Plastic Shredder using Kitchen Blender
Revision as of 06:01, 4 July 2014 by Traumflug (talk | contribs) (Create page from the forum thread. Pictures will be added later, uploading is broken for a moment.)
Release status: unknown
A simple way to turn scrap printed parts into granules small enough to feed a Filament Extruder.
unknown
Here we show a process to turn scrap plastics into granules usable with a Granule Extruder.
Flattening the parts
First step is to make these parts flat. As they're thermoplastic (else you wouldn't be able to print with them later), you can melt them. And right, the easiest way is to melt them in an oven:
Putting failed prints onto baking paper and applying some heat ... ... turns them into nice flat pieces.
Shreddering
These flat pieces are more easily to break, so you can put them into a blender to make granules of them.
Sieving
As you likely have a printer, you can print your own sieve! It's said that parts should have a maximum size of 5 mm.
Further Reading
Procedures achievinf a similar goal and, of course, extruders which can turn these granules back into filament, can be found in.
