Metamaquina 3D/Instruções de montagem/Eixo Z
Revision as of 20:53, 18 November 2012 by Tecepe (talk | contribs)
Components
  • 2x coupling set
  • 1x x-end-idler
  • 1x x-end-motor
Mm3d axisZ components 01.jpg 1x rod clamp
Mm3d axisZ components 02.jpg 2x step motors
Mm3d axisZ components 03.jpg 2x barras roscadas com 180mm
Mm3d axisZ components 04.jpg 2x barras lisas com 350mm
Mm3d axisZ components 05.jpg 4x rolamentos lineares LM8UU
Mm3d axisZ components 06.jpg 4x porcas M8
Mm3d axisZ components 07.jpg 16x porcas M3
Mm3d axisZ components 08.jpg 16x parafusos M3x20
Mm3d axisZ components 09.jpg 6x parafusos M3x10
Instruções
Take the clear plastic tubing and cut it into two equal pieces. Holding this with pliers gently warm them with a hair dryer (or heat gun, or in hot water). Once they are warm, slide them down the shafts of the two Z axis steppers until the free end of the shaft is level with the end of the sleeve.
Temporarily remove the Z motor mounts from the top of each side of the frame, place these upside down on the Z axis steppers, attach to the steppers with M3 10mm screws and M3 washers. Re attach the Z motor mount assemblies to the frame. (Alternatively, it is possible to complete this step without removing the Z motor mounts, by placing the stepper motors on top of the Z motor mounts and screwing the M3 10mm screws with M3 washers up into the stepper motor)
Take the two different sides of the couplers and assemble the with M3 20mm screws, M3 washers and M3nuts, test assemble and screw all the way together so that the M3 nuts become fully trapped in the nut shaped holes. Then disassemble. Take the 210mm lengths of threaded rod and trap this inside the coupling as shown in the photo. Tighten just enough so that the rod is held in place. Add a M8 nut as shown in the photo.
