Metamaquina 3D/en
Revision as of 12:24, 26 November 2014 by Glenn (talk | contribs) (+ Category:Metamaquina 3D)
Kits from Metamáquina are primarily sold in Brazil, so this tutorial is originally written in brazilian portuguese.
Kits da Metamáquina são majoritariamente vendidos para clientes no Brasil, portanto, este tutorial é originalmente escrito em português.
These are visual instructions on how to build a Metamáquina 3D printer. It is a machine very similar to the LongBoat Prusa Mendel.
Alert: This is work in progress!
Assembling the frame
At the end of this step, you'll have a frame in the shape of a triangular prism.
Barra lateral inferior
Triangulo lateral sem vértice do topo
Triangulo lateral completo
Triangulos laterais completos
Barra traseira com suporte para o motor do eixo Y
Vista explodida dos componentes utilizados nas barras traseiras
Barras traseiras após posicionamento inicial das porcas, arroelas e suporte para motor
Peças adicionais para a traseira incluindo rolamento para correia do eixo Y
Peças adicionais da barra traseira encaixadas
Peças adicionais da barra traseira apertadas
Callibrating the frame
The distance between plastic parts is 25 cm in all front, back and top bars.
For the two triangles in the frame, the distance between plastic parts is 29,4 cm.
Installing the Y-axis
parafusos M3x16
z-motors
4x M3x10 in each motor
more steps
TODO
You're 3D printer build is now complete
