Open Hybrid Mendel
Release status: Working
Description | A hybrid between Prusa and Mendel models using several improved pieces from the community
License | GPL
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Overview
The Open Hybrid Mendel (or OHM) is a project of the Penn State Reprap User Group. It is a Mendel design, which uses both standard Sells Mendel parts, a Prusa Z drive, various redesigns from the community at large, and a number of small design improvements developed in our PSU Reprap class, in the spirit of open source design (see the wiki page on closed innovation for a good comparison of methodologies ) It is so named due to this hybridization of designs, and obtains the 'Open' designation from the OpenX and OpenY axes it uses. The prototype for the OHM design was Etherdais_Unit_One
Expanding into the realm of the biological, the OHM is the basis for a Mendel-based PCR system, currently designated the RepRap Mullis.
Any Mendel can be broken down into 6 sub-systems, which are somewhat interchangable between designs:
Frame - The OHM uses Camiel's thin shelled Vertex design, maintaining vertices similar to the Sells design, but using less filament
Y-axis - The OHM uses a modified OpenY, with an optoless belt harness, and a second 90/180 arm in place of the 90/270 arm. This demands two additional bearings, but we find the result is more stable, while retaining the benefits of the OpenY. A modified Sells y-motor bracket is used, which avoids printing an unused endstop holder from the original Sells design. The original Sells y-bar clamps seem well suited for mounting y-axis opto-endstops.
Z-drive system - The OHM uses a Prusa, double motor design for driving the Z axis, avoiding the large prints and continuous belt of the Sells Z-drive design. We still use Sells bar clamps to clamp the smooth rod to the Z-motor mounts, as they are compatable, and look sharp together.
X-Z assembly - Currently, the OHM build uses a standard Sells X-Z assembly, as described here in Mendel_X-axis.
Carriage - The OpenX carriage is the design of choice currently. This, and the OpenY
Extruder - We are in the process of finding a design which is more compatable with the TechZone steel hot tips we've been using recently, though the current design is a hack of herringbone extruder gears, and GregFrost's hinged wades extruder.
Parts
Quantity | File-Name | Comments | Diagram |
4 | bed-spring_4off | ||
6 | Camiel_frame_vertex_7off | Alternative part by Camiel | |
2 | z-prusa-motor-mount | ||
4 | prusa_bar-clamp_2off | ||
2 | Pla_coupling_nophead | Alternative part by Nophead | |
2 | X-180-z-bearing-plate_2off | ||
2 | X-360-z-bearing-plate_2off | ||
2 | X-360-z-bearing-plate-mirror_2off | ||
1 | Xaxis-motor-bracket_1off | Alternative part by Rhys-jones | |
6 | X-bar-clamp-m3_6off | ||
4 | X-bar-clamp-m4_4off | ||
1 | X-end-bracket_1off | ||
4 | X-vert-drive-nut-trap_4off | ||
2 | X-vert-drive-side-plate-180-end_2off | ||
2 | X-vert-drive-side-plate-360-end_2off_rebuild | ||
8 | Y-bar-clamp_4off | ||
1 | Y-idler-bracket_1off | ||
1 | Y-motor-bracket_1off_mod3-15 | Modified by PSU Reprap Collective | |
2 | Z-bar-top-clamp_2off | ||
1 | HerringboneDrivenGear | Alternative part by Rhys-jones | |
1 | HerringboneDriveGear | Alternative part by Rhys-jones | |
1 | Gregs_accessible_wades_v6 | Alternative extruder by Greg-Frost | |
1 | Gregs_accessible_wades_idler | ||
1 | OpenX_Carriage | Open X by Buback | |
1 | OpenX_Undercarriage_Bracket | Open X by Buback | |
1 | OpenX_Arm | Open X by Buback | |
1 | 8mm_Belt_Harness_1off | Open Y by Buback, modified by PSU Reprap Collective | |
2 | 8mm_Crossbar_Mount_2off | Open Y by Buback | |
2 | Arm_90_-_180 | Open Y by Buback | |
1 | Arm_210 | Open Y by Buback | |
1 | OpenY_Undercarriage_Bracket | Open Y by Buback | |
3 | Electronics_board_mount | Created by RUG member SethG | |
2 | X-axis-side-plate-nut-jig_2off | ||
2 | Z-leadscrew-base-bar-clamp_2off | ||
2-4 | modified endstop holder | Prusa opto holder modified to have a thicker end | No picture yet |
