P3Steel Extras
Revision as of 16:40, 28 October 2014 by AndrewBCN (talk | contribs) (Bed leveling thumbwheels (low profile))
English
Introduction | Bill of materials | Proteins | Vitamins | Painting the steel frame parts | Main steel frame assembly | Y-axis assembly | X-axis assembly | Connecting X-axis and Z-axis | Motor assembly | X and Y-axis motions | Heated bed assembly | Extruder assembly | Electronics and wiring | Extras
There are a few extra items that can be added to the basic P3Steel assembly that make its use more effective:
Small bed leveling thumbwheels (low profile)
These small low profile thumbwheels with an embedded M3 niloc nut make bed leveling so much easier that they are considered almost essential (only 3 or 4 are needed, depending on the P3Steel frame version assembled).
Small, low profile bed leveling M3 thumbwheels for P3Steel.
Note that larger thumbwheels may not fit in the narrow space available under the P3Steel Y-carriage. These are tested and fit (Thingiverse 39459).
Filament spool holder
Again, you can live for a short while without this part but sooner or later you are going to add it to your P3Steel!
