NEMA 17 Stepper motor
A NEMA 17 stepper motor is a stepper motor with a 1.7 x 1.7 inch (43.2 x 43.2 mm) faceplate. The NEMA 17 is larger and generally heavier than for example a NEMA 14, but this also means it has more room to put a higher torque. However, its size is not an indication of its power.
Suppliers
Below is a non-exhaustive list of possible motors and suppliers.
Tested
You are welcome to add information on a stepper motor/vendor you encounter, but please add only steppers which were tested to actually work on some printer.
Manufacturer | Model | Holding torque | Rated voltage | Shaft | Stepping angle | Motor length | Additional notes | Vendor (shipping location) |
Kysan | 42BYGH4803 (SKU 1124030) | 54.0 N·cm | 4.2 V | Ø 5 mm single | 1.8° | 48 mm | Kysan (CN) XYZPrinters (NL) | |
Kysan | 42BYGH4803-DC (SKU 1124090) | 54.0 N·cm | 4.2 V | Ø 5 mm single | 1.8° | 48 mm | Same as 42BYGH4803, but with flat on the shaft. | 3D Maker World (US) Ultibots (US) |
Rebranded Longs Motor ? | 17HS1011-20B | 28.0 N·cm | 4.8 V | Ø 5 mm single | 1.8° | 34 mm | Also with flat on the shaft available. | RobotDigg (CN) |
Rebranded Longs Motor ? | 17HS3001-20B | 40.0 N·cm | 2.0 V | Ø 5 mm single | 1.8° | 40 mm | Also with flat on the shaft available. | RobotDigg (CN) |
Longs Motor | 17HS4417 | 40.0 N·cm | 2.6 V | Ø 5 mm single | 1.8° | 40 mm | 2PrintBeta (DE) | |
Mercury Motor | SM-42BYG011-25 | 23.0 N·cm | 12 V | Ø 5 mm single | 1.8° | 34 mm | Rated voltage higher than ideal for running on 12 V current chopping drivers. | Abra (US & CA) Akizuki Denshi Tsusho (JP) |
RB Step Motor | 17HD2038E | 45.0 N·cm | Ø 5 mm single | 1.8° | EckerTech (CA) | |||
Reprap Austria | 17HS19-1684S | 55 N·cm | 2.8 V | Ø 5 mm single | 1.8° | 47 mm | Custom model, includes 100cm leads and molex plug. | Reprap Austria (AT) |
SOYO | SY42STH47-1206A | 31.1 N·cm | 4.0 V | Ø 5 mm single | 1.8° | 40 mm | Pololu (US) | |
SOYO | SY42STH47-1504A | 55.0 N·cm | 2.8 V | Ø 5 mm | 1.8° | 47 mm | Flat on the shaft. | LulzBot (US) |
SOYO | SY42STH47-1684A | 43.1 N·cm | 2.8 V | Ø 5 mm single | 1.8° | 48 mm | Some vendors have longer than standard cables. | 3Distributed fabberworld.com (CH) |
SOYO | SY42STH47-1684B | 43.1 N·cm | 2.8 V | Ø 5 mm double | 1.8° | 48 mm | Same as SY42STH47-1684A, but double shaft. | LDO Motors (CN) Mendel-Parts (NL) |
Trinamic | QSH4218-51-049 | 49 N·cm | Ø 5 mm | 1.8° | 47 mm | Tested on MakerBot Cupcake CNC | Reichelt (DE) | |
Wantai | 42BYGH W811 | 47.0 N·cm | 3.1 V | Ø 5 mm | 1.8° | 48 mm | Variant with flat on the shaft available. | Cubic-Print (DE) electronic-things (DE) |
Wantai | Custom for QU-BD | 49.0 N·cm | 3.6 V | Ø 5 mm single | 1.8° | 48 mm | QU-BD (US) | |
Custom | Unknown | 32.4 N·cm | Ø 5 mm single | 0.9° | 43 mm | MatterHackers (US) |
Not tested
Lin Engineering | 417-11-48-02 | 7.0 N·cm | Ø 5 mm | 1.8° | 28 mm | May be too weak. | Alltronics (US) | |
Lin Engineering | 4018X-07-04 | 11.0 N·cm | Ø 5 mm | 1.8° | 26 mm | May be too weak. | ||
Lin Engineering | 4118L-25P-07R0 | 48.5 N·cm | Ø 5 mm | 1.8° | 48 mm | Alltronics (US) | ||
Nidec Servo | KH4248-B95101 | 48 N·cm | Ø 5 mm single | 1.8° | 48 mm | Mechapro (DE) | ||
Oriental Motors | PX243M-03AA | 20.0 N·cm | single | 0.9° | 42 mm | Interinar Electronics LLC (US) | ||
Oriental Motors | PX243M-01AA | 15.0 N·cm | Ø 5 mm single | 0.9° | 33 mm | Not strong enough for direct drive extruder. Uses Imperial #4-40 TPI mounting holes instead of M3 metric. (Web page says no longer available; suggests RepRap builders use PX243M-03AA instead.) |
Oriental Motors | PKE245DA-L | 1555.0 N·cm | Ø 5 mm single | 1.8° | 47 mm | Made in Japan. | Oriental motor (JP/US) | |
Rugao Xinhe | 17H185H-04A | 43.8 N·cm | 2.8 V | Ø 5 mm single | 1.8° | 42 mm | AusXmods (AU) | |
Rugao Xinhe | 17H185H-04B | 43.8 N·cm | 2.8 V | Ø 5 mm double | 1.8° | 42 mm | AusXmods (AU) | |
SANYO DENKI (Japan) | KH42KM2R001 | 45 N·cm | Ø 5 mm | |||||
Custom | 42BYGH404 | 31 N·cm | Ø 5 mm single | 1.8° | 49 mm | MPJA (US) |
Shinano Kenshi
If you have a Shinano Kenshi motor in your hands, you can decode the part number written on it with the SKC Stepping Motor Part Number decoder at Shinano Kenshi: "Stepping Motor Operation & Theory".
RoboDigg
According to the increasing request of building 3D Printers, RobotDigg customized produce two models NEMA 17 Stepper Motor which are very suitable for 3D printers like Makerbot and Reprap to utilize the NEMA 17 stepper motors, with a competitive price for small bulk order. According to the supplier, these two stepper motors are particularly manufactured for 3D printers in a very compact size with long lead wires or plug for prelong request.
17HS1011-20B
- 200 steps per revolution (1.8°/step)
- 2 Phase Bipolar, 4 Wires
- Rated Voltage 4.83V DC
- Rated Current 0.84A
- Phase Resistance: 5.75 Ω ± 10% (20º C)
- Phase inductance: 9.3 mH ± 20% (1kHz 1 V rms)
- Holding torque: 0.28 N·m Min.
- Shaft diameter: 5mm / 0.188" (3/16")
- Shaft length: 20mm
- Motor depth: 34mm
- Available at: RoboDigg
17HS3001-20B
- Rated Voltage 2V DC
- Rated Current 1.2A
- Phase Resistance: 1.7 Ω ± 10% (20º C)
- Phase inductance: 4.5 mH ± 20% (1kHz 1 V rms)
- Holding torque: 0.4 N·m Min.
- Motor depth: 40mm
LDO Motors
NEMA 17 (42MM) size hybrid stepper motor with followed main performance, widely used in 3D printer / CNC industrial.
42STH47-1684A
- 200 steps per revolution (1.8 deg/step)
- 1.68 A/phase
- Phase resistance: 1.65 Ω
- Phase inductance: 2.8 mH
- Holding torque: 5.0 Kg·cm (50N·cm)
- Shaft diameter: 5 mm or 6.35mm
- Shaft length: 24 mm or customize
- Motor body length: 48mm
- Datasheet
- Available at: LDO Motors
Lin Engineering
Lin Engineering is one of the few manufacturers that make stepper motors in the US. If you have one of their motors in your hands, you can decode the part number written on it with the "Lin part number system" decoder on p.1 and p.2 of the Lin Engineering Catalog. Page 9 of the Lin Engineering catalog explains the part numbering system for all Lin Engineering stepper motors.
4118S-62-07
This is an awesome little NEMA 17 stepper motor. It is the primary motor used on the Cupcake CNC. It has good torque and a small size.
- 2.5 A/phase
- Phase resistance: 0.6 Ω
- Phase inductance: 0.93 mH
- Holding torque: 3240 g·cm (~31 N·cm)
- Shaft diameter: 0.190" (4.83 mm)
- Shaft length: 0.50" (12.7 mm)
- Motor depth: 1.34" (34 mm)
- Datasheet
Name | Pololu pin | Color |
A | 2B | Red |
B | 2A | Blue |
C | 1A | Green |
D | 1B | Black |
