North90's hot-end
Revision as of 20:14, 13 November 2011 by North90ty (talk | contribs)
This hot-end is designed to be build with simple tools and without the need for great engineering skills.
About the design
WHY another design? The complexity of most hot-end designs (lathe needed) and the use of hard to obtain and expensive materials (Peek) make it hard for the average person to build their own hot-end. This design is great for everyone who wants to build a hot-end but who doesn't have access to a lathe, cnc-machine and drill-press.
Thermal design
Each hot-end consists out of three main parts:
  • hot end where the plastic is melting (usually brass tube + nozzle)
  • insulator which keeps the heat away from the extruder (usually PTFE(=Teflon) rod)
  • cold end the cool part of the hot-end which mounts to the extruder (can be any kind of material)
This hot-end uses stainless steel as an insulator. Stainless steel conducts heat less easily than normal steel, brass or aluminum, but much better than PTFE.
MATERIAL THERMAL CONDUCTIVITY <math>W*M^-1*K^-1</math> NOTES
PTFE 0.25 will deform when hot: can't be used as structural part
PEEK ~0.25 expensive+hard to obtain
normal steel 45
stainless steel 18
brass 120
aluminium 220
from http://en.wikipedia.org/wiki/List_of_thermal_conductivities
Tools and supplies
