printer, verify that it is calibrated first as that is the first step. See Calibration. Verify you also calibrated your extruder. Then verify your extruder zero height (endstop position) above your print bed is appropriately set.
