PonokoXAxisAssembly
Revision as of 00:30, 4 December 2008 by RussNelson (talk | contribs) (version migrated from twiki)
Assembling the Ponoko RepRap X Axis
[PonokoRepRap Main Ponoko Page]
Prev StepNext Step
Please, read the instructions completely through before you start.
The X axis assembly consists of a motor bracket, a carriage and an idler housing all transfixed by four 500mm x 8mm diameter bright (zinc plated) steel rods. The X motor bracket can accept NEMA 17 or NEMA 23 stepper motors. Use washers under the heads of all screws unless told otherwise. Where nuts can freely rotate, there should also be a washer between the nut and the plastic.
DO NOT remove protective paper from the 3mm slides used in the exchangeable extruder socket. You're reading the instructions through, right? You'll find it mentioned here.
Start by assembling the X carriage. You will need to locate the laser-cut components shown on the right, together with the appropriate fasteners listed below:
  • 17 off M3x16 screws
  • 1 off M3x20 screw
  • 19 off M3 nuts
  • 22 off M3 washers
Put an M3 washer on each of 2 M3x16mm screws, insert them through the rear panel of the carriage as shown, and fit nuts.
Bring the back of the carriage upright and slot the nuts into the cavities of the carriage base as shown. Note that the laser cuts on a slight slope, so if the nuts won't go in from one side, turn the part over and try again. Note also that the nuts do not want to go into the holes, and sometimes need encouraging with tweezers or similar. You may wish to apply tape to one side before putting them in, and tape on the other side to hold them in while you assemble the pieces. Remove the tape when you're done.
Here is a close-up shot showing how the nuts fit into the slots and the screws clamp everything together. As the washers may extend past the lower edge of the workpiece, you can't just flatten it on the bench and assume everything will come out level. You have to adjust it carefully.
Do not tighten the screws fully until all the parts of the carriage are in place. You may need the wiggle-room later.
Do not over-tighten the screws. This breaks the acrylic and means you either have to glue the bits together or hack a new part out of acrylic manually. Either will slow down your progress somewhat.
Put the washers on 3 M3x16mm screws and put them into the 3 holes on the side piece. Fit the side piece to the base, then add the two M3x16 screws and nuts (don't forget the washers) to the right side of the carriage. Then repeat with the left side, but only fit the lower two of the screws to the back of the carriage on the right hand side (shown un-assembled in the photo):
Gather the remaining long M3 screw and thread the washer, nut, and opto flag holder onto the screw to make a mechanical shish kebab. Do not fit the opto flag into the holder yet. We do that last as they are fragile and tend to bump into things during calibration.
This is what the kebab looks like. The first nut is because we need a non-standard length screw. You could just truncate the screw but this saves you the time and trouble.
It's hard to show on the photos, but the chain clamps are actually on the inside of the box-like carriage structure. If you choose to use split washers (more in a sec.), put them on the screws first and then ordinary washers.
Do not finish out the clamps yet - we put the chain in them a bit later.
If you have some split washers handy, you might want to fit them on the screws that retain the chain clamps first. We don't know yet. They might help the chain stay firmly gripped as it beds in, or may give too much and let the chain slip. Experiment.
... and after all is done, your X carriage should look a lot like this one. Put it aside and save it for the next step, which is adding the socket for the exchangeable extruder. If you have the "redux" kit, the extruder is fixed with bolts through the obvious holes and there is no socket, so you can skip that part. Exchangeable extruders are handy if you want to run different materials regularly.
Prev StepNext Step
-- Main.VikOlliver - 23 Oct 2008
