PonokoUpperCornerAssembly
Revision as of 23:00, 5 December 2008 by RussNelson (talk | contribs) (version migrated from twiki)
Making the Ponoko RepRap Upper Corners
[PonokoRepRap Main Ponoko Page]
Prev StepNext Step
These are the top corners of the RepRap and construction is similar to the lower corners. This time though, there are two corners pointing one way, and two otherwise identical mirror images. Either 608 ZZ bearings or the lasercut ball bearing races may be used.
This is very similar to the Lower Corners, which you should have done by now. Start by locating the components for an Upper Corner Assembly:
Put the washers on four M3 25mm machine screws and join the 3mm segment to the two 5mm segments as shown in the photo:
Attach the lower 8mm segment in a similar way, and then add the BBs and bearing race like you did with the Lower Corners.
Actually, you don't have to assemble the bearings just yet - particularly if you find loaded bearings tricky things to deal with. You might find it easier to wait until later, when the Z Axis is assembled inside the supporting framework.
Make two like that, and two that are a mirror image of it. Use the bolts & washers trick to keep them together while you assemble the other framework bits.
Prev StepNext Step
-- Main.VikOlliver - 14 Nov 2008
