PTFE
For a list of PTFE tubing suppliers see --> Bowden.
PTFE, also known under the brand name Teflon, has the lowest coefficient of friction of any known solid material and melts between 260°C and 327°C.
It's fairly hard and fairly stiff too, so it's ideal for RepRap parts including things low friction bushings to main assembly parts. Thermoplastics often swell just before they melt, so PTFE tube inserts are used in many extruder hot ends so that the swelled plastic slides on this insert, instead of wedging itself in, preventing extrusion. PEEK tubing can also be used for this purpose.
PTFE is used in lubricants, and PTFE grease highly recommended by many in the community as being low friction and inert. PTFE is also sold in very thin tape, known as plumbers tape or thread-sealing tape.
Despite it's relatively low melting temperature, "liquid" PTFE is much more of a thick gel than a true liquid. Because of this it cannot be injection molded; it is shaped and compressed in powder form, and then sintered. For this reason, PTFE is surprisingly expensive. It will likely remain a RepRap vitamin, unless powder printing takes off.
Properties
Property | PTFE (unfilled) | PTFE (25% glass filled) | PTFE (25% carbon filled) |
PHYSICAL | |||
Density (lb/in³) (g/cm³) | 0.078 (2.16) | 0.081 (2.25) | 0.075 (2.08) |
Water Absorption, 24 hrs (%) | < 0.01 | 0.02 | 0.05 |
MECHANICAL | |||
Tensile Strength (psi) | 3,900 | 2,100 | 1,900 |
Tensile Modulus (psi) | 80,000 | - | - |
Tensile Elongation at Break (%) | 300 | 270 | 75 |
Flexural Strength (psi) | No break | 1,950 | 2,300 |
Flexural Modulus (psi) | 72,000 | 190,000 | 160,000 |
Compressive Strength (psi) | 3,500 | 1,000 | 1,700 |
Compressive Modulus (psi) | 70,000 | 110,000 | 87,000 |
Hardness, Shore D | D50 | D60 | D62 |
IZOD Notched Impact (ft-lb/in) | 3.5 | - | - |
THERMAL | |||
Coefficient of Linear Thermal Expansion(x 10-5 in./in./°F) | 7.5 | 6.4 | 6.0 |
Heat Deflection Temp (°F / °C) at 264 psi | 132 / 55 | 150 / 65 | 150 / 65 |
Melting Temp (°F / °C) | 635 / 335 | 635 / 335 | 635 / 335 |
Max Operating Temp (°F / °C) | 500 / 260 | 500 / 260 | 500 / 260 |
Thermal Conductivity (BTU-in/ft²-hr-°F) (x 10-4 cal/cm-sec-°C) | 1.70 (5.86) | 3.1 (10.6) | 4.5 (15.5) |
Flammability Rating | V-O | V-O | V-O |
ELECTRICAL | |||
Dielectric Strength (V/mil) short time, 1/8" thick | 285 | - | - |
Dielectric Constant at 1 MHz | 2.1 | 2.4 | - |
Dissipation Factor at 1 MHz | < 0.0002 | 0.05 | - |
Volume Resistivity (ohm-cm)at 50% RH | >10^18 | > 10^15 | 10^4 |
from boedeker-infopage.
Availability
PTFE rods suitable for RepRap extruders can be purchased from:
