>>Currently populating data 3/4/2013- You are welcome to help. see [1]<<
This guide assumes a basically properly built and calibrated printer Main_Page.
If you have not read through and attempted a complete calibration, see the REPRAP wiki for Calibration instructions. Some common calibration issues as well as common build related issues however are discussed.
The following categories are used to help identify the print issue by either print defects or by cause (if known).
The print defects will point to identified causes and branch into individual examples and solutions:
CAUSES:
Material Feed
Excessive
Insufficient
Intermittent
Material Handling
Material Contamination
Material Handling, Material Contamination 02
Problem
Common Cause
Correction
Forum Link
Extruder jamb without apparent cause is a symptom. After extruder hot section disassembly and clean out, no source of jamb commonly found. May be visible in transparent filaments and may be accompanied by gas bubbles. Test for condition: (may damage nozzle) while extruder hot, insert orafice size drill bit up nozzle. If ooze occurs then stops again after drill bit removal, foreign particle may be in melt chamber.
Particulate inclusions in raw filament as purchased from source. Found in cheap filament (Chinese mfr) noted in PLA from Esun.
Use quality filament from known sources.
[3]
| Indications of abrasion may be noticed internally in the thermal isolator of the hot end with the lines of abrasion in the direction of filament feed. | | | |
</td>
</tr>
Extruding Temperature
Too hot
Too cold
Clogged Extruder
Bed Adherence
Insufficient
Excessive
Print Speed
Too Fast
Too Slow
Calibration
circularity
scale
Skipping Steps
Part Temperature
Too hot
Too cold
PRINT DEFECTS:
Surface Defects
Holes
Small Single Filament
Large Area of Filament
Waviness
Solidity of Surface
Strings
Blobs
Fineness of Detail
Filaments not Touching
Body Defects
Warping
#Part Temperature
Stepping/Offsetting
Interlayer Delamination
#Part Temperature
Failure at Height
#Part Temperature
Overall Disaster
