P3Steel Vitamins
In RepRap jargon, a vitamin (also called an "imported part" or "non-printed part") is anything that you need to make a RepRap, which a RepRap cannot itself make.
Lasecut parts
P3Steel frame is mainly built from lasercut steel. CAD Drawings are available from GitHub and author's page on Thingiverse.
P3Steel V1.2 | P3Steel V2.0 |
Has 3 Bearings on Y Carriage and 4 point heated bed levelling system. | Has 4 Bearings on Y Carriage and 3 or 4 point heated bed levelling system. |
P3Steel V2.01:
CAD file for version 2.01: File:PRUSA i3 steel 3mm lasercut 2.01d irobri.dwg
Mechanical Parts
Bearings
Motors & couplings
Rods
Threaded rods
Only 2 M5 threaded rods are needed:
- 2x Threaded rod M5x295 mm
Smooth rods
6 Smooth rods are needed of the following sizes:
- 2x Ø8x375 mm for X-Axis
- 2x Ø8x341 mm for Y-Axis (350mm for version 2.01)
- 2x Ø8x320 mm for Z-Axis
Screws
Approximately (with a reasonable safety margin):
80 x M3 nyloc nuts.
60 x M3 12mm bolts. 20 x M3 20mm bolts. 20 x M3 8mm bolts.
20 x M3 washers.
2 x M8 30mm bolts. 2 x M8 nyloc nuts. 10 x M8 washers.
The above does not include the screws, washers and nuts needed by the extruder. Stainless steel (vs. mild steel or carbon steel) M3 screws and nuts are much preferable, mainly for the frame assembly.
Electronics
Image | Part | Quantity | Unit price | Total cost | Commentaries |
Arduino Mega 2560 board (or compatible) | 1 | -- | -- | The printer's "brain". | |
RAMPS 1.4 board | 1 | -- | -- | Interface betwen the arduino board and the hardware. | |
Stepper motor drivers. | 4 | -- | -- | Drive the motors | |
Mechanical endstops. | 3 | -- | -- | Endstops are required to calibrate the home position for each of the X, Y and Z-axis. Mechanical, optical or magnetic sensors can be used. | |
12864 Graphics LCD Controller or 2004 LCD Smart Controller | 1(Optional) | -- | -- | An LCD controller allows printing without having a computer connected to the Arduino, by reading G-code from an SD card. | |
ATX PSU or LED strip 12V power supply. | 1 | -- | -- | See Choosing a Power Supply for your RepRap. We want 12V@16A minimum. |
Extruder / Hotend
This is a tough choice for people building their first RepRap printer, as it can become a major stumbling point during the first attempts to print a 3D object.
