North90's hot-end
This hot-end is designed to be build with simple tools and without the need for great engineering skills.
About the design
WHY another design? The complexity of most hot-end designs (lathe needed) and the use of hard to obtain and expensive materials (Peek) make it hard for the average person to build their own hot-end. This design is great for everyone who wants to build a hot-end but who doesn't have access to a lathe, cnc-machine and drill-press.
Thermal design
Each hot-end consists out of three main parts:
- hot end where the plastic is melting (usually brass tube + nozzle)
- insulator which keeps the heat away from the extruder (usually PTFE(=Teflon) rod)
- cold end the cool part of the hot-end which mounts to the extruder (can be any kind of material)
This hot-end uses stainless steel as an insulator. Stainless steel conducts heat less easily than normal steel, brass or aluminum, but much better than PTFE.
MATERIAL | THERMAL CONDUCTIVITY W/(M*K) | NOTES |
PTFE | 0.25 | will deform when hot: can't be used as structural part |
PEEK | ~0.25 | expensive+hard to obtain |
normal steel | 45 | |
stainless steel | 18 | |
brass | 120 | |
aluminium | 220 | |
dry wood | 0.05-0.12 |
from http://en.wikipedia.org/wiki/List_of_thermal_conductivities
The thermal conductivity of stainless steel is about a 100 times larger than that of PEEK or PTFE. To have a similar insulation as a PTFE insulator the cross-section of the insulator has to be a 100 times smaller.
A normal 16mm PTFE insulator (with a 3mm hole) has a cross-sectional surface area of 194mm2. The heat transfer for a PTFE insulator that is 25mm long at a temperature difference of 200C is 0.38W.
The stainless steel insulator of this hot-end is 6.35mm outside and an inside diameter of 5.7mm has a cross-sectional area of 6.14mm2. The heat transfer for this insulator (25mm long and 200C) is about 1.1W. This is almost 3 times as high as the PTFE insulator of the same length.
The extra heat transferred through the stainless steel insulator has to be dissipated with a heat sink.
Tools and supplies
- Drill + drill bits
- Vice
- Tap and die set: M3 tap, M6 tap and die
- Tube-cutter (or fine metal saw)
- File(s)
- Cutting oil (olive oil works great)
- Stainless steel tube with an outide diameter of 1/4" (6.35mm), inner diameter is not important
- PTFE tube 1/8"(3.18mm) id and 1/4" (6.35mm) outer diameter
- M6 brass bolt (25mm long) or welding nozzle (0.6mm)
- piece of aluminium 5-6mm thick
How to build the stainless steel insulator
Cut a piece of stainless steel tube of about 55mm long (about 10mm longer than the insulator you are making). An easy and very clean way to cut the tube is to use a tube-cutter. Stainless steel is very hard so it will take a while to get through. Use (olive) oil to ease the cutting Personally i put the tube in the drill and let the drill do the hard work.
Next step is to drill the inside of the stainless steel end up with an inner diameter of 5.5-5.6mm.
- Put the stainless steel tube in the drill and the drill-bit in a vice.
- Only reduce the inner diameter of 45mm of the tube, leave the last 10mm the original size. The tube gets to fragile to work with when the whole tube is drilled out. The last 10mm is cut off at the end.
- Drill the tube out in small steps: if the inner diameter is 4mm use a 4.5mm drill to start with followed by a 5mm and a 5.5mm drill.
- Use loads of oil (olive oil works great) to save your drill bits and make cleaner cuts.
- Go slow, try to get long pieces of metal coming out of the drill instead of small pieces.
When the tube is drilled out to 5.5mm inner diameter, one end is threaded with m6 thread, to be able to attach the hot end. Put the tube in the vice and use a M6 tap to tap thread in the drilled out end of the insulator. Use plenty of oil and go half a turn in, quarter turn out, half a turn in, quarter turn out. etc. Tap the tube as far as you want to go (when you tap it further the inner diameter of the tube is reduced over a longer length making it a better insulator, but the strenght of the tube is reduced at the same time). 10mm deep will work.
Now cut of the part of the tube that you didn't drill out, you probably know by now why to keep it longer till this point ;)
The stainless steel tube will be lined on the inside with a PTFE tube to reduce friction. The 1/4(6.35mm) outer diameter PTFE won't fit in the 5.5mm inside diameter insulator. To make this fit the PTFE tube will be reduced in diameter with a M6 die.
