Open Hybrid Mendel/Parts
Revision as of 18:18, 19 February 2013 by EtherDais (talk | contribs) (X Axis Parts)
Parts
Download Zip: File:OpenHybridMendel 0.95.rar
Frame and Z Axis Parts
Quantity File-Name Comments Diagram
6 Camiel_frame_vertex_6off Alternative part by Camiel Camiel frame vertex 7off.JPG
4 pla_coupling_nophead-1piece_4off Alternative part by Nophead Pla coupling nophead.JPG
1 y-motor-bracket_1off_mod3-15 Modified by PSU Reprap Collective to remove vestigial endstop mount Y-motor-bracket 1off mod3-15.JPG
X Axis Parts
2 x-180-z-bearing-plate_2off From Sells Mendel X-180-z-bearing-plate 2off.JPG
2 PSU_x_vert_sideplate_360_end_2off Alternative part to x-ver-drive-side-plate-360-end_2off. This piece was made to separate the threaded and smooth z-rods on both sides of the x-axis. PSU x vert sideplate 360 end 2off1.JPG
2 x-360-z-bearing-plate_2off From Sells Mendel X-360-z-bearing-plate 2off.JPG
2 x-360-z-bearing-plate-mirror_2off From Sells Mendel X-360-z-bearing-plate-mirror 2off.JPG
1 xaxis-motor-bracket_1off Alternative part by Rhys-jones Xaxis-motor-bracket 1off.JPG
4 x-vert-drive-nut-trap_4off From Sells Mendel X-vert-drive-nut-trap 4off.JPG
4 x-vert-drive-side-plate-180-end_4off From Sells Mendel X-vert-drive-side-plate-180-end 2off.JPG
2 x-axis-side-plate-nut-jig_2off From Sells Mendel X-axis-side-plate-nut-jig 2off.JPG
Y Carriage Parts
File:OHM OpenY.zip
1 OpenY_8mm Belt Harness_1off Open Y by Buback, modified by PSU Reprap Collective 8mm Belt Harness 1off.JPG
2 OpenY_8mm Crossbar Mount_2off Open Y by Buback 8mm Crossbar Mount 2off.JPG
1 OpenY_arm45 Open Y by Buback, modified by PSU Reprap Collective Arm 210.JPG
2 OpenXY_bracket Created by PSU RepRap Collective. Print two of these OpenXY bracket.jpg
X Carriage
File:OHM OpenX.zip
Two major issues affected the Open-X carriage: carriages occasionally "walk" up off the tracks, and inconsistent spacing of the undercarriage bracket occasionally allowed the extruder to move/twist laterally. Both of these issues were minimized through modifications by user Joe Bartolai. The OpenX Arm was shortened and an offset was added so that the bearing attached to it is centered on the rail. The OpenX undercarriage bracket was also modified by making the angle steeper where the lower bearings contact the rail and by increasing the spacing where the undercarriage bracket attaches to the carriage.
1 OpenX_arm_PSU_1off Open X by Buback Modified by PSU Reprap Collective OpenX arm PSU 1off.jpg
Extruder
File:OHM Extruder.zip
1 HerringboneDrivenGear Alternative part by Rhys-jones HerringboneDrivenGear.JPG
1 HerringboneDriveGear Alternative part by Rhys-jones HerringboneDriveGear.JPG
1 Gregs_accessible_wades_v6 Alternative extruder by Greg-Frost Gregs accessible wades v6.JPG
Electronics Mounting
2-5 prusa_modified_endstop_holder_2-5off Prusa opto holder modified to have a thicker end No picture yet
3 electronics_board_mount_opt Created by RUG member SethG. Optional Electronics board mount.JPG
Quantity of Materials Needed by Subsystem
Part Name Frame Z-Axis Open Y-Axis Open X-Axis X-Carriage Extruder Total
M3 Cap Screw 20mm 4 - - 8 - 4 16
M3 Cap Screw 25mm 1 8 - 9 2 - 24
M3 Nut - - - - - - -
M3 Nylok 1 8 - 9 2 - 24
M3 Washer 6 16 - 26 3 4 63
M4 Cap Screw 16mm - 4 - 4 - - 8
M4 Cap Screw 20mm - 1 12 9 14 - 36
M4 Cap Screw 40 mm 12 - 8 28 - 2 44
M4 Dome Screw 30 mm - - - - - 3 3
M4 Nut - - 2 12 - 2 12
M4 Nylok 8 1 10 31 14 1 57
M4 Washer 28 6 38 102 34 14 202
M8 Nut 72 8 4 4 - - 88
M8 Washer 72 8 4 - - 4 88
3/16" Fender Washer 8 - - 8 - - 16
Bearing 8x22x7 mm - - - - - 3 3
Bearing 4x13x5 mm 4 - 12 4 10 - 30
