PonokoUpperCornerAssembly
Making the Ponoko RepRap Upper Corners
UNDER CONSTRUCTION
These are the top corners of the RepRap and construction is similar to the lower corners. This time though, there are two corners pointing one way, and two otherwise identical mirror images. Either 608 ZZ bearings or the lasercut ball bearing races may be used.
Start by locating the components for an Upper Corner Assembly:
Hopefully there will be a nice photo showing it all competed here very shortly.
Now you can move on to assembling the upper frame.
-- Main.VikOlliver - 09 Nov 2008
