Optical sensor
Revision as of 03:04, 15 February 2006 by SimonMcAuliffe (talk) (version migrated from twiki)
Optical Sensor
A simple FDM opto-interrupter module.
TO BE DEVELOPED.
Here's a picture of a commonly available optointerrupter, which is also a convenient size for most applications.
The arms extend out 10.5mm with a gap of 5.5mm. The arm width is 4.5mm.
The LED and photo-transistor are mounted inside the arms, facing towards each other through a narrow vertical slot. The slot width is approximately 1mm.
Although it looks fairly solid, it is actually just a thin plastic shell mounted over a small PCB. There are small plastic clips (just little square blocks really) inside the shell that allow the PCB to snap into place. The LED and photo-transistor are soldered into the PCB and extend up the arm approximately half way.
If we use common off-the-shelf parts, they may need to be bent to face each other, which would probably require fatter arms.
