Metamaquina 3D/Instruções de montagem/Extrusor
Revision as of 09:58, 19 November 2012 by Tecepe (talk | contribs)
Montagem do bico extrusor
Components
Mm3d extrusor componentes 01.jpg 1x bloco extrusor
Mm3d extrusor componentes 02.jpg 1x pinça
Mm3d extrusor componentes 03.jpg 2x porca M4
Mm3d extrusor componentes 04.jpg 2x parafusos M4x50 rosca parcial
Mm3d extrusor componentes 05.jpg 2x molas CM2083 (4mm de espessura)
Mm3d extrusor componentes 06.jpg 3x rolamentos 608zz (8mm diâmetro interno)
Mm3d extrusor componentes 07.jpg 1x engrenagem de motor
Mm3d extrusor componentes 08.jpg 2x porcas M3
Mm3d extrusor componentes 09.jpg 2x parafusos M3x25 panela
Mm3d extrusor componentes 10.jpg 1x pedaço de barra roscada
Mm3d extrusor componentes 11.jpg 1x parafuso M3x10 sem cabeça
Mm3d extrusor componentes 12.jpg 1x arruela M3
Mm3d extrusor componentes 13.jpg 2x arruelas M4
Mm3d extrusor componentes 14.jpg 3x parafusos M3x10
Mm3d extrusor componentes 15.jpg 1x motor de passos
Instruções
Take the PTFE insulator and wrap a few turns of the PTFE tape around the threaded section.
Take the brass nozzle and screw on to the PTFE insulator.
Using the Silicone sealant fix the heating resistor in to the smooth board hole in the brass heater block.
Wiring the Hot End
Montagem do corpo do extrusor
Components
Instructions
Take the two M4 counter sunk 40mm screws and attach to the X axis plate through the countersunk holes , fix in place with a M4 nyloc nut on the underside.
Attach the LM8UU holders using the M3 12mm countersunk screws and M3 nuts.
Push two 608zz bearings in the holes on the Extruder block. (NOTE this can be a tight fit, gently squeezing in a vice can help ensure the 608zz bearings are seated correctly)
Use the two M4 16mm bolts to attach the extruder block to the X axis plate and use two M4 nyloc nuts to secure it in place.
Attach the Drive gear to the extruder stepper motor ensuring the grub screw lines up with the flat section of the stepper motor shaft. Fit as shown in photo below.
Attach the four M4 50mm bolts through the bolt shaped holes on the extruder block. Hot End assembly
Take the hobbed bolt and attach the Hub gear to it. Add two M8 washers.
Attach the hobbed bolt assembly to the extruder block, attaching to the side of the extruder block with the motor mount.
Take the extruder stepper motor and hold in place so that the gears engage with each other. You will note that two of the stepper mounting holes are covered by the Hub gear, use one M3 8mm screw to hold the stepper motor in place. Remove the drive gear from the motor shaft, and then remove the hobbed bolt assembly. Attach the stepper motor in place with the remaining two M3 8mm screws which holes are now no longer covered.
Re attach the hobbed bolt assembly, fix in place with one M8 washer, one M8 nut and one M8 nyloc nut.
Re attach the drive gear to the stepper motor shaft, ensuring the grub screw lines up with the flat section of the motor shaft.
Attach the two belt clamps using four M3 16mm screws and four M3 nuts, do not fully tighten yet.
Insert a 608zz bearing with the 20mm threaded rod and attach the Extruder idler holder to the extruder block to hold it in place.
Add a spring to each of the bolts followed by a M4 wing nut. Do not over tighten.
Anexando o bico extrusor ao corpo do extrusor
