Monotronics
Release status: unknown
Description | A single-board electronics config designed by TechZone
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
General
The RepRap Monolithic Electronics set (also known as the Monotronics) is a new design, based upon the Generation 3 electronics. It is using the same underlying Sanguino (Atmega 644p) processor and the same stepper controller circuit. We considered using one of the newer, more "faddish" stepper controller chips and decided against it (see design considerations below for more details and our logic process). This electronics set is designed to be a versatile, trouble free, easy to install electronics set. It should vastly simplify the wiring and make your RepRap build look much cleaner.
Files
I appologize to all of you who downloaded and installed this firmware before today (January 18, 2011). I had accidentally uploaded the wrong firmware. The correct one has now been uploaded.
FILE ID# | TYPE | DESCRIPTION | AVAILABLE FORMATS | CREATED/RESERVED BY |
TechZone Monotronics Firmware | MONOTRONICS Firmware | This file is the firmware for the Monotronics | .zip for use with arduino | --Tech Zone Communications Jan 16, 2011 |
Installation
Here at TechZoneCommunications, we use RepSnapper as our host software. We do not think that RepSnapper has the most features of all the different options out there, but for our purposes, we have found it to be the most stable. The other two common host software packages are RepRap Host, and Replicator G. RepRap Host uses the same firmware and is the official host software of the RepRap project (at least that is how I understand it - corrections are welcome here). What we have found, is that both RepRap Host and ReplicatorG are written on the Java platform, and as such have inherited any quirks or flaws inherent to that platform (yes, there are some, even though Oracle - formerly Sun Microsystems - would have you believe otherwise). RepSnapper was writen in C and seems to be very stable for us.
I recommend that you use RepSnapper to connect and test your electronics, then, after you know that everything is working, you can switch to a different host software. In this way, if you have problems in the future, you will know it is MOST likely something with the software, not with the electronics. Te same firmware from above should work with RepRap Host, you will have to customize your own firmware to work with ReplicatorG (Or convince me to take the time to do it...)
Adjust the Motors
I start by connecting the motors to the mainboard (see below for wire order), on a workbench. The purpose of this is to get the motors working as they should and adjust the trimpots, so that the motors are running cool enough to NOT warp you plastic parts.I go ahead and hook up all four motors, but you could use one motor (especially if all the others are already attached to your machine) and move it from one motor controller to the next, adjusting one of them at a time. With all the motors hooked up, you can connect the 12v power. The X axis, the Y axis and the Extruder are the only motors which are always activated, and so they are the only ones you can adjust by temperature. The Z axis only activates when it is being used, so after the other three are adjusted, I would adjust the Z to about the same position on the trimpot.
You don't need to connect the USB to your computer to get this first adjustment. After letting the electronics and motors sit for about 20 minutes, I check the temperature of the motors. I use an IR thermometer, but you can do it with your sense of touch (not as precise, but it should work fine). I want to get my motors to where they are running at 50 degrees celcius or less, most of mine are adjusted to be closer to 40 degrees. I have found that if they are hotter than that, then I am loosing torque due to the increased resistance of the hot windings... which creates a weaker magnetic feild. This is an example of a case where more is not better. If you are using your hand, 50 degrees feels uncomfortably hot still, but not unbearably hot, 40 degrees feels like a warmish/hot shower.
IF you have the USB connected to your computer and host software connected to it, you should be able to tell the machine to turn your motors at this time and they should obey.
Further Bench Test(s)
While we have the system out on the bench, I like to check and make sure that the mainboard and the tip manager are talking as they should. This is very simple to do. I unhook the 12v from the system, since it is not needed for this test. The first thing to look at is the temperature your host software is reporting to you. With the correct firmware (from Files above) installed and your host software communicating with the board, it should report a temperature of 2511 for both the tip manager and the Heated Bed Manager. If you are not seeing 2511 then one of two things is wrong (OK, maybe three things). The software is not connecting to the mainboard, or the mainboard has the wrong firmware; the third possibility is that the board is bad...
I would troubleshoot the above situation by re-flashing the mainboard. If it flashes correctly then it is 99% likely that it will report 2511 when your host software connects to it. I would then start checking the software to make sure it is working as it should... check the com port(s), check the computers OS, etc. I have seen a very high level of success running RepSnapper on 32 bit operating systems, the jury is still out on 64 bit operating systems - although it should work.
Next, take a tip manager and connect it to the mainboard with the RJ45 cable (a standard ethernet cable will work if you need a replacement). When you plug it in, the tip manager should immediately start reporting the room temperature to you. If you connect the same tip manager into the heated bed manager location, you should get room temperature for the heated bed temperature. Yes, it reports a temperature even without the thermocouple connected.
Connecting the Motor(s)
If you have read very much information about RepRap and the various electronics and motors... then you know that there are lots of motors out there that work... and many that don't. The first thing you should know is that your motor needs to be a bidirectional stepper motor, which has 6 ohms of resistance per phase or more. Although many people run motors with less resistance, it is not a good idea, and it has the possibility of drawing more current than the controller chip can handle, thereby frying the chip.A TECHNICAL NOTE ABOUT UNIDIRECTIONAL STEPPER MOTORS - If you have a unidirectional motor, you can wire it up in bidirectional mode (most of the time). I am not going to go into details here about how to do that, but the information is available on the web.. and someday I may create a wiki entry about doing this. I mention it because it may make finding a motor easier.. also because when you connect a unidirectional motor up in bidirectional mode, it combines two of the phases, so each separate phase from a unidirectional motor can be as low as 3 ohms, which will give you 6 ohms when you hook it up in bidirctional mode.
There are lots of different wire colors for stepper motors, but the most common are blue, red, green, and black wires. These motors are connected with the wire sequence of Blue-Red-Green-Black. If when you connect your motor, it causes the axis or extruder to move backwards from what you tell it, the simply mirror your wire connection (ie Black-Green-Red-Blue). On the right is a picture of this most common sequence. The pictures at the bottom of this gallery show some other wire colors as they should be connected to the stepper controller.
Most motors come with more wire than is needed, I recommend cuting the excess off, after the motor is mounted. Be careful to make sure that you have enough wire left, if hte motor can be moved (like the extruder motor, or the X Axis motor).
Install the Mounting Board
The mounting board is not really part of the electronics set. It is, however required in some form. The mounting board we ship with the "TechZone Huxley Kit" , or with the "LaserCut Mendel with Monotronics Kit" has a peculiar shape and is designed to be mounted to the side of the machine. I mount it to the side which is closest to the motors, to reduce the wire lenght needed.
It simply fastens to the frame using some of the small zip ties that came in your kit.
Mounting The Electronics
If you have been following the Huxley build instructions (or most other RepRap instructions) you will have already mounted the opto-endstops.
I like to mount the Monotronics board to the Mounting board with 3mm bolts and screws. You can use plastic standoff feed, or wire ties, or even hot glue if you prefer. If using the 3mm bolts, be careful to make sure that the bolts cannot short out any of the components on the board.
Connect The Endstop(s)
One of the most common mistakes, is to hook all the endstops up at once, then power the electronics up and see what happens. IF you have them hooked up wrong, you just fried all three. I suggest that you hook up one and test it, then if that goes well, hook up the next one and test it... etc.. then they are all done and working.
Uploading the Firmware
This quick tutorial assumes that you already have the Arduino/Sanguino software properly installed. If you do not yet have the software installed and configured you can find instructions HERE (link needed) in the wiki. The process below will work with other RepRap boards as well - just use the appropriate file for them
Downlaod the firmware from the files section above and unzip it to a location you can find in the next few steps It should create several sub directories with files in them.Open the Arduino environment and load the file you unzipped above.
Check in Arduino to make sure the corect board is selected. The Monotronics are a Sanguino board (as is the mainboard of the Gen 3 Electronics) The Extruder Controller from the Gen 3 Electronics is a Diecimila
Pinout Maps
We tried to label most of the connections on the mainboard as clearly as we could. There is a block of pins on the left side of the board, near the USB connector, which are not labled. these pins are intended for creative people to be able to add features or peripherals as they would like.
I have created 2 pinout maps. One which shows the common names of connectors (like what is on the board). The other has the Arduino pin names on the various connections - for programming and reference purposes.
