Mini prusa
Mini Prusa
Release status: experimental
Description | Mini Prusa
License | GPL
Author | |
Contributors | |
Based-on | |
Categories | Prusa Development
CAD Models | |
External Link |
Introduction
This is my version of a Mini Prusa, The idea behind it was that after building my Mendel-Prusa I thought that the desgin could be made smaller so it would be more portable. In doing so it the size of the printer is W/H/D 310mm x 310mm x 310mm with a build area of 150mm x 150mm x 90mm. As it is smaller in size with will cost less to build and even use less plastic.
Configuration
- Sanguinololu electronics,
- Aluminium heated bed,
- Nema 14 Stepper Motors
- Smaller Wade extruder using Nema 14
- M6 Smooth and Threaded rods
I also have re-desgin most parts to make sure that fit the project goal.
Files
Parts List
Nuts & Bolts
- 72 - M6 Nuts
- 4 - M6 Nylon Nuts - X Ends
- 74 - M6 Washers
- 8 - M3 x 20mm Bolts - Z Couplers
- 20 - M3 x 12mm Bolts - Stepper Motors
- 2 - M3 x 6mm Grub Screws - Pullies
- 8 - M3 Nuts
- 28 - M3 Washers
Heated Bed Parts
- 4 - M3 x 30mm Countersunk Bolts
- 8 - M3 x 10mm Countersunk Bolts
- 24 - M3 Nuts
- 24 - M3 Washers
- 4 - 1.2 Ohm 5 Watt Resistors (Alum Clad)
Rodding
- 4 - 210mm x M6 Threaded Rod
- 6 - 265mm x M6 Threaded Rod
- 3 - 310mm x M6 Threaded Rod
- 2 - 230mm x M6 Threaded Rod - Leadscrew
- 6 - 265mm x M6 Smooth Rod
Bearings
- 6 626 bearings - 3 on the printer, 3 on the extruder
- 12 LM6UU Liner Bearings
Thin Sheets
- 160mm x 160mm x 2mm Alum Plate - Will be used as the Printbed/Heated Bed
- 160mm x 100mm x 2mm Alum Plate - Y Frog
