PartsSupplies
These pages should be merged such that both pages do not attempt to cover the duplicate topics.
- 1 How to get the parts to build a RepRap printer
- 1.1 3Distributed
- 1.2 The RepRap For-Sale Forum
- 1.3 RepRap Parts Lister
- 1.4 Kent's strapper:
- 1.5 Charlie's 3D Technologies
- 1.6 RepRap Source
- 1.7 !iPrint3D
- 1.8 German RepRap Foundation (GRRF)
- 1.9 3D Acessories Hub
- 1.10 Ponoko Lasercut Parts
- 1.11 Cubic Print
- 1.12 Rapid Prototyping Services
- 1.13 Machine your own
There are a number of places that you can buy kits of parts for RepRap machines. These are listed on this page. Also, if you want to make your own parts, check out the last section: "Machine Your Own". This links to the design files for you use or edit.
3Distributed
3Distributed is a company set up in the United Kingdom which supplies printed parts as well as a print on demand service for anything else you might need printed. Visit their website here or e-mail [email protected] for a print quote.
They also offer a range of printer parts, kits, and filament materials.
We run a forum where people can post the availability of parts for RepRap machines that they have made in their own RepRap machines, or anything else useful to RepRap builders. Go to the For-Sale Forum here.
RepRap Parts Lister
RepRap Google Docs Parts Lister.
Also, I don't know if it knows about Prusa Mendel or other, post-Ed Mendels. --Sebastien Bailard 19:25, 16 December 2010 (UTC)
Kent's strapper:
è la prima risorsa italiana per reperire le parti per il montaggio della reprap Prusa
It's the first resource in Italy to find the parts of reprap Prusa visita il sito qui
Charlie's 3D Technologies is a company set up in Belgium to supply RepRap parts. Visit their site here.
RepRap Source
RepRap Source is a company set up in Germany to supply RepRap parts. Visit their site here.
!iPrint3D
!iPrint3D is a company set up in Belgium to supply RepRap parts. Visit their site here.
German RepRap Foundation is a company set up in Germany to supply RepRap parts. Visit their site here.
3D Acessories Hub
3D Acessories Hub is an Indian company setup in India to manufacture and supply Repraos parts word wide. You may find more information about us on .
[ https://www.3dacessorieshub.com ]
Ponoko run an online laser-cutting service using a wide range of sheet materials. Toby Borland was kind enough to supply us with a 2D version of the RepRap design, and inspired by this Vik Olliver modified it and Ian Adkins' design to work using three sheets of 3mm, 5mm, and 8mm acrylic (5mm sheet twice as big). It can, and has, been built using plywood, however, the slight variability in plywood thickness makes it very hard to assemble some parts. Work has switched to acrylic.
This is currently being shipped, and has reached version 1.1 . More details under PonokoRepRap.
Note: Ponoko have kindly given Vik Olliver a discounted Ponoko account to cut parts and kits for RepRap users with.
Cubic Print
Cubic Print is a company set up in Germany to supply RepRap parts. Visit their site here.
Has anyone used these guys? We probably should just buy parts from the for sales forum. --Sebastien Bailard 19:25, 16 December 2010 (UTC)
Because not everyone is able to get printed parts from reprapper friends yet, you can get (customized) plastic parts Rapid Prototyped at:
- Charlie's 3D Technologies
- Kent's strapperla prima risorsa italiana per stampare oggetti 3d a basso costo[NEW!!]
- Alpha Prototypes
- Star Prototype China
- www.r-design.hu - Hungarian. Claims to be relatively low cost, also for small runs.
- RedEye RPM - Various materials. Minimum order $ 150.
- RapidPrototyping.NL in the Netherlands (English + Dutch texts)
- 3DP-TOOLS - Switzerland, ABS parts printed on its RepRap machines, very competitive price
- Laser Prototypes Europe
- 3E rapid prototyping services - provides a comprehensive range of RP services from China
- Alu rapid prototyping services - China based supplier offers state-of-the-art production technology
Machine your own
If you have the tooling, build a WolfStrap. Then print Mendels. These directions are kind of silly.
If you already have a Mendel or some other RepStrap, the Mendel materials procurement page describes how to make your own reprapped parts.
If you already have your own machining facilities, part files for all the rapid-prototyped parts of RepRap can be downloaded from Sourceforge here. Check all the releases under 'Object files'.
At the moment the STL files are not all generated from AoI, and this means that not all of them will load properly into the RepRap software. We are working to correct this, but meanwhile here's a workround (thanks to Andy Sterne).
Procedure for generating corrected .stl files from !Solidworks:
- Open the file in wordpad or notepad
- Save it with the extension .csv instead of .stl
- Use Cntrl+H to replace all spaces with a comma and a space
- Save the file and exit
- Browse to the file and double click on it to open it in Excel
- Use Cntrl+A to select the entire worksheet
- Right click and select format cells
- Select the Number tab and highlight the category Number
- Change the Decimal places to 12
- Click ok
- Use Cntrl+C to copy the entire worksheet
- Open wordpad or notepad and use Cntrl+P to paste the entire worksheet into the file
- Save the file with a slightly different name and with the extension of .stl
- Open RepRap.jar (or run the program from Eclipse) and load the part file to verify
Procedure for generating corrected .stl files from SolidEdge, using Art of Illusion:
- File->Import->STL (got an error but ignored it)
- Object->Convert to Triangle Mesh
- Object->Edit Object (opens mesh editor)
- Edit->Select All
- [optional] Mesh->Transform, (used 0,0,0 90,0,0 25.4,25.4,25.4 to scale and rotate)
- Mesh->Simplify Selection (used 0.05)
- close mesh editor
- File->Export->STL
-- Main.AdrianBowyer - 06 Dec 2007
- a1:
