P3Steel Vitamins
Revision as of 20:42, 16 November 2013 by Jbabio (talk | contribs) (Motors & couplings)
EnglishEspañol
Introduction | Bill of materials | Proteins | Vitamins | Y-axis assembly | X-axis assembly | Connecting X-axis and Z-axis | Motor assembly | X and Y-axis motions | Heated bed assembly | Extruder assembly | Electronics and wiring
In RepRap jargon, a vitamin (also called an "imported part" or "non-printed part") is anything that you need to make a RepRap, which a RepRap cannot itself make.
Lasecut parts
P3Steel frame is mainly built from lasercut steel. CAD Drawings are available from GitHub and author's page on Thingiverse.
P3Steel V1.2 P3Steel V2.0
Has 3 Bearings on Y Carriage and 4 point heated bed levelling system. Has 4 Bearings on Y Carriage and 3 or 4 point heated bed levelling system.
Mechanical Parts
Bearings
Image Part Quantity Unit price Total cost Commentaries
P3S LM8UU.png LM8UU Lineal bearings 11 -- -- 4 for the Y carriage, 4 for the Z carriage and 3 for the X carriage.
P3S 608.png 608zz Axial bearings 4 -- -- Dos para cada idler.
P3S 608.png Other axial bearings (pending) -- -- -- --
Motors & couplings
P3S GT2.png GT2 or T2.5 Pulleys 2 -- -- --
P3S Correa GT2.png GT2 or T2.5 Belt -- -- -- --
P3S Acoplador 5mm.png Flexible coupling 5mm to 5mm 2 -- -- Couple the Z-Axis motors to the threaded rods.
Motor-pap.png NEMA 17 Stepper motors 5 -- -- 1 for the X-axis, 1 for the Y-axis, 2 for the Z-axis and 1 for the extruder.
Rods
Threaded rods
Only 2 M5 threaded rods are needed:
  • 2x Threaded rod M5x295 mm
Smooth rods
6 Smooth rods are needed of the following sizes:
  • 2x Ø8x375 mm for X-Axis
  • 2x Ø8x341 mm for Y-Axis
  • 2x Ø8x320 mm for Z-Axis
Screws
Pending.
Electronics
P3S Mega 2560.png Arduino Mega 2560 board (or compatible) 1 -- -- The printer's "brain".
P3S RAMPS.png RAMPS 1.4 board 1 -- -- Interface betwen the arduino board and the hardware.
P3S Stepstick.png Stepper motor drivers. 4 -- -- Drive the motors
P3S EndStop.png Mechanical endstops. 3 -- -- Tell the software when the carriage has reached the home position. Can be replaced with optical or magnetic sensors.
P3S SmartLCD.png Smart LCD 1(Optional) -- -- Run your RAMPS without a computer just with a SD card and Gcode files.
P3S PSU.png Power supply. 1 -- -- Min power 16A, Recommended 30A
