PonokoBOM
Revision as of 20:03, 31 December 2008 by RussNelson (talk | contribs) (version migrated from twiki)
This Bill of Materials is complete for the instructions that have been written. More parts WILL be needed as more instructions are added. I may have made mistakes, however. This page is automatically generated. Do not edit it. If you think you need to edit it, or have found a mistake, contact RussNelson. This BoM? is best for locating parts needed for a particular assembly. For procuring parts, Zach's parts lister at http://parts.reprap.org/ is best, but I have to figure out how to import this into it.
Changes from the previous BOM to this one: http://reprap.org/bin/rdiff/Main/PonokoBOM?rev1=1.6&rev2=1.3
- 1 PonokoBedChainFitting
- 2 PonokoCornerAssembly
- 3 PonokoExtruderAssembly
- 4 PonokoExtruderSocketAssembly
- 5 PonokoFrameBaseAssembly
- 6 PonokoFrameBracing
- 7 PonokoRepRap
- 8 PonokoRepRapXAxisAssembly
- 9 PonokoRepRapXMotorAssembly
- 10 PonokoUpperCornerAssembly
- 11 PonokoXAxisAssembly
- 12 PonokoXIdlerAssembly
- 13 PonokoYAxisAssembly
- 14 PonokoYInstallation
- 15 PonokoZAxisTensioner
- 16 PonokoZFrameAssembly
- 17 PonokoZMotorAssembly
- 18 all
1 2200mm of 4.5mm ball chain 3 8mm i/d compression spring approximately 16mm long 12 M3 25mm screw 12 M3 nut 24 M3 washer 3 M8 25mm screw 6 M8 nut 9 M8 washer
24 4.5mm BBs 24 M3 25mm screw 24 M3 nut 48 M3 washer
1 0.1uF capacitor 1 200-300mm of nichrome wire with a resistance of about 8 ohms 1 35mm piece of 10mm diameter PTFE rod with a 3mm hole drilled down the centre 1 40mm long piece of M6 brass bolt with a 3mm hole drilled right down the middle 2 608Z skate bearing 1 625ZZNSK bearing 5 M3 20mm screw 2 M3 30mm screw 4 M3 40mm screw 3 M3 50mm screw 11 M3 nut 23 M3 washer 2 M5 25mm screw 5 M5 30mm screw 4 M5 nut 1 M5 nyloc nut 4 M5 washer 1 M6 32mm o/d washer 2 M6 dome nut 2 M6 half- or press-nut 2 M6 washer 4 M8 nut 1 M8 studding 110mm 4 M8 washer 1 PTFE tape 1 gear motor 2 hole socket strip 4 large M3 washer 4 small, stout springs 1 thick, solid, insulated copper wire
4 M3 16mm screw 2 M3 25mm screw 6 M3 nut 8 M3 washer 8 M5 30mm screw 6 M5 nut 2 M5 nyloc nut 16 M5 washer
4 8mm diameter 500mm long bright steel rod 12 M3 40mm screw 12 M3 nut 24 M3 washer 4 M8 400mm studding 16 M8 nut 8 M8 washer
PonokoFrameBracing
20 M3 25mm screw 20 M3 nut 40 M3 washer 8 M8 600mm studding 2 M8 650mm studding 40 M8 nut 40 M8 washer
PonokoRepRap
3 1200mm of 3.5mm ball chain 4 8mm diameter 500mm long bright steel rod 3 M3 25mm screw 3 M3 nut 6 M3 washer 4 M5 50mm screw 2 M5 8mm grub screw 10 M5 nut 8 M5 washer 1 M8 half-nut 1 M8 nut 1 M8 washer
4 M3 12mm screw 4 M3 16mm screw 4 M3 20mm screw 16 M3 25mm screw NEMA17 2 M3 40mm screw 12 M3 nut 16 M3 nut NEMA17 22 M3 washer 32 M3 washer NEMA17 4 M5 25mm screw NEMA23 4 M5 nut NEMA23 8 M5 washer NEMA23
32 M3 25mm screw 32 M3 nut 64 M3 washer
PonokoXAxisAssembly
17 M3 16mm screw 1 M3 20mm screw 19 M3 nut 22 M3 washer
1 608Z skate bearing 4 M3 12mm screw 4 M3 16mm screw 12 M3 20mm screw 8 M3 25mm screw 2 M3 40mm screw 24 M3 nut 46 M3 washer 1 M8 80mm studding 5 M8 nut 3 M8 washer 2 M8 wide aka fender washer
PonokoYAxisAssembly
4 608Z skate bearing 8 M3 30mm screw 8 M3 nut 12 M3 washer 1 M8 500mm studding 2 M8 70mm bolt ifbolt 2 M8 70mm studding ifstudding 8 M8 nut 2 M8 nut ifstudding 2 M8 nyloc nut 12 M8 washer
PonokoYInstallation
8 M5 8mm grub screw 8 M5 nut
2 5mm i/d soft plastic tubing, approx 22mm long 4 M3 12mm machine screw 5 M3 25mm machine screw 10 M3 nuts 14 M3 washers 2 M5 50mm machine screw 2 M5 nut 4 M5 washers
8 8mm diameter 500mm long bright steel rod 8 M5 8mm grub screw 10 M5 grub screw 17 M5 nut 1 M8 half-nut 11 M8 nut 2 M8 washer
8 M3 25mm screw 3 M3 30mm screw 14 M3 nut 25 M3 washer 4 M5 25mm screw 1 M5 8mm grub screw 5 M5 nut 4 M5 washer
all
1 0.1uF capacitor 3 1200mm of 3.5mm ball chain 1 200-300mm of nichrome wire with a resistance of about 8 ohms 1 2200mm of 4.5mm ball chain 1 35mm piece of 10mm diameter PTFE rod with a 3mm hole drilled down the centre 24 4.5mm BBs 1 40mm long piece of M6 brass bolt with a 3mm hole drilled right down the middle 2 5mm i/d soft plastic tubing, approx 22mm long 7 608Z skate bearing 1 625ZZNSK bearing 16 8mm diameter 500mm long bright steel rod 3 8mm i/d compression spring approximately 16mm long 4 M3 12mm machine screw 8 M3 12mm screw 29 M3 16mm screw 22 M3 20mm screw 5 M3 25mm machine screw 109 M3 25mm screw 16 M3 25mm screw NEMA17 13 M3 30mm screw 20 M3 40mm screw 3 M3 50mm screw 197 M3 nut 16 M3 nut NEMA17 10 M3 nuts 364 M3 washer 32 M3 washer NEMA17 14 M3 washers 6 M5 25mm screw 4 M5 25mm screw NEMA23 13 M5 30mm screw 2 M5 50mm machine screw 4 M5 50mm screw 19 M5 8mm grub screw 10 M5 grub screw 52 M5 nut 4 M5 nut NEMA23 3 M5 nyloc nut 32 M5 washer 8 M5 washer NEMA23 4 M5 washers 1 M6 32mm o/d washer 2 M6 dome nut 2 M6 half- or press-nut 2 M6 washer 3 M8 25mm screw 4 M8 400mm studding 1 M8 500mm studding 8 M8 600mm studding 2 M8 650mm studding 2 M8 70mm bolt ifbolt 2 M8 70mm studding ifstudding 1 M8 80mm studding 2 M8 half-nut 91 M8 nut 2 M8 nut ifstudding 2 M8 nyloc nut 1 M8 studding 110mm 79 M8 washer 2 M8 wide aka fender washer 1 PTFE tape 1 gear motor 2 hole socket strip 4 large M3 washer 4 small, stout springs 1 thick, solid, insulated copper wire
-- Main.RussNelson - 31 Dec 2008
