Pololu Extruder Stripboard
Revision as of 17:03, 26 July 2010 by Tbuser (talk | contribs) (Wiring)
Release status: concept
GPL
Introduction
The idea is to make a dead simple stripboard mounted Pololu A4983 Stepper Motor Driver and connect it to the existing RepRap electronics in order to bypass the noisy inefficient 2 H-bridge hack on the extruder controller. (at least until an all Pololu Electronics PCB design matures) I have it working with a temporary breadboard setup, but a better solution would be to mount it on stripboard...
Parts
<iframe width='500' height='300' frameborder='0' src='http://spreadsheets.google.com/pub?key=0AtBLRDaDs5APdFlhcEhpbWRQckF4THoyYXcyMVJ5eVE&hl=en&output=html&widget=true'></iframe>
Assembly
Under Construction...
Split 12v Power
Solder Stripboard Mount
Wiring
4 pins on top right corner of motherboard. 5v, GND, SDA (to STEP), and SCL (to DIR) on Pololu board. 12v and GND from cholocate block split above.
Firmware Changes
In motherboard firmware's configuration.h change E0_STEPS_PER_MM to 32 for 1/16 microstepping.
