Ohm/How to build an OHM
- 1 Introduction
- 2 Mechanical Construction
- 2.1 Frame
- 2.2 Z Drive System
- 2.3 X-Z Assembly
- 2.4 OpenY Axis
- 2.5 Extruder
- 2.6 Spool
- 3 Electrical Construction
Introduction
The Open Hybrid Mendel (OHM) has several advantages over the generic Mendel model. Mainly, it is more flexible. The extruder carriage and printing board are designed to easily pop off the machine without unscrewing any parts.
All STL files mentioned in this article are referring to, and can be downloaded from the OHM Parts section.
Frame
Frame Triangles
Parts
Total # of assemblies: 2
Name | Qty/assembly | Total Qty | Type |
Camiel_frame_vertex_6off | 3 | 6 | RP |
prusa_bar-clamp_4off | 1 | 2 | RP |
m8-nut | 14 | 28 | Fastener |
m8-washer | 14 | 28 | Fastener |
m8-threaded rod D | 3 | 6 | Threaded Rod |
Reprapped parts
Assembly
(The above list of parts is accurate. The assembly should reflect this) (Assembly guide. Delete this note when section is finished)
Tips
When you assemble the frame triangles, it will be easier if you assemble the two top vertices the last. To insert the rod into the vertices, you can tie two nuts tight together and then use a wrench to screw in the rod.
Connecting the Triangles
Parts
Total # of assemblies: 1
y-motor-bracket_1off_mod3-15 | 1 | 1 | RP |
y-idler-bracket_1off | 1 | 1 | RP |
m4x40-cap | 4 | 4 | Fastener |
m4-washer | 12 | 12 | Fastener |
m4-large OD washer | 8 | 8 | Fastener |
m4-nylock | 4 | 4 | Fastener |
m8-nut | 44 | 44 | Fastener |
m8-washer | 44 | 44 | Fastener |
m8-threaded rod E | 4 | 4 | Threaded Rod |
m8-threaded rod F | 3 | 3 | Threaded Rod |
Reprapped parts
Assembly
(The above list of parts is accurate. The assembly should reflect this) It is a good idea to assemble the pulley bearings before putting the motor mount and idler on (Assembly guide. Delete this note when section is finished)
Tips
It is easier to assemble the triangles, if connected both ends first, and then connect the bottom two rods.(Extra tips to help assemble. Delete this note when section is finished)
Z Drive System
Z-Axis Motor Mounts
Parts
Name | Qty/assembly | Total Qty | Type | |
z-prusa-motor-mount_2off | 1 | 2 | RP | |
z-bar-top-clamp_2off | 1 | 2 | RP | |
m3x10-cap | 4 | 8 | Fastener | |
m3-washer | 4 | 8 | Fastener | |
m8-nut | 2 | 4 | Fastener | |
m8-washer | 4 | 8 | Fastener | |
Stepper Motor | 1 | 2 | Motor |
Reprapped parts
Assembly
(The above list of parts is accurate. The assembly should reflect this) Leave the smooth rod clamps loose and save the threaded rod for "connecting the x and z axis" section, since the x assembly needs to slide on before these are attached. (Assembly guide. Delete this note when section is finished)
Tips
Assembly of Z-axis can be started from sticking everything together in one rod. Settling all the parts (including the two top vertices for the frame triangle) on Z axis and connecting them with rod at one side, then insert the rod for the other side.
X-Z Assembly
X-Axis Idler Bracket
Parts
x-end-bracket_1off | 1 | 1 | RP |
x-180-z-bearing-plate_2off | 2 | 2 | RP |
x-bar-clamp-m3_4off | 2 | 2 | RP |
m3x20-cap | 4 | 4 | Fastener |
m3-nylock | 4 | 4 | Fastener |
m3-washer | 8 | 8 | Fastener |
m4x16-cap | 2 | 2 | Fastener |
m4x40-cap | 6 | 6 | Fastener |
m4-nylock | 8 | 8 | Fastener |
m4-washer | 22 | 22 | Fastener |
m4-large OD washer | 4 | 4 | Fastener |
bearing-4x13x5 | 6 | 6 | Bearing |
Reprapped parts
Assembly
Tips
X-Axis Motor Mount
Parts
xaxis-motor-bracket_1off | 1 | 1 | RP |
PSU_x_vert_sideplate_360_end_2off | 2 | 2 | RP |
x-360-z-bearing-plate_2off | 2 | 2 | RP |
x-360-z-bearing-plate-mirror_2off | 2 | 2 | RP |
pulley_w-set_screw_2off | 1 | 1 | RP |
m2x5 set screw? | 1 | 1 | Fastener |
m2 set screw nut? | 1 | 1 | Fastener |
m3x20-cap | 8 | 8 | Fastener |
m3-washer | 12 | 12 | Fastener |
m4x16-cap | 6 | 6 | Fastener |
m4-nylock | 10 | 10 | Fastener |
m4-washer | 28 | 28 | Fastener |
bearing-4x13x5 | 8 | 8 | Bearing |
Stepper Motor | 1 | 1 | Motor |
Reprapped parts
Assembly
Tips
X-Axis Vertical Bearing
See Mendel X-Axis for further information.
Parts
x-axis-side-plate-nut-jig_2off | 1 | 2 | RP |
x-bar-clamp-m4_4off | 2 | 4 | RP |
x-vert-drive-nut-trap_4off | 2 | 4 | RP |
x-vert-drive-side-plate_4off | 2 | 4 | RP |
m4-nut | 4 | 8 | Fastener |
m4-nylock | 4 | 8 | Fastener |
m4-washer | 16 | 32 | Fastener |
m4x40-cap | 8 | 16 | Fastener |
m8-nut | 1 | 2 | Fastener |
Reprapped parts
Assembly
First, assemble the x-vert-drive-nut-trap_4off. To do this, you need a lighter, four m4 nuts and a m4x40-cap. Place an m4 Nut on the end of the m4x40-cap and heat with the lighter. Caution: Do not heat for too long or the m4x40-cap will become very hot.
Push the heated nut into one of the hexagonal holes in the x-vert-drive-nut-trap_4off. Repeat for all four nuts.
Screw x-vert-drive-side-plate-180-end_2off and x-bar-clamp-m4_4offtogether using m4x40-cap and washers. Do not screw them all the way in.
Screw x-vert-drive-nut-trap_4off into x-vert-drive-side-plate-180-end_2off using a diagonal pattern. Remember to use washers. Do not screw them all the way in.
Repeat previous steps to create other half. Make sure that you place the screws diagonally in a way that they do not interact with the other screws.
Place the x-vert-drive-nut-trap_4off in between the bottom half of the two sides and line up screws. Screw in the M4 screws until they sit in the nuts and are firmly in place. This could take some adjustment.
Place an M8 nut in between the two trap sides. Then screw the upper screw together. Tighten all screws in steps.
Tips
- In some cases, though it is not necessary, it may help if you drill out the holes before assembling.
- To help align the screw holes, place on screw in, clamp the parts, and drill the rest of the holes.
Assembling the X-Axis
Parts
m8-smooth rod A | 2 | 2 | Smooth Rod |
Assembly
Tips
Connecting the X-Axis to the Z-Axis
Parts
pla_coupling_nophead-1piece_4off | 2 | 4 | RP |
m3x25-cap | 4 | 8 | Fastener |
m3-nylock | 4 | 8 | Fastener |
m3-washer | 8 | 16 | Fastener |
m8-washer | 2 | 4 | Fastener |
m8-threaded rod G | 1 | 2 | Threaded Rod |
m8-smooth rod B | 1 | 2 | Smooth Rod |
Reprapped parts
Assembly
Tips
Z and X axes Endstops
Parts
endstop-holder_microsw-1_small enstops_3off | 1 | 2 | RP |
m4x20-cap | 1 | 2 | Fastener |
m4-nylock | 1 | 2 | Fastener |
m4-washer | 2 | 4 | Fastener |
Reprapped parts
Assembly
Tips
OpenY Axis
Y-axis Guide Bars
Parts
y-bar-clamp_8off | 4 | 8 | RP | |
m4x40-cap | 4 | 8 | Fastener | |
m4-nylock | 4 | 2 | Fastener | |
m4-washer | 8 | 16 | Fastener | |
m8-smooth rod C | 1 | 2 | Smooth Rod |
Reprapped parts
Assembly
Tips
OpenY Assembly
Parts
OpenY_Arm 90 - 180_2off | 2 | 2 | RP |
OpenY_arm45 | 1 | 1 | RP |
OpenY_8mm Crossbar Mount_2off | 2 | 2 | RP |
OpenY_8mm Belt Harness_1off | 1 | 1 | RP |
OpenXY_bracket | 2 | 2 | RP |
m4x20-cap | 12 | 12 | Fastener |
m4-washer | 26 | 26 | Fastener |
m8-nut | 4 | 4 | Fastener |
m8-washer | 2 | 2 | Fastener |
m8-threaded rod H | 1 | 1 | Threaded Rod |
bearing-4x13x5 | 12 | 12 | Bearing |
Reprapped parts
Assembly
Tips
Print Bed
Parts
bed-spring_4off | 4 | 4 | RP |
m4-washer | 4 | 4 | Fastener |
Reprapped parts
(Parts needed for assembly. Delete this note when section is finished)
Assembly
Tips
Motors, Belts and Endstops
Parts
endstop-holder_microsw-1_small enstops_3off | 1 | 1 | RP |
m3x25-cap | 4 | 4 | Fastener |
m3-washer | 4 | 4 | Fastener |
Reprapped parts
Assembly
Tips
Extruder
Carriage
Parts
OpenX_Carriage_1off | 1 | 1 | RP |
OpenX_arm_PSU_1off | 1 | 1 | RP |
m4x20-cap | 14 | 14 | Fastener |
m4-nylock | 14 | 14 | Fastener |
m4-washer | 36 | 36 | Fastener |
bearing-4x13x5 | 10 | 10 | Bearing |
Reprapped parts
Assembly
Tips
Motor Mount
Parts
Gregs_accessible_wades_v6 | 1 | 1 | RP |
Gregs_accessible_wades_idler | 1 | 1 | RP |
HerringboneDrivenGear | 1 | 1 | RP |
HerringboneDriveGear | 1 | 1 | RP |
m4x40-cap | 5 | 5 | Fastener |
m4-nut | 2 | 2 | Fastener |
m4-nylok | 3 | 3 | Fastener |
m4-washer | 8 | 8 | Fastener |
m8-hobbed bolt | 1 | 1 | Fastener |
m8-nylok | 1 | 1 | Fastener |
m8-washer | 1 | 1 | Fastener |
m8-smooth rod (stub) | 1 | 1 | Smooth Rod |
bearing-8x22x7 | 3 | 3 | Bearing |
stepper motor | 1 | 1 | Stepper Motor |
Reprapped parts
Assembly
(Assembly guide. Delete this note when section is finished) This unfinished part includes the main driven gear, idler and lastly the main section.
Tips
Hot Tip
Parts
metal base plate | 1 | 1 | Misc. Hardware |
metal exruder shaft | 1 | 1 | Misc. Hardware |
brass tip | 1 | 1 | Misc. Hardware |
heat sink | 1 | 1 | Misc. Hardware |
fireplace cement? | 1 | 1 | Misc. Hardware |
m3x25-countersink | 1 | 1 | Fastener |
nichrome wire | 1 | 1 | Wire |
thermocouple | 1 | 1 | Wire |
(These parts need to be more specific with details) (Parts needed for assembly. Delete this note when section is finished)
Assembly
Tips
When you feel like the tip is stuck, heat it up, and then use another piece of filament to quickly suck out the part that were stuck in the tip. (Extra tips to help assemble. Delete this note when section is finished)
Spool
Spool Assembly
Parts
Assembly
Tips
Spool Mount
Parts
Assembly
Tips
RAMPS
Motherboard
Ramps_Mount | 1 | 1 | RP |
RAMPS 1.4 | 1 | 1 | PCB |
twist-tie (or zip-tie) | 4 | 4 | Fastener |
Reprapped parts & motherboard
Connecting Power
Parts
AC Computer Power Adapter | 1 | 1 | Power Supply |
(Include size on power supply)
