Neutron
Revision as of 04:15, 1 March 2017 by Atom3dp (talk | contribs) (Pictures in a Table)
Neutron
Delta robot 3D printer with extrusion frame.
[http://]
Neutron is a parametric delta robot 3D printer, built in 2016 by Atom3dp in Taipei, Taiwan.
Specification
  • Bounding volume: 320 x 330 x 540mm
  • Assembled weight: 3.75kg
  • Max print volume: Φ140 x 200mm
  • Accuracy: 0.1 ~ 0.3mm
  • Printed Parts: 8
  • Speed: 20mm/s perimeter, 30mm/s infill
Pictures in a gallery
If you have a real lot of pictures and not more than a few words of text for them, using a gallery is a good idea:
Pictures in a Table
As an intermediate between the above two, you can use a table to focus on a number of pictures:
If you add a "thumb", you can still make the picture large, but also add some descriptive text.
"center" makes sure pictures align by their centers in such a picture-table.
On how to do all this, see source code of this section.
Text
You want text, of course. Pictures should be understood. See how large amounts look like:
Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text.
Related Projects
Check this page Proton and you will find another RepRap printer designed by ATOM as well.
Documentation
Photos and Drawings
Huge Image
Really big example images with lots of descriptive text are a fun part of documentation.
Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text. Text text text text text text text text text text text text text text text text.
May contain scaffolding.
This page may contain "scaffolding" - mediawiki text from the Example page that may not need to be there. It may help to delete the parts that you don't need. (more details)
<videoflash type="youtube">l8m3tsg24e8</videoflash>
Links
