Ppa install
Revision as of 05:34, 7 July 2011 by Bsutton (talk | contribs)
Here is Jonathan Marsden's personal package archive with the RepRap Debian/Ubuntu packages:
[1]
You can install them on an Ubuntu machine with the following commands.
<nowiki>
sudo apt-add-repository ppa:jmarsden/reprap && sudo apt-get update sudo apt-get -y install reprap-mendel-host reprap-mendel-electronics reprap-mendel-firmware reprap-mendel-mechanics reprap-utils <nowiki>
You also probably need to add a udev rule to access the communication port.
<nowiki>
echo 'SYSFS{idVendor}=="0403", SYSFS{idProduct}=="6001", MODE="666"' | sudo tee /etc/udev/rules.d/sanguino-usb.rules > /dev/null <nowiki>
To get the software for loading firmware into the Sanguino chip, issue the following commands (not necessary, if the firmware has been loaded already).
<nowiki>
sudo apt-get -y install arduino sudo wget --continue --directory-prefix=/tmp 'http://sanguino.googlecode.com/files/Sanguino-0018r2_1_4.zip' sudo unzip -o /tmp/Sanguino-0018r2_1_4.zip Sanguino/* -d /usr/share/arduino/hardware <nowiki>
