Open Hybrid Mendel/Parts
Parts
Download .rar: File:OpenHybridMendel 0.98.rar
Frame and Z Axis Parts
Quantity | File-Name | Comments | Diagram |
6 | Camiel_frame_vertex_6off | Alternative part by Camiel | |
2 | z-prusa-motor-mount_2off | From Prusa Mendel (V1) | |
2 | z-bar-top-clamp_2off | From Sells Mendel | |
4 | pla_coupling_nophead-1piece_4off | Alternative part by Nophead | |
4 | prusa_bar-clamp_4off | From Prusa Mendel (V1) | |
8 | y-bar-clamp_8off | From Sells Mendel | |
1 | y-idler-bracket_1off | From Sells Mendel | |
1 | y-motor-bracket_1off_mod3-15 | Modified by PSU Reprap Collective to remove vestigial endstop mount | |
1 | pulley_w-set_screw_2off | Same as in X Axis |
X Axis Parts
2 | x-180-z-bearing-plate_2off | From Sells Mendel | |
2 | PSU_x_vert_sideplate_360_end_2off | Alternative part to x-ver-drive-side-plate-360-end_2off. This piece was made to separate the threaded and smooth z-rods on both sides of the x-axis. | |
2 | x-360-z-bearing-plate_2off | From Sells Mendel | |
2 | x-360-z-bearing-plate-mirror_2off | From Sells Mendel | |
1 | xaxis-motor-bracket_1off | Alternative part by Rhys-jones | |
4 | x-bar-clamp-m3_4off | From Sells Mendel | |
4 | x-bar-clamp-m4_4off | From Sells Mendel | |
1 | x-end-bracket_1off | From Sells Mendel | |
4 | x-vert-drive-nut-trap_4off | From Sells Mendel | |
4 | x-vert-drive-side-plate_4off | From Sells Mendel | |
2 | x-axis-side-plate-nut-jig_2off | From Sells Mendel | |
1 | pulley_w-set_screw_2off | Same as in Frame and Z Axis |
Y Carriage Parts
4 | bed-spring_4off | From Sells Mendel | |
1 | OpenY_8mm Belt Harness_1off | Open Y by Buback, modified by PSU Reprap Collective | |
2 | OpenY_8mm Crossbar Mount_2off | Open Y by Buback | |
2 | OpenY_Arm 90 - 180_2off | Open Y by Buback | |
1 | OpenY_arm45 | Open Y by Buback, modified by PSU Reprap Collective | |
2 | OpenXY_bracket | Created by PSU RepRap Collective. Print two of these |
X Carriage
Two major issues affected the Open-X carriage: carriages occasionally "walk" up off the tracks, and inconsistent spacing of the undercarriage bracket occasionally allowed the extruder to move/twist laterally. Both of these issues were minimized through modifications by user Joe Bartolai. The OpenX Arm was shortened and an offset was added so that the bearing attached to it is centered on the rail. The OpenX undercarriage bracket was also modified by making the angle steeper where the lower bearings contact the rail and by increasing the spacing where the undercarriage bracket attaches to the carriage.
1 | OpenX_Carriage_1off | Open X by Buback | |
1 | OpenX_arm_PSU_1off | Open X by Buback Modified by PSU Reprap Collective | |
2 | OpenXY_bracket | Same as in Y Carriage |
Extruder
1 | HerringboneDrivenGear | Derived from anAlternative part by Rhys-jones. Current design by J.Bartolai | |
1 | HerringboneDriveGear | Alternative part by Rhys-jones | |
1 | Gregs_accessible_wades_v6 | Alternative extruder by Greg-Frost | |
1 | Gregs_accessible_wades_idler |
Electronics Mounting
Quantity of Materials Needed by Subsystem
Part Name | Frame | Z-Axis | Open Y-Axis | Open X-Axis | X-Carriage | Extruder | Total |
M3x6mm Flat Set Screw | - | - | 1 | 1 | - | 1 | 3 |
M3x10mm Cap Screw | - | 8 | - | 4 | - | 4 | 16 |
M3x20mm Cap Screw | - | 9 | 1 | 9 | - | - | 19 |
M3x25mm Cap Screw | - | 4 | - | - | - | - | 4 |
M3 Washer | - | 26 | 6 | 22 | - | 4 | 58 |
M3 Nut | - | - | 1 | 1 | - | 1 | 3 |
M3 Nylock | - | 9 | 1 | 9 | - | - | 19 |
M4x16mm Cap Screw | - | - | - | 4 | - | - | 4 |
M4x20mm Cap Screw | - | - | 8 | 4 | 14 | - | 26 |
M4x25mm Cap Screw | - | - | 4 | - | - | - | 4 |
M4x30 mm Cap Screw (low profile) | - | - | - | - | - | 3 | 3 |
M4x40mm Cap Screw | - | - | 16 | 30 | - | 2 | 48 |
M4x50mm Cap Screw | - | - | 4 | - | - | - | 4 |
M4 Washer | - | - | 72 | 84 | 34 | 8 | 198 |
M4 Large OD Washer | - | - | 8 | 8 | - | - | 16 |
M4 Nut | - | - | - | 8 | - | 3 | 11 |
M4 Nylock | - | - | 32 | 30 | 14 | 2 | 78 |
M8 Washer | 72 | 12 | 4 | - | - | 2 | 90 |
M8 Nut | 72 | 8 | 4 | 2 | - | - | 86 |
M8 Nylock | - | - | - | - | - | 1 | 1 |
Bearing 8x22x7 mm | - | - | - | - | - | 3 | 3 |
Bearing 4x13x5 mm | - | - | 12 | 14 | 10 | - | 36 |
Older complete version: File:OpenHybridMendel 0.96.rar
Threaded Rod and Smooth Rod
See the following page for a list of all the threaded and smooth rods required and how to cut them to length.
