Microcontroller Firmware Hints
Compiling and downloading Arduino Firmware using Windows
- Fresh Install Arduino version 011 software.
- Copy sub directories in reprap-arduino-firmware-1.3/library directory to Arduino hardware/libraries directory.
- You should end up with 14 sub directories below /libraries.
- Open Single_Arduino_SNAP.pde in arduino.
- Compile.
- You will see an error regarding obsolete header file.
- BUT it will compile without error.
- If you change a file in libraries which you invariably have to do to match your thermister/thermocouple delete the object file ?????.o
- Otherwise it will not recompile using the changes
