NEMA 17 Stepper motor
A NEMA 17 stepper motor is a stepper motor with a 1.7 x 1.7 inch (43.2 x 43.2 mm) faceplate. The NEMA 17 is larger and generally heavier than for example a NEMA 14, but this also means it has more room to put a higher torque. However, its size is not an indication of its power.
Suppliers
Below is a non-exhaustive list of possible motors and suppliers.
You are welcome to add information on a stepper motor/vendor you encounter, but please add only steppers which were tested to actually work on some printer.
Manufacturer | Model | Holding torque | Rated voltage | Shaft | Step angle | Motor length | Additional notes | Vendor (shipping location) |
Kysan | 42BYGH4803 (SKU 1124030) | 54.0 N·cm | 4.2 V | Ø 5 mm single | 1.8° | 48 mm | Kysan (CN) XYZPrinters (NL) | |
Kysan | 42BYGH4803-DC (SKU 1124090) | 54.0 N·cm | 4.2 V | Ø 5 mm single | 1.8° | 48 mm | Same as 42BYGH4803, but with flat on the shaft. | 3D Maker World (US) Ultibots (US) |
RobotDigg RobotDigg | 17HS1011-20B | 28.0 N·cm | 4.8 V | Ø 5 mm single | 1.8° | 34 mm | Also with flat on the shaft available. | RobotDigg (CN) |
RobotDigg RobotDigg | 17HS3001-20B | 40.0 N·cm | 2.0 V | Ø 5 mm single | 1.8° | 40 mm | Also with flat on the shaft available. | RobotDigg (CN) |
Longs Motor | 17HS4417 | 40.0 N·cm | 2.6 V | Ø 5 mm single | 1.8° | 40 mm | 2PrintBeta (DE) | |
Mercury Motor | SM-42BYG011-25 | 23.0 N·cm | 12 V | Ø 5 mm single | 1.8° | 34 mm | Rated voltage higher than ideal for running on 12 V current chopping drivers. | Abra (US & CA) Akizuki Denshi Tsusho (JP) |
Unknown | 17HD2038E | 45.0 N·cm | Ø 5 mm single | 1.8° | EckerTech (CA) | |||
Unknown | 17HS19-1684S | 55 N·cm | 2.8 V | Ø 5 mm single | 1.8° | 47 mm | Custom model, includes 100cm leads and molex plug. | Reprap Austria (AT) |
SOYO | SY42STH47-1206A | 31.1 N·cm | 4.0 V | Ø 5 mm single | 1.8° | 40 mm | Pololu (US) | |
SOYO | SY42STH47-1504A | 55.0 N·cm | 2.8 V | Ø 5 mm | 1.8° | 47 mm | Flat on the shaft. | LulzBot (US) |
SOYO | SY42STH47-1684A | 43.1 N·cm | 2.8 V | Ø 5 mm single | 1.8° | 48 mm | Some vendors have longer than standard cables. | 3Distributed fabberworld.com (CH) |
SOYO | SY42STH47-1684B | 43.1 N·cm | 2.8 V | Ø 5 mm double | 1.8° | 48 mm | Same as SY42STH47-1684A, but double shaft. | LDO Motors (CN) Mendel-Parts (NL) |
Trinamic | QSH4218-51-049 | 49 N·cm | Ø 5 mm | 1.8° | 47 mm | Tested on MakerBot Cupcake CNC | Reichelt (DE) | |
Wantai | 42BYGH W811 | 47.0 N·cm | 3.1 V | Ø 5 mm | 1.8° | 48 mm | Variant with flat on the shaft available. | Cubic-Print (DE) electronic-things (DE) |
Wantai | Custom for QU-BD | 49.0 N·cm | 3.6 V | Ø 5 mm single | 1.8° | 48 mm | QU-BD (US) | |
Unknown | Unknown | 32.4 N·cm | Ø 5 mm single | 0.9° | 43 mm | MatterHackers (US) |
These were listed as "not tested" earlier, so your mileage may vary:
Lin Engineering | 417-11-48-02 | 7.0 N·cm | Ø 5 mm | 1.8° | 28 mm | May be too weak. | Alltronics (US) | |
Lin Engineering | 4018X-07-04 | 11.0 N·cm | Ø 5 mm | 1.8° | 26 mm | May be too weak. | ||
Lin Engineering | 4118L-25P-07R0 | 48.5 N·cm | Ø 5 mm | 1.8° | 48 mm | Alltronics (US) | ||
Nidec Servo | KH4248-B95101 | 48 N·cm | Ø 5 mm single | 1.8° | 48 mm | Mechapro (DE) | ||
Oriental Motors | PX243M-03AA | 20.0 N·cm | single | 0.9° | 42 mm | Interinar Electronics LLC (US) | ||
Oriental Motors | PX243M-01AA | 15.0 N·cm | Ø 5 mm single | 0.9° | 33 mm | Not strong enough for direct drive extruder. Uses Imperial #4-40 TPI mounting holes instead of M3 metric. (Web page says no longer available; suggests RepRap builders use PX243M-03AA instead.) |
Oriental Motors | PKE245DA-L | 1555.0 N·cm | Ø 5 mm single | 1.8° | 47 mm | Made in Japan. | Oriental motor (JP/US) | |
Rugao Xinhe | 17H185H-04A | 43.8 N·cm | 2.8 V | Ø 5 mm single | 1.8° | 42 mm | AusXmods (AU) | |
Rugao Xinhe | 17H185H-04B | 43.8 N·cm | 2.8 V | Ø 5 mm double | 1.8° | 42 mm | AusXmods (AU) | |
SANYO DENKI (Japan) | KH42KM2R001 | 45 N·cm | Ø 5 mm | |||||
Custom | 42BYGH404 | 31 N·cm | Ø 5 mm single | 1.8° | 49 mm | MPJA (US) |
Shinano Kenshi
If you have a Shinano Kenshi motor in your hands, you can decode the part number written on it with the SKC Stepping Motor Part Number decoder at Shinano Kenshi: "Stepping Motor Operation & Theory".
Lin Engineering
Lin Engineering is one of the few manufacturers that make stepper motors in the US. If you have one of their motors in your hands, you can decode the part number written on it with the "Lin part number system" decoder on p.1 and p.2 of the Lin Engineering Catalog. Page 9 of the Lin Engineering catalog explains the part numbering system for all Lin Engineering stepper motors.
4118S-62-07
This is an awesome little NEMA 17 stepper motor. It is the primary motor used on the Cupcake CNC. It has good torque and a small size.
- 200 steps per revolution (1.8 deg/step)
- 2.5 A/phase
- Phase resistance: 0.6 Ω
- Phase inductance: 0.93 mH
- Holding torque: 3240 g·cm (~31 N·cm)
- Shaft diameter: 0.190" (4.83 mm)
- Shaft length: 0.50" (12.7 mm)
- Motor depth: 1.34" (34 mm)
- Datasheet
Name | Pololu pin | Color |
A | 2B | Red |
B | 2A | Blue |
C | 1A | Green |
D | 1B | Black |
