MetalicaRap
Revision as of 18:17, 12 April 2013 by Rapatan (talk | contribs) (MetalicaRapBaby .... For actual builders go to builders only section below)
MetalicaRap
Release status: Experimental
An Electron Beam 3D Metal and Home Solar cell Printer, including microscope vision system (SEM) & Z axis metal correction in a vacuum.(Design stage).
EBM,categories =Powder
please contact us via mail forum below
MetalicaRap is an open 3D metal & home solar cell printer that is currently in the design stage.
The goal is to have affordable home-manufacturing of solar cells, key electrical parts and milled-quality metal parts[3][4][5].
MetalicaRap, Light , Bitch & Baby
Congratulations Aleksander he has made the first home build electron beam welder!! See 27min 40Sec along video[6]
Design criteria
The printer should have the following characteristics:
  • A build volume of about 30cm x 30cm x30cm
  • Produces finished parts +/- 20 µm over 20mm
  • Finished parts should be the metallurgical equivalent to wrought iron milled metal parts (full strength, >98% density)
  • The printer is largely self reproducing (i.e. it can print many of its own parts)
  • Single Phase electrical supply
  • Minimum consumables beyond metal powder (avoiding need for e.g. argon gas would be an advantage for later designs)
  • Cost for parts which it cannot itself print plus the raw material for printable parts is less than the cost of a used car (self replication plus self build kit may reduce the price by approximately 100 times i.e. from the existing price of a metal 3D printer or solar cell plant; 1,000,000 euro price tag, to 10,000 euro self print/kit price. historically the plastic printer went from 30,000 euro commercial price to 500 euro in 2009 via this approach)
  • The build-rate can be slow i.e. 0.2 kg per hour.
  • Max height should be 2.4m so it can fit in a home. ( first / simpler to construct prototype will be taller than this until we know how much we can bend beam while maintaining spot size, the bigger the bend the shorter it will become)
  • Shape and size of vacuum chamber and electron gun power rating should be suitable for Solar Cell Printing.
Initial decision making
An electron beam based printer was chosen due to the ability to print itsself, the power efficiency of an electron gun vs. a powerful laser at fusing metal, and the fact that an electron gun and vacuum chamber are the primary requirements for thin film solar cell printers. It was recognized that the printer did not require a new technological invention, but does require the existing solutions to become publicly accessable through grassroots research and re-engineering, freeing them from current industrial secrecy practices.
MetalicaRapLight Solar Cell Production
One of the goals is a solar cell production plant design that MetalicaRap will be able to print, that will utilize MetalicaRap's vacuum chamber and beam for the solar cell manufacturing processes[7]. For a typical family home electrical system we may bring the solar cell cost down from 10,000 euro to 400 euro by self printing. (solar cell installation, inverter, and other costs would obviously be on top of this price).
Use the process that creates thin film solar cells at a vacuum of 10-4 Torr by directly co-evaporating readily available targets [8] of ;copper gallium mix, copper indium mix and selenium sulfur mix[9], mobidium backing layer, Tin oxide front contact onto a heated substrate with a chemically dipped buffer layer and front copper alloy electrical collector strip [10]. Other precursor choices should also be possible[11]. The CIGS manufacturing process will consist of electron beam physical vapor deposition[12] (EBPVD summary by material [13])
Essential Reading
Existing Commercial Electron Beam 3D printer 2min video introduction click link in square brackets here [14], People locally developing solutions for local problems (while being connected globally[15]) and for those who have everything developing technology for a market of one! personal fabrication as a way to take control and as an aid for identity [16], Factory at home, See [17],A commercially Printed Rocket Engine Takes Flight in USA! See here at 2:40[18] (a stainless steel 3d Print)
Newsletter
We are now 18 months into the development of a printer capable of printing in all common metals, which can largely print itself.
Why an Open Design?
Currently few commercial companies give away the ability to manufacture their own product to the customer(googles "free search" business model comes closest and also Mendel see below). MetalicaRap does through self printing, which is why this project needs volunteers initially giving their time, effort and charitable contributions via crowd funding. This price reduction method and empowerment model has been shown to work with a plastic printer in 2009 bringing the price down by a factor of 60 (30,000 euro to 500 euro kit price Mendel http://reprap.org/ http://en.wikipedia.org/wiki/Adrian_Bowyer award wining inventor).
What are the benefits?
A home solar cell printer will enable a whole set of new possibilities via nearfree electricity including: water supply from air condensing, home tropical greenhouse[19], along with the well known environmental benefits of solar power for heating and lighting.
Metal printing has obvious benefits for reducing transport costs. Later MetalicaRap may effect accommodation/Titanium/Stainless steel structures cost, through reducing metal refinement and manufacturing costs, by replacing foundry processes by processing its own billet metal in to metal powder through electron beam melting on to a spinning disk within MetalicaRap, an established method.
We may bring the powder price down to 6 euro per kilogram (2012) as titanium's last refining step is Electron beam melting of "Titanium Sponge" the identical process to MetalicaRap's [20] [21].
Titanium's properties include; Highest strength weight ratio of any pure metal, Corrosion resistance similar to platinum, surface hardness can be nearly as hard as diamonds, this may lead to wearing component life times of over 70 years with a car body lasting 300 years, and with high recyclable factor of materials within MetalicaRap [22].
Few large commercial companies will compete with MetalicaRap products as Titanium's durability (100's of years) means that it is not in their interest to, as they may see it as "destroying" their own resale market. Yet through branding and short lived fashionable product design some large companies will try to maintain high product redundancy rates.
Why should i help?
There is no technological block to the success of this project, but it requires the engineering solutions to happen within an open hardware cultural context to succeed, a group of technical specialists volunteering there time and effort, along with crowd funding. We have had involvement 6 part time specialists based in Copenhagen, Geneva (x-Cern), California (x-stanford), and Toronto volunteering part time in areas including electron gun design, currently we have 2 specialists consulting for us. The more people involved on a non-specialist task level will bring the project forward quicker.
Critically MetalicaRap may offer the ability to largely print the most expensive parts so may enable the price of the solar cell printer to fall by a factor of 100, so to be within the home budgets grasp. (printing the electron gun is equivalent to printing a 600W fiber laser in a Selective Laser Sintering machine, this guns function is to melt metal on a build platform to producing metal thin film solar cells and metal parts)
For now the self replication will not include the vacuum chamber. The power supply is under construction from bought in parts. One pump will initially be purchased, and as the design progresses further parts will be self printed.
If you would like to help and knowing that MetalicaRap's design development details do not fit in one persons head, please specialize and take ownership of a specific task from below or contact us via the mail forum.
Towards this aim of reaching further volunteers we would really appreciate the inclusion of the below within your member contact newsletter in a form that suits your organization.
Kind Regards MetalicaRap team
Request for specialists and non specalists
We are looking for further technical people who are committed to empowering themselves and their environment through self motivated practical tasks in the following areas: Stainless steel metal prototype machining, High voltage power supply prototyping (75kV 1-5KW), Vacuum instrumentation, mechanical drafting / design, and back end software (specifically in unified accelerator library; a gcode to electron beam deflection coil data application). We are now also looking for more people to chase non specialist tasks as well.
Crowd Funding Support of MetalicaRap
We are currently raising money to make a RepStrap version of MetalicaRap.
We need an estimated 50K euro, and have so far raised over 5000 euro. Donations over 100 euro recieve a MetalicaRap Printing Certificate. We are aiming for a final kit parts price of 9K to 13K euro.
You can donate money:
There are many other ways you can help further the development of MetalicaRap. Please read this page to get an idea of current development status. We can be contacted on the RepRap IRC channel, [email protected], or best at RepRap MetalicaRap forum.
Main design spredsheet
Contact: click here [23] Rapatan
File:Gun Coil Pump Cost calculator MetalicaRapReadOnly.ods This is MetalicaRap's master spreadsheet click on to download.
Please send your additional calculations for the above spread sheet to the email forum above.
General Design
Philosophy
"Since Jones and Swainson many other techniques for rapid prototyping have been developed. Three of the most significant are selective laser sintering (SLS), filament deposition modeling (FDM), and the MIT powder/ink-jet-glue process.A rapid prototyping machine that can make most of its own component parts will clearly be easier to design if one avoids things like high-powered lasers; having the machine make a laser from scratch would be difficult. More subtly, ink-jet print heads (though cheap) are intrinsically hard to make as they involve micro-fabrication, and so a machine based on them would be unlikely (in the medium term) to be able to liberate itself from that one bought-in part. " [24] Adrian Bowyer
Even though SLS was one of the 3 major contenders for the reprap machine, it was rejected due to the difficulty of self manufacturing the laser. Using an electron beam may offer easier self manufacture, due to it largely consisting of 3 simple elements; a cathode metal ring, an anode metal tube and a hot wire.
Another key issue is producing verified, dimensionally finished parts. Commercial metal powder printers, both laser and electron based, can not measure the individual parts they produce during production, unlike conventional machining methods. MetalicaRap could due to the inclusion of a layer by layer measuring system (stereo, 3d scanning electron microscope).
The challenges of Z axis control is expected to be greatly helped by the vision system and z axis correction method EBM/vaporization (Vision systems are currently in development stage on state of the art commercial machines.)
Its important to point out that this is a complex and in the 1000's of euro price range project. Your largely self producing printer is possible in the commercial setting with either laser or electron beam printing parts (as the commercial machines indicate), but due to the power transfer inefficiency from wall socket to most common metals via lasers being 50 times worse than in electron beams, available home lasers would print too slowly (an exception to this is laser to steel:80%)( typically a CO2 laser in copper 1.6% energy transfer efficiency, So a 400W energy to metal therefore requires a 25000 W laser, current home build lasers are considered large at 30W), therefore lasers would limit achievable part size to 10's of cm3( e.g. 3cm x3cmx3cm) with a 2 day print duration, which makes it impracticably slow for self replicating printers. (For further proof try our Laser 808 Build Speed Calculator get from bottom of this page link here[25] )
So the electron gun is still likely to be quite a bit easier for the same power level, especially as long as complications due to magnetic forces, grounding, X-ray radiation, and calibration do not turn out to be too bad a problem, and I wouldn't expect them to. Also, its likely that subtractive machining is needed. Commercial printers report being able to produce finished parts for jet engines and medical implants etc. without it, but granted maybe there are details the manufacturers don't put on their web sites. ( thanks toGreenAtol for his overview assistance Rapatan.)
Initial technical decisions
Due to lack of control in metal powder deposition & molten metal forming droplet/distortions in conventional ebeam 3D printing (e.g Arcam 3d) a tolerance of 300µ in the Z axis is a typical with 10µ powder, (Finer powders are prone to magnetic forces and typically unwieldy, though powder demagnetization and non ferrous construction is a possibility) this demands an error correction which is based round a Vision system using 4-sector, independent channel axial Back Scatter electron detector (BSE) Scanning Electron Microscope (SEM) combined with image processing. The pseudo stereo SEM picture data can be converted to true 3D dimensional data (asymmetrical 4-source BSE photometric stereo 3D-imaging), Enabling sub µ metal height measurement. Z axis dimensional mistakes in any particular layer can be found and corrected by removal of high points through Electron beam machining of the metal. From discussions with industry experts we may bring the XYZ axis to 20µ error over 20mm (IT grade 7 See IT grade table here [26].
Advantages of current chosen design approach
  • Fully functional parts directly from standard metals
  • For most parts it may offer dimensionally finished metal parts IT grade 7
  • Good metallurgy on all common metals (Melting process rather than sintering process ensures near 100% of solid material)
  • Closed loop system
    • Self measurement of finished part tolerances.
    • May offer automatic self correction (subtractive machining steps during build process and feedback with compensation used in the additive process).
Additional Benefits; Can print thin film CIGS Solar cells in existing 10<math>^-</math><math>^4</math>vacuum chamber with existing electron gun, will be able to self print additional required parts for solar cell printer.Example process[27].
Disadvantages of current chosen design approach
  • Vacuum chamber needs on going maintenance.
  • Given the quantity and quality of metal/materials used in 10-4 torr vacuum chamber construction they may have high cost or be hard to obtain. (Limited outgasing required, more info: [28][29])
  • Difficultly in managing metal powders, indicated by the need to have layer error correction, Problem area's including; powder layer flatness, metal meniscus blob formation, metal powder trapped in work piece (i.e. designed internal closed cavities, designed internal porous or honeycomb structures most likely impossible without additional processing or work on the part after printing).
  • Quality Control may be a hurdle to overcome - on the fly heat treatment process development (to overcome residual stress present in the first few layers) may be desirable but optional. Layer by layer temperature measurement is one way for metallurgical quality assurance. Currently multiple printed and tested tensile test samples are used to prove most processes. This is a problem in general for additive manufacturing of all sorts at present.
  • Adequate surface finish may require post processing, depending on the purpose of the part. Later by the addition of argon we could do electronbeam polishing[30].
  • Non-desktop size wardrobe size, chamber volume approx 0.3m cubed.
MetalicaRapBaby in it's current form has 7 main elements which form the printer hardware proper:
  • Electron gun including deflection assemblies 0.89 m long within a 4 way reducer cross.
  • A metal powder dispenser trough hopper, with a cartesian 8cm diameter topological pick up ring. ( in a box created from a single 8 cm thick sheet of aluminum self shaped to box by MetalicaRap subtractive Electron beam cutting)
  • Build platform in a 14 inch dia. build platform tube within outer glass tube chamber.
  • SEM for vision system/feedback regarding the shape of the part and what's going on in the chamber, using the 12kg trough, hopper pick up ring.
  • One roughing pump capable of 10-4 Torr
  • Switch Mode Power Supply -63KV up to 5KWseries parallel resonant converter topology..
A low power gun build example
Low power gun in operation.. See [1]
Electron Gun Elements
Coil wiring diagram
Electron Gun
Static Electron Gun B 1- 5KW max (-63KV ) 1 m above build platform. The gun has a small filament chamber followed by a 8-32mm diameter 304L austentic grain stainless steel pipe going through the center of the coils(so non magnetic meaning coils can be in air outside chamber p.243 [31]) . The coils consist of 2 focus coils and 3 XY interlens deflection assemblies, each XY deflection assembly consisting of 2 pairs of coils for X & Y deflection on a toroid core to create electron beam for melting metal powder for additive printing and melting targets for solar cell EBPVD process, beam spot size 100µ pointing accuracy 10µ. The 3d printed layer can be measured via a sensor pick up ring that's attached to gravity fed powder hopper just above the build surface with 2 powder wiper blades attached. A second powder hopper will gravity feed the first powder hopper.
Vision gun method of providing µm precision is Topological mode SEM vision system (See [32])
Additionally the beam providing Micro vaporization of errors in the build (See gun layout Page 3 [33] down to 10µ to 40µ spot size), Initially this would be used to flatten every tenth layer of the build through high points / blobs removal. Future software development could provide live modeling of build, so through the adjustment of beam melting path in following layers errors/ blobs could be taken account of as they arise, thereby limiting the need for blob removal to critical surfaces.
  • Electron Gun constructed from self printed Stainless steel 304L 6 3/4 inch 4 way crosses reducer with ID 8 - 32mm beam pipe . Beam pipe terminates in joining adapter to glass chambers.
Vacuum Chamber and pump
  • Glass Chambers MetalicaRap Baby (3D print baby version) & MetalicaRapLight EBPVD (solar version)
MetalicaRap Baby 3D print ; 3D print chamber based around large diameter Borosilicate glass tube with aluminum plates top and bottom, with L gasket seals ( as used on vacuum bell jars), bottom aluminum plate can be lowered to gain access to attached build platform/ motors / sensors and includes electrical feed through,Stand supports glass tube and top aluminum plate with gun and power supply attached via O rings above it, beam tube to gun/filament/anode chamber will need to be welded in mother chamber due to heat when printer is operating. Large diameter removable cement pipe used to shield around it all.
MetalicaRapLight EBPVD ( Solar version) chamber based around a square bottom flask with metal vapor trap. Glass chambers are connected to electron gun tube via top Aluminum plate Tube/Glass adapter; with 5 o rings, 2 for gun tube sealing and 3 for top aluminium plate to square bottomed flask sealing, having 1 o-ring for cushioning end of glass and two for sealing each joint.Large diameter removable cement pipe used to shield around it all.
  • Pump is a roughing pump 2 stage Vane pump e.g.Leybold D4 D4B Trivac Rotary Vane Dual Stage 3.4cfm 2K euro new. to 1 x10-4 torr gas ballast off [34] [35][36] 1.0x<math>10^-</math><math>^4</math>Torr )
  • High vacuum <math>10^-</math><math>^4</math> Torr to <math>10^-</math><math>^5</math>
  • Electrical feed-troughs ; For tungsten filament AC 6V 15W 50/60Hz heater power supply based around modified microscope flat wound bulb's body(sm8018) giving a -63 KV Wehnelt feedthrough which is within a test tube providing -60KV cathode feed-through, using large diameter glass cylinder chamber with L gaskets TV feedthrough seal with o rings or o ring to copper tube then connect TV neck to copper tube. Glass tube to metal tube connection video[37].
  • Mechanical feed-troughs ; will be avoided by using periodically replaced cheap standard Nema motors within the chamber.
  • Viewing & illumination windows ; As main chambers will be glass no others are needed beyond.a window in the surrounding shielding box of standard glass 70mm thick can be multiple sheets no seal required as outside main large diameter glass cylinder.
  • Pirani vacuum gauge home build version (use google translate) [38]
  • Outer box for shielding constructed of cheap material concrete or solidified sand or earth brick.
Metal powder dispenser
This will be a gravity fed split powder hopper.A small hopper will move in the x direction, intermittently refilled by main hopper situated in side of electron gun tube.The small hopper will have a 12Kg powder capacity, this gravity fed powder hopper just above the build surface has two 1cm square section powder wiper blades attached wither side, leveling the roughly dispensed powder. The powder is released using two sliding slotted plates. A second main powder hopper will gravity feed the 12 kg hopper diameter gun tube.
Other dispensing considerations:
  • clumping may be an obstacle at high vacuums, better metal powder flow through hopper achieved through slight vacuum reducing during gravity hopper operation, then re-pumped again before bean melting resumes.
  • SEM pickup PIN diodes protection cover will be used when printing.
Build platform
A 30cm vertical travel stepper motor driven circular platform within a 14 inch 304 tube. Within the build platform is a built in ceramic insulation layer. Two felt o- rings seal to keep the metal powder from falling through build platform and build platform cylinder.
Power supply
Power supply Full Bridge LCC Series Resonant Converter with duty cycle switching variation control and above resonance frequency switching variation control, through this frequency variation maintaining Zero Current Switching during Coolmos switch ON and Zero Voltage switching during Coolmos OFF switching, with Arc sense, arc quench and arc count with output via a gun resistor, this gun resistor combined with the power supply itself will be used for beam current control .
High output series-parallel resonant DC-DC converter (search on this bold text string) -62.5KV 0 to 5KW running at 181.5KHz resonant up to 500Khz at idle/no load, with a -325V to -62.5KV transformer with voltage doubler on output, the transformer is designed for a specific value of inductance and capacitance to operate at the desired resonant frequency, as the load changes the parasitic capacitance of the transformer changes too, this means that at high load the series resonant converter topology dominates and light / no load the parallel resonant converter topology dominates. The change in load changes dramatically due to occasional arcing in the gun, This topology deals with these changes effectively. Each of the 178 PCB transformer secondary converter stages is a pcb with 1 turn coil track outputting -354 V d.c. via cheap rectifiers and voltage doublers/smoothing capacitors, when this is combined with the resonant tank gain of a range from 2.25 times to 6 times, the output voltage of 63KV is obtained. Along the stack of pcb's the voltage increases gradually keeping under the paschen air arc limit. Secondary converter stages are connected in series creating the -62.5 KV output,. Two C shaped transformer N87 ferite cores with 11 turn primary (54A) and a high voltage 178 PCB secondary insulated bobbin 4mm deep of UHMWPE seperates ferite core and PCB secondaries.
Power supply feedback control around transformer measures';'Output voltage feedback via 208 thick film resistors creating voltage divider . Output current sense feedback via a temperature stable resistor in ground voltage path. Input /Primary current sense via 2 "current transformers" in series in each leg of full bridge. Wehnelt voltage feed back via thick film voltage divider. These four signals go via signal reconditioning board then on to Field programmable gate array (FPGA) [39]via four channel analogue to digital converter (ADC) 12 bit 40Msps[40]. FPGA process maintains input and output current parity within acceptable current window values. Allows a small error signal from voltage output variations when within a narrower voltage output window values. FPGA drives 4 coolmos FET gates in full bridge topology via driver circuits. FPGA also checks for error conditions. Solftware for the FPGA is a PID controler [41] and a osscilator. A separate housekeeping supply provides bias for all control circuitry, providing a 5V separate stand-by voltage which remains active when the power supply unit is shut down for any reason ( later once efficiency of power supply is assessed a Power factor adjuster circuit may be added between rectifier and dc to dc converter).
Beam current modulation options;
  • Control via power supply feed back circuit, leaving gun cathode to Wehnelt electrode bias fixed via resistor. When at 1KW power and shut down in half a cycle ( 0.2MHz switch frequency) the resonant energy left in LCC circuit and output capacitance would lead to one extra 55micron cube of melted Titanium or 40 microns cube of melted steel which is workable .
Specialist Parts
Those which are not self printable or readily available;
  • Transformer ferrite core ; Rectangular hollow section shape single phase style [42] but circular cross section on secondary high voltage side
  • 4 toroid coil cores Material (?)
  • Roughing pump capable of 10-4Torr
  • long large diameter Flexible hose to reduce back streaming of oil from pump to gun (with end CF-16 hose to pump fitting)
  • Priani vacuum gauge
  • Electrically operated CF-16 T valve
  • Exhaust Valve
  • Transformer varnish insulated wire for coils
  • Viton o rings; 6 small for cathode, 3 small & 3 large for gun tube to glass chamber adapter, two very large door style for CRT to CRT sealing with Aluminum support ring sandwiched between them,
  • Copper OPFC knfe edge flange sealing rings; 2x 6.34inch DN() , 1 x DN80 anode, electron gun tube flange 1.33inch DN() for 6.34 inch to 1.33inch reducer plate.
Access to ; Vacuum leak detector Spot welder for in chamber electrical connections of OFPC copper conductors having glass beads as conductor insulation. Avoid the need for TIG Welder in MetalicaRapBaby by bourgt in part electron gun beam tube being chort enough to be able to fit in chamber of mother machine ( or with stopper and compression fitting chamber base plate if needed),(TIG welder for electron gun tube to flange attachment for MetalicaRapBitch)
MetalicaRapWin Optional beam windows A later innovative development
A window between gun and build platform enables the use of high brightness small spot size LaBa6 filaments that last 1,000 hrs as opposed to 70 hrs for tungsten. Allows the use of barrier argon gas at atmospheric pressure surrounding build platform and associated mechanics so no pump down time after accessing build chamber and great savings on mechanical feed through seals. Will also offer large part manufacturing in inexpensive argon "tents" as only the gun requires a vacuum chamber. Disadvantages include; some ballooning of beam as it passes through approx 5mm's of argon atmosphere between build platform and window, lowing resolution of SEM vision system ( x-ray sensing option may help or build platform chamber pump down for vision system and argn for printing), high tech stationary window will involve high tech manufacturing , Low tech Aluminum slot window will reduce print speed and increased mechanical complexity as build platform to gun physical scanning motion will be required. Repeated door opening will be overcome through these windows and thus ion pump or electron beam sublimation pump will be less stressed.
Low tech option; Scanning Aluminum Slot beam window (14cm length x 100µ width )
A narrow slot window which is physically moved across the build area.Window will be cooled through thermal conduction to water channels surrounding window. Requires minimum 100KV beam to penetrate 20µ thick AL window, so keeping beam losses below 21%. Beam loss is inversely proportional to acceleration voltage.
High tech option; stationary window
A stationary high tech window that will be cooled through convection and radiation alone. "transparency" of window enables the possibility of a less penetrating beam of 60KV. 400µ sheet with 50µ micro dead end holes creating ebeam window.
Beam divergence at different atmospheric pressures beyond window, left at atmospheric pressure, middle at third of atmospheric pressure , right at a hundredth of atmospheric pressure
Costs and technical calculations spreadsheet
Gun Calculator, download MetalicaRapReadOnly.ods left side
Lens Coil Calculator , download MetalicaRapReadOnly.ods above left side
Large part costs, download MetalicaRapReadOnly.ods above left side
File:Gun Coil Pump Cost calculator MetalicaRapReadOnly.ods this is metalicarap's master spread sheet click on to download.
Software
Include the following models for tracking the process;
  • Electron gun beam focus model:To highlight resolution operational compromises between; the higher the gun cathode voltage the tighter gun focus, so the smaller the beam spot size on the metal powder giving rise to a higher XY minimum feature size (lens adjustment can alleviate. See lens simulation [43]), yet also the higher cathode voltage the faster the electrons go, so the deeper the electron energy deposition/giving rise to deeper vaporization holes, giving less vertical Z resolution, (used during Z axis error correction mode). Also surface tension is correlated with temperature, and works in opposition to wetting effect flattening the surface of the melt pool (if the melt pool diameter is small compared to the thickness of the metal layer it may appear as a molten blob of metal). This model will receive an energy profile of the beam by pulling two wire prongs through the beam in the X and Y direction, The wire prongs attached to the end of the sensor ring will be pulled through the beam by the XY motor drives, thereby sensing the energy cross section through the electron beam, which will be radioed back to Unified accelerator Library control system, enabling automatic adjustment of beam focus, beam strength and beam spot size. This will also be used to compensate for ripple in the power supply and operational loss of beam alignment from for example filament variation and magnetic interference. All except the last of these effects should be predictable so most calculations for build can be done by the model prior to build in offline mode.
  • Thermal Real Time Model; this allows us to keep track of the thermal changes across the build chamber or cooling path as the electron gun pulses strike the build volume powder. Cooling rate controls the micro-structure which controls the mechanical properties of the final part. Defects include residual stress that can be removed by removing the part from the chamber and heat treating before continuation of the build, so it is best avoided by temperature management. In vacuum no convection, so a little radiation and mostly non air conduction. Conduction path is only threw metal to metal contact so as part builds cooling path continuously changes. Also each layer melts part of the previous layer. Considering the following 4 situations conduction rates:1. Metal powder & solid metal volumes experiencing direct electron energy deposition (i.e. heat around electron penetrated regions, the depth of these volumes increases with Cathode Gun Voltage KV & vary with metal type) see electron penetration model [44], 2. solid metal thermal conduction volumes (the completed elements of final metal part under construction), 3. metal powder conduction volumes (the surrounding powder), 4. chamber/boundary thermal conditions (vacuum region, build box). See electron strike model for different metals and different cathode Voltages.In general for any unit volume receiving an amount of energy per second to be raised by 1 degree K (the metals specific heat capacity) from a distant energy source, the amount of energy (W or J/s) arriving from that energy source(the electron beam) via a path; The paths energy transit rate (the conduction rate) is dependent on the cross sectional area of path, the length of path and the temperature difference between the ends of the path, ( "thermal conductivity, units in W/deg.K). The volume changes size by the surrounding pressure (atmospheric pressure, indicating the density of the material).So from known initial temperature conditions combining the specific heat capacity, thermal conductivity and density to calculate paths, then summing these paths leads to knowing the temperature of a specific unit piece of metal and its physical state, solid or liquid or vaporized (temperature above or below its melting point or vaporization point at any particular time). The following should be considered; variation of mass with scan speed, bed preheating scans. See for more background technical information. [45] [46].
  • We may need a network structure to combine the different hardware elements.
"Unified accelerator library"
Our electron beam focus model and control software choice
Those looking for entertainment might look at the open source Unified Accelerator Library (UAL) that has a 30yr track record of simulation and control of electron beam movement , a Electron beam focus model and a Control/Simulation approach. But UAL lacks thermal models and metal powder melting modeling so it's main use may be to get the beam spot landing on the powder at the correct position and with the desired diameter defined in the G code from skeinforge. (You can down load UAL here [47], [48] Introduction here, [49]
Manuel for UAL's Design Toolkit called MADX where you can enter a hardware definition i.e. collection of coils along a beam start with two solenoids at 0.1m and -6 m, beam at 0m along latticeset, at 3KW 100 micron diameter (MetalicaRap will likely have 3 XY deflector coils for beam deflection, 2 "Solenoid" for beam lenses) then run simulation of beam with OFFLINE MODEL UAL 1.9 here [50].
The hardware definition of coil positions is called the "lattice". The control ONLINE UAL 1.11 will them apply this simulation to the control of the electron guns in real time. Ignore the following elements we don't have them in MetalicaRap: BeamBean, electric kicker,Kicker, RF cavity, taylor map, wake, wriggler .
This has the advantage of being a closed loop system, which while simulating the beam movement simultaneously records models coils, guns, motors inputs; voltage values, current values etc. Then when you run the real world machine these form the drive instructions to the machine, any sensors picking up deviations are resolved through alarms or the software "reality checking" and thus improving the model. It also is designed as a multi user, multi platform software environment. Some draw backs may be over complexity of the system.
Main Deflector Coil driver options; a) Raster 30cmx30cm b) point and shoot
  • An open source network software Fast Network "EPICS" for running UAL on, See here [51] [52] More Info here[53]
"Code Aster"
Our thermal modeling software choice
Quick start instructions on thermal modeling software:
  • Open Source thermal real time model software Code_aster Introduction here[54],
    • Download code-aster software (Windows) here [55],
    • Download extra element GetDP.exe here[56] (put GetDP.exe in c:\ASTER\OUTILS\gmsh\)[57],
    • Download code-aster software (Linux to compile) here[58],
    • Download extra element GetDP.exe here[59] (put GetDP.exe in c:\ASTER\OUTILS\gmsh\) once it is installed and extra element has been copied then as it finishs select option to run code aster.
First select your problem type definition files from the wiki i.e.Thermal program example See here (Use login user: getdp password: getdp) [60]
Second build your mesh of shape you require to be tested, with code_aster sub module Gmsh: you can find it In ASTK prg window under menu item Tools Gmsh \\\ then in Gmsh window select GEO in drop down sub menu //// or import shape via .stl file In ASTK prg window, menu item Tools, Gmsh , then in Gmsh window select; MESH submenu
Third run solver to solve the problem you have defined above by selecting the SOLVER submenu in the GetDP window and hit GetDP button. In GetDP window choose source files for problem; name.PRO file(the problem defined in an example text file from GetDP wiki ) Choose name.MSH ( mesh file defining geometry) Then in GetDP window select options and tick "display client messages" option, then hit Pre then Cal then Pos buttons and then see window called message console window and it will tell you what happened, the output results files name.PRE name.RES name.POS will be in the same directory as the name.PRO file you selected for input.
General info;(Gmsh is a three-dimensional finite element grid generator with a build-in CAD engine and post-processor) See here [61] Can access Gmsh through Graphic user interface or directly through unix or TCPIP socket via code_aster sub module getDP Download GetDP.exe here[62] (put GetDP.exe in c:\ASTER\OUTILS\gmsh\ or specify path to existing location) Overview here [63]See here [64]GetDP documentation here [65], Thermal program example See here (Use login user: getdp password: getdp) [66] Documentation for relevant thermal model calculations See Thermics module R5.02 booklet: / General Architecture D00301a.pdf In DDocsHTML (Down load following two links, unzip to same folder) [67] [68], Complete Guide to code_aster documentation here [69], Software Principles explained here[70] ,Aster documentation source here [71] , home page here [72] wiki[73],
Background Technical design considerations
Construction Materials
Materials:
  • Vacuum chamber wall stainless 304 L  ; cold rolled , p.243 [74]
  • metals for cathode/1stanode-wehnelt/ anode electrodes '(tungsten /molybdenum/ tungsten,)
  • metal for "soft iron core" surrounding the two lens coil windings, unalloyed soft iron for yoke use a soft iron, like AISI 1006
  • Inter lens X Y deflection coils made from 3 ferite toroid's, all X deflection coils interconnected, with the first toroid wound in opposite direction from the second and third toroid's and Y deflection coils similarly connected.
  • thermal conducting material for anode support structure that extends through the middle of the anode support ; copper for wehnelt support rods and water cooling core within 304L anode support rod p.246 [75]
  • Thermionic emission regime hot filament design; Tungsten ; light bulb sm8018 see cost saving approaches below or Ribbon 2mm wide 0.254mm thick ( copper infused tungsten has also been mentioned as more stable physically)
  • ceramic insulators, you can use either mullite or alumina. Do not use stuff like teflon (is a sponge for water, and outgasses too much) or macor (machinable glass - too delicate). Your shoulder washers in electron gun support are standard commercial items. these are specialist items so we have tried to replace them with everyday glass items e.g. test tubes .
Finishes: Interior surface of vacuum chamber should be polished (..) then cleaned acetone and ethyl alcohol
Avoided materials:
  • Avoid zinc, magnesium, and lead, as these don't have negligible equilibrium pressure at temperature ie out gass too much at temperature, so for example avoid brass as out-gasses intensely when it gets hot, which can lead to ionization and flash overs.p.237[76]
Powder and metalurgy issues
NASA is also making their own machine but with wire not powder, t the 1 hour lecture is a good introduction to the metallurgy involved in EBM see here [77] (if not work then go to http://www.aeronautics.nasa.gov/electron_beam.htm# Select windows streaming in main page, then Windows Streaming Video then +window streaming in pop up window, some other selection options come up with the wrong video).
Play with this build speed software we have written and then you get a good idea of which metal you want to start with Online Design Tool: Build Speed Calculator for metals including Aluminum,Stainless,Tungsten
The initial test run prints will be made in stainless steel 30µ (Pre cool final printed parts from this powder is therefore likely to achieve a tolerance of 250µ) and chromium cobalt under 50µ 30µ?( Pre cool final printed parts from this powder is therefore likely to achieve tolerance of 250µ)metal powder [78]supplier[79], and then later the challenges of Titanium 4µ powder will be considered (Pre cool final printed parts from this powder is therefore likely to achieve tolerance of 20µ). See article on micro sls [80]. See example machine [81],See example of twin chamber 3D printer[82]. Though through subtractive machining we may be able to bring critical surfaces of most of parts down to 20µ. stainless is 316L grain size -45µ+10µ product purpose 3D printing good fluibility, 60gbp a kilo best price 80 kg per buy delivery 3 month. Powder is manufactured from cold rolled metal (e.g. 304 approx 1.8 Euro a KG 07/20111) by Electron Beam Melting of a rod of feed material which then is momentarily caught on spinning plate and flung thereafter, thereby solidify by cooling. See [83]
The magnetic metals lead to magnetizing of Iron based metal powders so should be avoided where possible, (the main magnetic metals are Iron, Nickel, Cobalt Iron)
The metal powders are not good to ingest or breath in so mask should be worn. The metal powders may get caught in the fine folds of your skin so gloves should be worn.
All metal powders can burn easier than solid blocks, the active metals are most flammable and difficult to handle; Titanium 4µ (other active metals include Aluminum, , zirconium ), then the moderate range metals e.g. Cobalt Chromium 50µ and finally low range Stainless steel 30µ . General fire avoidance should be followed, Avoid sparks and open flames, Avoid dust clouds( through dumping action of powders), and use appropriate tools. Design principles of fire avoidance should include; appropriate grounding of equipment, avoid excess mechanical friction in design. For active metals consider glove box contained nitrogen clean up environment or just a liquid based vacuum cleaner. The number of electrons, the velocity of electrons and the beam diameter all effects the resultant melting and penetration. Putting the focal point within the metal gives more penetration, while placing it above the metal spreads the beam and gives a wider melt pool. More electron current makes deeper penetration and more heat input, yet less current with higher velocity electrons give less heat input and less penetration.
First layers are tricky to print  ; first layer must weld well to metal base to stop part warping , because cold platform contact hot metal residual stress tries to snap build platform so build platform needs to be thick to resist this force, must also need to be reusable after each print must be milled.
Cost reduction by pre-processing billet metal in to metal powder within MetalicaRap through electron beam melting on to a spinning disk is also achievable later. For a particular steel unprocessed it costs about 0.5 Euro/ kg, but traditional metal stock for milling machining costs 20 Euro/kg, for metal powder up to 60 euro/Kg, these raw material pre-processing costs may reduce to 1Euro/kg by self processing.
Pros and cons of 3d metal processes [84](see below for link comparing tool head processes for more detail)
Current status
We are based in Copenhagen Denmark at Labitat.dk our main engineers are also in Lancashire UK.
Wednesday night you can come to Labitat in Frederiksberg, Denmark and meet the team. Currently electron gun test rig and repstrap vacuum chamber, including pumps and gauges under electrical maintenance.
Get involved! The current team donates their free time, Current tech team; 1 Administrator, 1 software developer UAL, 1 electrical engineer all part time
(Very occasional advice from; 1 Ultra-high vacuum metal deposition specialist, 2 physicist, 1 High-voltage system designer, 1 mechanical Design Engineer).
Do get in touch. See talk page and forum for more discussion.
Files and Parts
File:Assembly1 MetalicaRap V2.04.stl Pre detailing chamber to scale ( work in progress)
Click on file names to download file
Sub Assemblies and Related
EBS=Electron beam sinterer/melting.
sequence - electron gun parts repstrapped EBS. Assembled tested in repstrap vacuum chamber. Metal powder deposition mechanism parts repstraped EBS . Gun deposition assembled tested. MetalicarapVacuumChamber parts Electron beam sintered by our system. MetalicarapVacuumchamber assembled tested. 5 Elements assembled and tested.
Downloads Drawings and Photos
For further drawings click here MetalicaRap:Photos and Drawings
Self replication
Self-replication of a vacuum chamber runs into the "how to make a match box inside a match box problem". This has been overcome by using 2 recycled TV cathode ray tubes as main vacuum chamber, Leaving only the problem of the build chamber tube which can now self print in 7 pieces and assembled, which is achievable as no longer needs to be vacuum tight only metal powder tight as is within glass Cathode ray tube chambers. Finally a good way to reuse all those old TV's!
Design review
Cost saving approaches
cost saving approaches List;
  • Only control via power supply feed back circuit leaving gun cathode to Wehnelt electrode bias fixed via resistor. When at 1KW power and shut down in half a cycle ( 0.2MHz switch frequency) the resonant energy left in LCC circuit and output capacitance would lead to one extra 55micron cube of melted Titanium or 40 microns cube of melted steel. See problem C for calculation Physics Principles/Discussion Yes! big cost savings here!
  • filament based around tungsten microscope bulb ( ie flat wound)( sm8018 6V 15W bayonet square filament towards top BA15D ) with top glass dome removed held on remaining glass, half in and out of chamber by 2 viton O rings in bespoke compression fitting which itself is within a test tube via 2 more o rings which is also half in and out of the chamber held in its own compression fitting, the test tube is modified with a hole in its end for the bulb filament to protrude out of. A coil surrounds the test tube and a small coil attached to the bulb completes the filament drive "core-less transformer" electrical circuit, when combined with a dimmer circuit connected to coil out side the test tube it replaces conventional filament current control. Thus using a test tube with a home wound coil round it and a modified light bulb provides; -80KV electrical feed-through, -77KV electrical wehnelt feed-through, filament transformer, filament , heat removal mechanism from bulb to test ube, support for wehnelt disc(adjustable height above filament aim 0.3mm) ( also covered with a cap so no pointy HV parts revealed). A user selectable resistor is also included between wehnelt and filament within the test tube. 6.5Keuro saved here.
  • Two large TV tubes with screens drilled through with appox 16 inch circular holes enough for build platform, placed face to face with oring between screens, one neck removed where the electron gun is inserted via a o ring, maybe one path to save 2K euro of chamber metal and get 1 set of free electrical feedthroughs for motors (motors working in chamber).
  • Since you can get an electron beam to operate in a vacuum of around 5x10^-3 Torr. Avoid metal sealed flanges such as the conflat or wheeler flange By Buna rubber seals and low out gassing glues can be used for sealing components and costly vacuum flanges can be avoided in much of the construction. Simple pipe threads sealed with teflon tape or even glues can be used along with cheaper KF flanges. ( status untested ).
  • Avoid expensive vacuum specified water cooled motors operating in the vacuum ( heat dissipation problem) By using oversized normal NEMA motors to cope with overheating and replace any oil filled elements eg gear boxs with a higher temperature white grease. Out-gassing shouldn't be a big problem with grease.;( Status may only last 6 months at a time partially tested) //A hole should also be drilled into the gearbox to allow air to be evacuated.//
  • Normally you use use pneumatic vacuum gate valves for the foreline and roughing valves and then a large pneumatic "angle" gate valve for the diffusion pump/ion pump inlet. Lastly, a pneumatic poppet type valve is used to vent the chamber to atmosphere. Avoid the expensive 25.4cm angle gate valve By home-brew using large plumbing valves gate or ball valves for 4 inch and smaller diffusion pumps. See how well home brew valves hold a vacuum BEFORE you put them onto your vacuum chamber. ( status untested).;
  • MetalicaRapWin 2nd pump Oil diffusion or ion pumps may be replaced by MetalicaRaps electron beam heating a titanium block within the vacuum chamber, thereby creating a Titanium Sublimation Pump Or what I think we should name it the Electron beam titanium sublimation pump so avoids all gate valves to the second pump since titanium is replenished each atmospheric cycle by the beam melting it and thus also avoids ion pump refreshment /maintenance. ( this new method of pumping relies on a having a very good rough pump vacuum ie 1x10-3Torr so the beam can operate to raise titanium to 1300-1600 deg.C. its sublimation temperature. eg Leybold D4 D4B Trivac Rotary Vane Dual Stage 3.4cfm 2K euro new. to 1 x10-4 torr gas ballast off [85] [86][87] or Kinney KC Series KC-3 pump 2K euro recon. or e.g DS 102 Dual Stage Rotary Vane Vacuum Pump 2 x10-3torr 2K euro new. ( these pumps both use oil for lubrication, Oil free called dry pumps are better for EBPVD. (check which PVD metals deposit ok with oil around and which not? ) Dry pump options are currently too expensive eg 10K euro plus; Richards EPX or top end Dry Scroll pumps or Blower Booster paired with own Backing Pump) to protect the chamber put the titanium block in side a double walled box with a beam entry hole at the top, and offset breathing holes through to the rest of the chamber on the box sides, thereby protecting the main chamber from the condensed titanium on inside surfaces of the box and yet let chamber gas combine with titanium creating solid compounds/a chemical pump with inbuilt recovery. Pumping speed may be moderate; for a 13 inch long 1 inch wide by 3 inch high box surrounding the titanium bar , gives a Ti deposit area of 91square inchs, at 20 degC. given pumping speed is 25 litres per second per square inch of deposited Titanium, So Nitrogen pumping speed is 2275 litre per second or 136 m3 / min or 8191 m3 per hour, thus the beam creates its own high vacuum pump. (some tantalum will be advantageous for argon pumping). (Arcing is more likely at poorer vacuum pressures, from the paschen curve we can see that this may not be a problem[88] (should allow / avoid arcing between; cathode to wehnelt 3kV over 0.3mm (same as Pd 3x10-2Torr cm at 3KV See graph [89]) - welhnet to anode - 100KV over 34mm (same as Pd 2.9x10-4Torr cm at 100kV See graph [90])(note; may not work/ may arc at rough pumping pressure levels of 1x10-2 Torr for argon on wehnelt ( i.e. Pd 3x10-1Torr cm at 3KV See graph [91])))) ( untested but breakthrough if works and probably will especially for MetalicaRapWin with its 10-7Torr vac requiremnt !)
More Examples
Practical manufacturing walk through
Manufacturing walk through Time/Cost
Given Electricity is 2kwh per hour .5Euro/hr Part A Material; Stainless steal, Size; 300x300x200mm Weight; 15Kg 10µ Stainless powder (40 to 100Euro/kg) melt print 100µ Z layer thickness
1 minute per 100µ each layer See below; 1 minute per Z 100µ layer, each layer preheated 20 degrees Centigrade under melting-point followed by printed by beam5.33 minute per Every 10th layer Z axis correction see below ;
SEM ( part assumed to occupy 1/9 of whole print area; 1/9* 300*300=10 000<math>mm^2</math> measurement at every 10µ, SEM picture 500x500 pixel so 5mmx5mm, So for 10,000<math>mm^2</math> need 400 SEM pictures 10,000/25= 400 4x pictures from 4 picups gives effect of different angles? for 3D picture reconstruction so real distances, 400 5mmx5mm pictures, 250ms a picture = 100sec. plus time of mechanical movement of electron gun between .024m square patches at .03m per second is 12y strips each 0.3m strip takes 10 seconds to travel, so in all takes 120 seconds to cover build area( Risk of underestimate factor x100 ) 100+120=220 or 3.66 min flatten blobs through repeated surface spot melting 1ms per 70µ diameter spot area 4000x10-6<math>mm^2</math> ( 850µs duration & 150µs beam movement) 1/10 of part high(Risk of underestimate factor x2) ( 1/10*10 000mm2/ 4000x10-6 <math>mm^2</math>= 1x105 spots 1x105 spots*1ms= 100Sec 1.66min
Time so far 200* Z correction layers 5.33 Min each 1066 + 1800 printed layer 1min each = 2866 min ( 2.0 days) Cost 690 Euro materials 600Euro Electricity 90
MetalicaRap:Further future developments
Critical Design Review, Review of decisions made so far
In chronological order
1.metal.......................... Vs ..composite. ........... .........Why .Metals needed for high stress high temp contexts , engines, solar plants.. -ve ........................ +ve metals 100 % recyclable fits Cradle to Cradle Design See [92]
2.additive.Sintering........ Vs Subtractive EDM?.................Why Tool path manual intervention required.Consumables......... -ve ..Powder management ............ +ve
3.ebeam..Vs laser .....Why A)laser below 50W,small size part 5x5x5cm,slow B) Laser above 150W cost, permit , Wall plug efficiency , optics .-ve .not so cool , difficulty diagnostics...+ve solar cell printer possible
4.powder...........................Vs foil..........................................Why foil waste removal.................................-ve .Harder solid parts.& powder management...... +ve
5.vision & correction sub. Vs one pass blind process ... ....Why .reliability Verifiable tolerance............................................. -ve ...Complexity..................... ................ +ve
6.gravity hopper................ Vs twin chamber........................ Why avoid old powder reuse fresh every time easier prep ............ -ve their must be a good reason to use 2 build chamber? e.g. EOS is. +ve
7.one static top of chamber gun with just sensor ring on cartesian axis Top gun shoots through sensor ring from top........... Vs two gun would ensure spot size on vaporisation but could add in again if existing does not work. Why So SEM near table Sensors PIN Diodes 164$ each not 64x PINdiodes . Pros & Cons of two guns design
8. Water cooling Vs Passive cooling for 5KW gun .............Why .Air cooling fins on cathode head block and on high voltage copper enclosed connector plus ducted fan & fins -ve need to be FEL modeled to check conductance. +ve Simplicity no water ( though could add later ).
9 Tungsten thermionic cathode filament.2600C. Vs .hot Field emission cathode ..Why Cost of IrCe, field emission required UHV, .Thermionic is OK in high vacuum... -ve hot spots poor beam focus reduced filament lifetime, gas load in metal powder more critical due to filament sharing same space.... +ve cheap no need for window to separate gun chamber from powder chamber
10. External coils Vs ..Internal coils in a 304 can..... ....Why .to achieve small enough spot size as spherical aborations are zero on axis of lens and increase as you move out, ... -ve need for barrier between coil pole pieces and beam for vacuum, construction of can for air cooling +ve no contact between coils and vacuum
11. Split hopper ..... Vs ..One large dispenser hopper.....Why ..cost chamber size less force required on motion feed through............... -ve ..complexity of refill mechanism ( shutter with knife edges ) ............... +ve. initial lower cost
...................................... Vs ...............................................Why ...................................................... -ve ..................................................... +ve.......................................
list in importance order, bold text indicates more thought required
General Information
Solar cell thin film deposition
Thin film deposition summary by material [93] RF sputter is another option for increased solar cell production rate [94] uses the electron beam to resonate a cavity to produce an RF magnetron) .
Green Tech./Solar Cell production cost calculation
To produce thin film CIGS solar cells at under 11 cents per Watt peak. So Solar cells cost for a family 3 Bed house; Average Electricity usage 4200KW per year, 4200KW/365days*4.93 Equivalent Hrs peak sunshine= 4200KW/1800Hrs=2.3KW peak of solar cell panels required, at 11 cents per Watt peak the solar cell's would cost 253 dollars from MetalicaRaps plant plus cost of backing material, cost of inverter plus extras 1300 dollar, so it may offer an uninstalled system at under 1,900 dollars,( current price for uninstalled system is around 14,000 dollars (jan 2011)). (Calculation based on cloudy areas of world, 1KWatt peak solar panel system under 4.9 hours peak sunshine per day gives approx 1800KWh per year, A desert area at low latitude would be up to twice as good as this.)( For reference in a hot climate a 1.25 dollar/W installed financed system gives ;0.07 dollar/KWh over 20yrs, 0.03dollar/kWh over 60 yrs [95])
Safety issues
The penetrating ability of Xray produced is proportional to the voltage applied to the apparatus, So for your your old TV it was at 30KV but as long as you keep the electrons in a box that was no problem. But If you do like those crazy people in hospitals fire them all round the place precautions need to be taken, MetalicaRap keeps the electrons and the targets within a glass or metal box surrounded by a further shielding concrete/sand rectangular box.
We can use this formula to calculate the dose rate,
R (rad/sec) = 50 x V (kV) x I (mA) x Ztarget / [r (cm)]2 x 74 where V is acceleration voltage, I beam current, Z constant for target metal type, r distance from target. Formula from Radiation safety manuel page 11 [96]
Lets calculate the dose inside the box we find;
The dose rate inside the chamber at 14 cm from a copper target operated like metalicrap at 100kV and 14 mA is: 50 x 100 x 14 x 29/ (7cm)2 x 74 = 560 rad/sec.
The recommended shielding from this level of radiation for working hours use is 1.2mm of lead.
Our MetalicaRapBaby and MetalicaRapBitch chamber is made out of stainless steel 304L 3mm thick, which is equivalent to 1mm thickness of lead shielding, this is surrounded by a concrete sand outer rectangular shielding box which is equivalent to a further 1.3mm of lead. So over twice the required shielding is provided by the chamber and shielding box. So plenty of shielding is evident.
Our MetalicaRapWin chamber is made out of stainless steel 304 each 3mm thickness is equivalent to 1mm thickness of lead shielding, our chamber is 7.925mm thick, So over twice the required shielding is provided by the chamber. So no further shielding materials are required.
Useful links
EBM introduction [97]
Images EBM / EBW [98]
General background Videos EBW see here [99]
Back ground Information on Electron beam processes; electron beam welding / vaporization , EBM 3D printing(2),
Scanning electron microscope SEM background(3)(4).
2. http://www.arcam.com/technology/ebm-process.aspx
More technical sites
3. http://www.matter.org.uk/tem/sitemap.htm ,
4. http://www.uga.edu/caur/semindex.htm
5. General practical technical information; Power supply; Transfomer winding [100]
6.General practical technical information; Feedthrough glass joining ways to adjust your glass items in your test tube based electrical feedthroughs and insulate/construct with bead glass between electrodes.[101], Glass tube to metal tube connection[102]
7. General practical technical information;Electron gun / CRT tube salvage ; Explanation of how to take apart a cathode ray tube electron gun to salvage Wehnelt molybdenum disk with hole in ( the first disk in front of the hot wire cathode) a tv CRT [103] note you can diamond file/diamond saw break the pip on the very back of tube to release the vacuum then reseal with blow torch to keep the electrical feed-throughs functional. Another example of a old CRT oscilloscope.[104] .
8. Conventional Helium detector explanation [105]
Self Replication Engineering Options See section 2. [106].
EBM technical background lecture See here [107]
General background Videos EBW see here [108]
MetalicaRap:Tool head processes discussion
Futher Reading
Vacuum chamber principles; Essential reading before you weld/construct your vacuum chamber, Basic Vacuum technology by Varian
Maths behind vacuum processes (Not for the faint hearted )[109]
Old general infomation
Click for link to Old Information section
Builders Section Very detailed technical information for actual builders only
MetalicaRapBitch elements
Power Supply section is correct but the other sections on the repstrap machine called MetalicaRapBitch is still being edited so not correct yet!
Electron Gun MetalicaRapBitch for builders
Electron Gun B 1-5KW max (63KV ) 1 m? above build platform. The gun has a small filament chamber followed by a 12mm? diameter 304L austentic grain (i.e non magnetic p.243 [110]) stainless steel pipe going through the center of the coils. The coils consist of 2 focus coils and 3 XY interlens deflection assemblies, each XY deflection assembly consisting of 2 pairs of coils for X & Y deflection on a toroid core.
Demagnifyng lens Assume max current/cm square is 250A/cm sq in coil,Assume wire crossection is square, and max current in an individual wire is 4A, therefore 67 wires per cm sq max., so round down to 8x8 wires in one cm sq diameter 10mm/52 =0.19mm from awg chart [111] AWG 17 with varnish insulation, 2750 wires in probe forming lens so approx cross sction area of coil 2750/64=43 sq cm 12 cm x 4cm. round up to 12 x 6 for tolerance.
Probe forming lens Assume max current/cm square is 250A/cm sq in coil,Assume wire crossection is square, and max current in an individual wire is 4A, therefore 67 wires per cm sq max. , , so round down to 8x8 wires in one cm sq diameter 10mm/8 =1.25mm from awg chart [112] AWG 17 with varnish insulation, 600 wires in probe forming lens so approx cross sction area of coil 600/64=10 sq cm 4cm x 2.5cm.
For 1 m from platform to probe forming lens 11 deg interlens deflection required pipe radius 16mm I.D.
Thus providing additive printing through melting at high beam deflection speeds, enabling high build rates along with melting targets behind a metal vapor trap EBPVD solar cell production. The one gun will be stationary situated 1m above the build platform. A sensor pick up ring will be attached to a 12Kg gravity fed powder hopper just above the build surface with 2 powder wiper blades attached, using sliding slotted plates to release the powder (design similar to household air vents, but ours will have sharpened vent edges). A second powder hopper will gravity feed the 12 kg hopper. This one gun will be used for both melting and vision systems. a back-scatter detector ring will be attached to the powder hopper, close to the workpiece mounted on the Cartesian XY system (the hoppers motion itself provided by the X motion of the hopper, Y motion by means of further 2 linear bearings on front of hopper and drive shaft (No automated Z movement of the ring is included in the design ).
Providing build platform metal powder heating and melting, spot size 100µ (may be inaccurate) pointing accuracy 10µ (may be inaccurate). The gun will have a liquid cooling anode system via its support.
Vision gun method of providing Sub µm Topological mode SEM vision system (See [113])
Additionally providing Micro vaporization (See gun layout Page 3 [114] down to 10µ to 40µ spot size), Initially this would be used to flatten every tenth layer of the build through high points / blobs removal. Future software development could provide live modeling of build, so through the adjustment of beam melting path in following layers errors/ blobs could be taken account of as they arise, thereby limiting the need for blob removal to critical surfaces.
Vacuum Chamber and pump MetalicaRapBitch for builders
  • Pump is a roughing pump 2 stage Vane pump e.g.Leybold D4 D4B Trivac Rotary Vane Dual Stage 3.4cfm 2K euro new. to 1 x10-4 torr gas ballast off [115] [116][117] 1.0x<math>10^-</math><math>^4</math>Torr )( a dry pump option is better for EBPVD but currently 10K plus euro so rely on back flow oil filtering.)
  • Electron Gun constructed from Stainless steel 304L 6 3/4 inch 4 way crosses reducer with ID 8 - 12mm beam pipe . Beam pipe terminates in joining adapter to chambers,
  • Use large diameter Borosilicate glass tube with aluminum plates top and bottom, with L gasket seals ( as used on vacuum bell jars), bottom aluminum plate can be lowered to gain access to attached build platform/ motors / sensors and includes electrical feed through,( thus avoiding the need to cut TV screens hardened glass as in TV solution, or use TIG welding equipment, as mother machine can self print or fit parts requiring welding in her chamber, but initially requiring more machining to produce top and bottom aluminum plates (later we can electron beam machine over size top and bottom plates in mother machine, by first printing O ring collars and grooves inserts, then welding these inserts in to half drilled holes in top or bottom over size plates in mother machine, then through drilling these half drilled holes, finally cutting down circumference of top and bottom plates with hand tools). Stand supports glass tube and top aluminum plate with gun and power supply attached via O rings above it, beam tube to filament / anode chamber will need to be welded in mother chamber due to heat when printer is operating. Large diameter removable cement pipe used to shield operator and some environmental disturbance removal shielding e.g.electromagnetic shielding so beam is not effected by outside electromagnetic disturbance, e.g. nikel coating, when printer is running.
  • ((OLD solution TV Glass Chamber; chamber based around two recycled CRT TV tubes, face to face. The 2 salvaged CRT's with holes cut in screens, after end neck pip breakage release of vacuum, capacitive discharge via anode button and electron gun removal in both CRT's. Lower CRT pip reseal with blowtorch so lower feed-throughs continue to function, upper CRT has electron gun neck of CRT tube shortened. Two o-rings supported on one side by a double grooved Aluminum metal support ring sealing the CRT's face to face and providing access door. (Capacitive discharge via shorting anode cap to earthing band on corners, use own cable as anode cable may have diode in [118][119][120] be safe out there!). Glass chamber is connected to electron gun tube via Aluminum Tube/Glass adapter; with 5 o rings, 2 for gun tube sealing and 3 for CRT (MetalicaRapBitch) , having 1 for cushioning end of glass and two for sealing each joint.(or to square bottomed flask (MetalicaRapLIght) sealing) feed-through motor connections via Cathode RayTube connections in lower recycled Cathode RayTube,. ))
  • Electrical feed-troughs ; For tungsten filament AC 10A 3V 50/60Hz heater power supply based around modified microscope flat wound bulbs body(sm8018) giving a -62.5 KV Wehnelt feedthrough which is within a test tube providing -59.5KV feedthrough. Using large diameter glass cylinder chamber with L gaskets TV CRT neck feed-through seal with o rings Or o ring to copper tube then connect TV neck to copper tube by melting CRT glass. Glass tube to metal tube connection video[121])
  • Pirani vacuum gauge ( avoid cathode gauges as ionization from gun my interfere with them)* Home build Pirani vacuum gauge (use google translate) [122]
  • Outer box for shielding constructed of cheap material concrete or solidified sand.
  • Viewing windows; Main chamber viewing window with large diameter glass cylinder; Viewing windows are just multiple planes of normal glass in hole in concrete pipe as no sealing is required, total thickness 70mm for shielding. ; Electron Gun viewing window will be a CF 50 flanged type on a Twith extra removable metal plate for shielding
Metal powder dispenser MetalicaRapBitch for builders
Currently same as above
This will be a gravity fed split powder hopper.A small hopper will move in the x direction, intermittently refilled by main hopper situated in side of electron gun tube.The small hopper will have a 12Kg powder capacity, this gravity fed powder hopper just above the build surface has two 1cm square section powder wiper blades attached wither side, leveling the roughly dispensed powder. The powder is released using two sliding slotted plates, ( design similar to household air vents but ours will have sharpened vent edges). At the end of the hopper travel a small waste powder slot will remove old dispensed powder before the next dispensing sweep takes place. A second main powder hopper will gravity feed the 12 kg hopper, it will be situated up in the side of the 14 inch OD diameter gun tube and will obscure a little part of the build chamber from the beam (a necessary compromise). The vision system feedback can accommodate some roughness in the powder deposition during beam melting phase and subtractive removal phase.This design may lead to clumping with some powders at higher vacuums. The window option overcomes this but introduces other complexities in vision system and beam distortion (see below).
Other dispensing/ considerations include:
  • Metal Vapor will be released in to the chamber during the melting of the the powder, a later consideration is protection of the gun, initially the guns distance from the build platform should be adequate, but the possible inclusion of a spinning slotted disc in front of the gun as further protection may need to be considered,
  • SEM pickup PIN diodes protection cover will be used when printing,
  • Variable layer thickness might (?) be desirable to provide fine control of the vertical resolution using thin layers where desired, while still allowing relatively high build speeds that come with thick layers for other areas.
    • The Arcam EMB uses a "textured roller". Presumably a roller is textured with a pattern of holes which is loaded with powder, then the powder falls out of the holes, and a little random redistribution occurs on the way down to the workpiece surface for a reasonably uniform powder layer of repeatable thickness this design will likely operate at ultra high vacuum.
    • Leveling the surface of the powder bed or enabling better flow through hopper at ultra high vacuums may be possible using ultrasonic lubrication to briefly fluidize the powder bed. It might cause unacceptable settling though.
    • The density of the powder is lower than the density of the solid metal. So if the powder is only deposited using say the textured roller the upper level of the powder bed will get higher than the surface of the part being printed. How is this dealt with in the Arcam printers? More research needed
  • Upon beam heating material loss in the form of evaporation and melting is released in to the chamber redepositing itself on windows and light optics and even chemically react with filament ( a minor effect with most materials), use replaceable and disposable glass sheet covers.
Build platform MetalicaRapBitch for builders
A 30cm vertical travel stepper motor driven circular platform within a 14 inch 304 tube printed in sections which is not vacuum sealed , as it is all surrounded by large radius glass tube. Within the build platform is a built in ceramic insulation layer. Two felt o- rings seal the gap between the vertical motion circular build platform and the surrounding cylinder.
Power supply MetalicaRapBitch for builders
Overview
Power supply Full Bridge LCC Series Resonant Converter with duty cycle switching variation control and above resonance frequency switching variation control, through this frequency variation maintaining Zero Current Switching during Coolmos switch ON and Zero Voltage switching during Coolmos OFF switching, with Arc sense, arc quench and arc count. ( see old information for more on beam current control options)
High output series-parallel resonant DC-DC converter 5KW 62.5KV (search on this bold text) -62.5 KV 0 to 5KW running at 181.5KHz resonant range 260Khz up to 500Khz at idle/low load, with a -325V to 62.5KV transformer with voltage doubler on output, the transformer is designed for a specific value of inductance and capacitance to operate at the desired resonant frequency, as the load changes the parasitic capacitance of the transformer changes too, this means that at high load the series resonant converter topology dominates and light / no load the parallel resonant converter topology dominates. The change in load changes dramatically due to occasional arcing in the gun, This topology deals with these changes effectively.
The primary of the high voltage transformer will have 11 winds .The transformer secondary consists of a magnetic flux pole with multiple ac to dc converter stages with planar coils (search on this bold text string) but pole is extended in to a traditional single phase core type transformer arrangement [123] or technically defined as a "dual C ferrite core assembly" ( with high voltage secondary side cylindrical cross section not rectangular, so as to avoid corners at high voltage). Each side is surrounded by an insulating HDPE or nylon 6/ 6 insulation cover called a transformer bobbin, one square sectioned and one circular cross sectioned (dual C ferrite core assembly and bobbins will be within a insulated HDPE box, and will run in air with the option of mineral oil insulation later).
Each of the178 transformer secondary converter stages is a 2 layer PCB 0.4mm thick, with a 3 turns/winds (A 1 turn PCB layer and a 2 turn PCB layer blind via's not possible) ( 1oz. thickness) 0.6mm wide circular tracks on the PCB looped around the ferrite core and 4mm insulation bobbin connected to 2 rectifying diodes and 2 capacitors in a voltage doubling arrangement, ((0.4 thickness for insulation safety) no masks(100µ mask saved) + 0.15µ Mica washer (better insulation and heat dissipation(check availability)= 0 .55mm thick) conductive turn/winds of track creates a transformer secondary coil. The series parallel resonant converter topology gives voltage gain in this coil from 2.25 times to 6 times dependent on switching freq/duty cycle which is combined with the gain of the o/p voltage doubler arrangement of output rectifying diodes and capacitors, gives a resultant gain of ; 11primary winds,3 secondary wind, times factor of 2 (Topology)and times 2 (voltage doubler)(3/11)*2*2*325V= 354V, so outputting -354 V d.c.from each PCB. Each voltage doubling circuit uses fast rectifiers and 2 smoothing capacitors. Along the stack of pcb's the voltage increases in a negative direction gradually, keeping below Paschen or arc limit . The power supply secondary converter stages can be tested (unregulated) as 178 separate -354 V power supplies, before all the secondary converter stages are connected in series creating the -62.5 KV output. To reduce the parasitic capacitance each secondary PCB 3 turn track layout is in alternate direction clockwise/anticlockwise, while the connection polarity to the 2 smoothing/doubling capacitors is also alternated so as to maintain a continually decreasing voltage up to the top of the secondary pole across the o/p capacitor stack of -62.5KV. This gain requires the following component values n=17 Cp=15nF Cs=48nF( Series Capacitor requiring reduced ESR [124] so achieved with many film type nonpolar capacitors in parallel ( capacitance additive, ESR resistance reducing each extra parallel)) alpha=0.3125 Ls=16µH. fo= 181.5Khz. Max duty cycle 0..8 at frequencies 260KHz to 500Khz. Temperature rise is under 10deg C for this 0.6mm wide 1 oz (35µm) thick track area 0.21 sq mm rated up to 08A will use 0.08A Fig2[125] At switching frequency 181.5Khz skin effect is 0.15mm depth of circular conductor (each side of track approximately) so effective rating 0.6A [126]. Min track spacing 16mm for 178V. (( Alternative use flexpcb 0.2layer x2 but under 400µ thick insulation issue could test further)).
Transformer ferrite core is splittable in to two "C's" half's horizontally in the middle of vertical sides. Min transformer "window" vertical space for coils/PCB is in practice approx 100mm from ((178*(0.4mm PCB + 150µm Mica washer )+8mm insulation ) 8mm insulation is made up of 4mmTop&Bottom Sides of Bobbin. 0.15mm mica washer (Fx. Kapton sheet SIL-PAD K-10.[127] Or Muscovite mica paper MPM1(501) 82g/m2 0.055mm thick[128]- doubled up 2KV protection (3/11*325*6=531V max. poss.)) as spacers between PCB's, with Creepage distaance around edge off sheet/paper of Cat III 8mm min. ie 4mm track from edge of paper inside and outside track/coil[129].
Transformer ferrite core In any of the following equivalent materials //Material code (Manufacturer)// CF139 ( Cosmo ferrite),// N87 (epcos),// 3c94 3f3 (ferroxcube ),// R (Magnetics ), //PC44 (TDK),// 2FB ( tomita ).
Primary wire is 11 turn primary (87A continuous)(coolmos short circuit peak current limit of 117A) on a transformer bobbin (10cm flange on HV end) high voltage bobbin 4mm of HDPE or cross linked low density polyethylene XLPE also called PEX or nylon 6/6 insulation.
The -62.5kV Direct Current (DC) after regulation is directly connected to the Welnelt electrode then continues on via a manually selectable gun resistor to the Tungsten filament/cathode. Then the current flow continues down the beam to the target and returns via the chamber body to the power supply via a fixed resistor in the earth path to measure its magnitude. The voltage at the filament/cathode is also measured and fed back to power supply. This feedback via increased beam current leading to more voltage dropped across gun resistor meaning Wehnelt pinches beam current to a lower value and vice-versa means the beam current settles to a stable value. To maintain the best beam shape this simple feed back mechanism should ideally stabalise with 3KV over the gun resistor ie +3KV between Wehnelt and the cathode/ filament.( see spread sheet above for more details of optics)(NB the most negative part of gun is the Wehnelt, the cathode traps electrons in front of it by being up to 3KV more positive than the Wehnelt (-59.5KV). The max beam current possible would be achieved if the cathode-filament became more negative, ultimately as negative as the Wehnelt at the same -63KV, thus the wehnelt would have no limiting effect on beam current. Unfortunately the focusing effect of the wehnelt would also be lost at this point, so cathode being slightly positive with respect to Wehnelt is always desirable. Maintaining this cloud of electrons in-front of the cathode-filament called the space charge effect See spread sheet for calculations)
Power supply feedback control around transformer ;Output voltage feedback via 178 thick film resistors in series creating voltage divider . Output current sense feedback via a temperature stable resistor in ground voltage path back to power supply from earth on chamber. . Input /Primary current sense via 2 "current transformers" in series in each leg of full bridge with 1:125. Cathode voltage feed back via 178 thick film resistors acting as voltage divider. These four signals go via signal reconditioning board then on to Field programmable gate array (FPGA)[130] [131] via four channel analogue to digital converter (ADC) 12 bit 40Msps[132]. FPGA process software will maintains input and output current parity within acceptable current window values. Allows a small error signal from voltage output variations when within a narrower voltage output window values. FPGA drives 4 coolmos FET gates in full bridge topology via driver circuits. FPGA also checks for error conditions. Solftware for the FPGA is a PID controler [133] For control methodology also see High output series-parallel resonant DC-DC converter 5KW 62.5KV ( via search on this bold text )(NB this paper does not include the real transformer just 2 dummy inductors and 2 Dummy capacitors one series one parallel) . A separate housekeeping supply provides bias for all control circuitry, providing a 5V separate stand-by voltage which remains active when the power supply unit is shut down for any reason ( later once efficiency of power supply is assessed a Power factor adjuster circuit may be added between rectifier and dc to dc converter) The following safe guards will be included; Under/over voltage protection, Short-circuit protection, Output current limit, over temperature protection and line fuse. Adaptive control[134] is applied using Gain Scheduling in feed-forward methodology; Controller verifies the amount of current available (ie how much in tank ) to reach a target voltage at the o/p, adaptive gains are recalculated over each sample , this system identification technique thereby selects the appropriate linear controller from 3 options(low load controller, high load controller, arc controller) , so target voltage is met what ever the operational reality demands ( other people have done with fuzzy logic).
(Useful cheap analyzer for FPGA development [135],[136] , [137] )
Beam current modulation options MetallicaRapBitch;
  • Only control via power supply feed back circuit leaving gun cathode to Wehnelt bias fixed via gun resistor ( which includes inherent sensing of beam current; as too high beam current means more voltage drop across resistor so more beam pinching so reducing beam current so simple feed back control). When at 1KW power and shut down in half a cycle ( 0.2MHz switch frequency) the resonant energy left in LCC circuit and output capacitance would lead to one extra 55micron cube of melted Titanium or 40 microns cube of melted steel . . See problem C for calculation Physics Principles/Discussion Fixed gun resistor but with a refinement of 8 fixed value /position adjustable gun resistors(200W 40K to 180KOhm with heat sink and glass pipe air cooling) so you can put beam current in suitable range to allow for filament change variations these are manually selectable from outside test tube, via magnetic mechanical feed through around test tube. ( will need to develop beam calibration current measurement method after filament change, IDEAS? Could measure deflection distance of beam for known deflection coil current modulation? )Yes! big cost savings here!
Power supply High Voltage Isolation optical SFP Implementation MetalicaRapBitch for builders
To control the power supply we need to measure the output current and output voltage just before the tungsten cathode, the current is measured via ADC voltage dividers either side of a fixed value thermionic stable 15Kohm300W bias resistor situated in the test tube high voltage feed-through ( there is also a further 3 selectable resistors 15K Ohm 30KOhm 60Kohm in series for lower beam currents with the aim of always achieving 3kVolt drop between cathode and Wehlnet via these resistors(at 300W)) , but these circuits are at high voltage and require isolation.
To isolate them from the user (transformer primary side) and still receive the voltage and current data from the high voltage output, we use two Papillio FPGA's one each side of the transformer connected with an optic fibre which provides the insulation (optic fibre must be non metalic cased type). This transformer Secondary side FPGA measures the voltage and current via ADC's and then converts this parrallel data in to a serial bit stream, which is sent over the optic fiber via two Gigabit SFP transceivers [138]. Due to the FPGA's running off non synchronized clocks a buffer is required on the primary side FPGA to resync and recover the data and its associated clock, so the voltage and current information can be decoded by the primary side FPGA. Further details TBA [139]
High speed optical link receiver buffer FPGA logic gate circuit; showing layout of buffering of incoming data signal (data signal sampled at 400MHz/ or 2.5ns period , data bit is 6 bits long, +/- one bit). This gives plenty of scope for tracking the incoming data as its relative phase wanders between the two FPGA's caused by FPGA's master clocks inherent rate variations [2]
Powersupply Feedack Control Implementation MetalicaRapBitch for builders
The primary side FPGA also runs the PID error signal correction and low pass filter along with the Digital Pulse width modulation outputs to the drive the FET's via a 300V isolation chip and a high low FET driver chip.
Further details TBA
SEM MetalicaRapBitch for builders
We may be able to use 6 PIN diode Topological / 3D imaging sensor also for spot size calibration, as we can solve for spot size knowing distance from gun...etc.
MetlaicaRapWin Later
Optional beam windows; High tech stationary window or Low tech scanning Aluminum foil slot shaped beam window.
  • As the window version will run at 10-7 Torr LaB6 filament is possible (expensive but 1000 hour filament life and 40 times brighter),
  • One Self printed Electron beam titanium sublimation pump Or distributed Ion pump with some tantalum, slotted cathode cells for argon gas collection[140] or oil diffusion pump or turbo pump. (prototype uses turbo pump)
  • Second pump is a self printed High vacuum Titanium sputter-Ion pump (with some tantalum, slotted cathode cells for argon gas collection [141]) or our invention Electron beam titanium sublimation pump. Prototype before self print, bought in oil diffusion pump (messy with expensive oil 100euro/litre) or turbo vane pump(4K euro extra) .
  • Second pump types sputter ion pump or oil diffusion pump will need to be closed off from the chamber during chamber access and roughing pump cycle, to save cost avoiding large gate valves reduced pumping rates will be accepted through the use of smaller radius gate or ball valves with smaller 4 inch or below type pumps . ( later self print gate valves will be investigated)(An oil diffusion pump can not pump at atmospheric pressures and can ruin the oil trying to do so).
  • (For ion pump; Use electron guns focus coils to provide magnetic field to sputter ion pump [142] 50L/s max, short duration between maintenance 30Hours , self cathode refreshment by electron beam surface melting exposure in MetalicaRap's beam)
Our high vacuum pump will be a sputter ion pump as has a cost reduction and ease of use advantage for us especially with the window option . As the high vacuum turbo pump cost has been a block to costs coming down, but after redesign an Ion pump seems a good solution, approximately 300 tubes (anodes at 8KV) 15mm diameter 26mm long made of stainless, with 8mm diameter titanium plates ( cathodes at 0V) fitting in either end of anode tubes , leaving a 3.5mm gap for the gas to enter, these are situated around the outside of the lens coils providing magnetic fields in their own stanless steel cans and a 8KV supply hooked up, we have create a electron gun and ion pump combination pump. The number of tubes control the pumping rate it lasts 400 hrs at 1 x <math>10^-</math> <math>^4</math>torr but 40000 hrs at 1 x <math>10^-</math> <math>^6</math>torr . slotted cathode cells for argon gas collection [143]
14 inch pipe (NPS 14 min. SCH 20 ) with one 100mm thick Aluminum plate with interior "carved out" for hopper box sides and top, a further 304 plate for bottom of hopper box with o-ring seal, 304L Top and bottom pipe end caps if not domed min. 18mm thickness typical 25mm thick with copper CF flange and hinged window access.
The refill hopper will be situated in the side of the 14 inch OD diameter gun tube and will obscure a little part of the build chamber from the beam(a necessary compromise). (Technical background: See 5.2 [144]see lecture 4.02/11/04[145],[146]
  • Viewing window/ Door 8inch borrsilicate glass, 3/8 thick, standard 10 inch CF plate and Oring.
Detailed Information for builders only General Processes Information
Materials for builders
  • Vacuum chamber wall stainless 304 L  ; this can be used for walls and pipes and is non magnetic when in Austentic grain state so can be used within magnetic fields. p.243 [147]
  • 304L cold rolled , hot forged, electro slag remelt or vacuum remelt or cross forged ,
  • 304L pipe cold rolled must be welded without filler,
  • To avoid micro cracks (use 304L not 304) and maintain non magnetic properties , Keep 304L at temperature 600 to 750 C for min period during welding ( minuets not hours under 1 hour max)
  • For window version UHV LaB6 keep max inclusions to 1 or less for all types see p8 [148]
  • metal for "soft iron core" surrounding coil windings, unalloyed soft iron for yoke use a soft iron, like AISI 1006; as low carbon as possible. or possible. "Hyperm O", (Cobalt iron alloys for pole pieces if needed e.g. Vanadium Permendur is a superior soft magnet material, but it is VERY difficult to work with and very expensive , and requires fair expertise in heat treating after machining. You should only use it if you need to)
Inter lens X Y deflection coils made from 3 ferite toroid's (N97?), all X deflection coils interconnected, with the first toroid wound in opposite direction from the second and third toroid's and Y deflection coils similarly connected.
  • thermal conducting material for anode support structure that extends through high voltage feed through ; Aluminum p.245 [149]
  • glass for cheap but fragile chambers ( and often need outer radiation shielding box ) p 249[150]
  • Thermionic emission regime hot filament design; light bulb sm8018 see cost saving approaches below ( copper infused tungsten has also been mentioned as more stable physically)
material for flange ordering:
  • 304L stainless steel electro slag remelt or vacuum remelt or cross forged,
  • hot forged
  • tube ID to be free of hydrocarbon contamination
  • white pickled or bright-annealed
  • I.D & O.D Clean after manufacturing
  • seal in plastic bags
  • etched or stamped with part nr, and material type
not allowed:
  • sand packing,
  • mechanical scratches on tube ID
  • any type of lubricant
Avoid the following ;stainless 303 has sulfur in, cadmium and zinc plated screws, brass. avoid plastics , avoid O rings contact with solvents. [151]
( Prototype ; Vacuum flanges use cross forged 304L stainless ( corss forging breaks up an reorientates leak paths(certainly in flanges over 3 inch to remove micro leak paths that exist in normal 304 plate) (Material sampling As each batch of steal has a unique finger print of number of leak paths/impurities, material sampling can be used to fine the best batch's for High vacuum use.)
Strength vs cost of materials [152] Strength vs Weight [153] Strenght vs Ductility/Brittleness [154] Strength vs Toughness [155] Stiffness vs cost of materials [156] Recycle Fraction vs Cost [157]
Resistance Electrical vs Cost [158] Max service temperature [159]
Vacuum Tech for builders
check for design for; leaks, Virtual leaks , chamber surface area reduction eg minimizing ceramic fish beads insulation, This is a developing detailed process which you improve incrementally in practice.
calculation of process of gas load from;
  • seals /volume gas / Calculator here [160] Given a)enclosed volume..m<math>^3</math> b) Volume flow rate capacity m<math>^3</math>/s remove from this o ring leak rates ( for viton 2.5 x<math>10^-</math> <math>^8</math> torr liters / second / linear inch )c) initial pressure mbar d) final pressure mbar Get estimated evacuation time of
  • surface gas / permeation/ desorption from materials etc by pump ,
If two pumps backing pump selection calculation.
10-4 torr HV chamber list ; First time chambers conditioning; New O-rings vacuum bake 150o C or several hours next to infa red lamp not over 160o C before installation . If the chamber is a bake-able, metal-gasketed ultrahigh vacuum (UHV) system, baking the system, especially into the roughing pump, would be standard procedure.Avoid cold spots will collect the very contaminants that we need to remove.. Using internal UV 185 /254 nm bulbs to breakup hydrocarbons and infrared bulbs for desorption of water.; If using non capturing type of pump ( eg turbo pump or oil diffusion pump ) where 2 pumps are required, one roughing (i.e. taking the turbo pumps inlet to low enough pressure to be activated, then changing mode to maintaining a appropriate turbo pump inlet pressure for efficient pumping, called roughing pump in backing mode), the inter pump connection line or" foreline " having a diameter above 12cm means you nearly avoid slow pumping molecular flow mode [161] otherwise introducing some Nitrogen in the inter pump line when chamber is below 1 x <math>10^-</math> <math>^3</math>torr will ironically help the roughing pump support the turbo pump better and remove any water .This Nitrogen gas technique is also an extra help for supporting the functioning of the oil sealed mechanical pumps oil traps and light gases in fore line also.
For window version running LaB6 UHV chamber 1 x <math>10^-</math> <math>^6</math>torr ; First time chambers; Flushing the chamber to exhaust with hot nitrogen gas for 1/4 -1/2 hour can be effective in removing surface contaminants (UHV) Could go as far as Glow discharge cleaning[162].
High Voltage for builders
The high voltage bobbin for transformer is an insulating material; HDPE 4mm or cheaper XLPE ( X indicates crosslinked LDPE) or nylon 6/6 insulation, This cross linked low density polyethylene XLPE is used in 11KV to 500KV cables where LPE is set to a fixed form by a process called curing or vulcanization, this can be done via chemical or electron beam radiation. This crosslinking process improves the mechanical stability of the cheaper XLPE products. Comparing the breakdown voltages on different Polyethylene we find that HDPE is 100KV/mm, LLDPE 75KV/mm LDPE 75KV/mm XLPE 50KV/mm p.8[163]]. Other materials include PVC, ceramics, glass, rubber, resins, reinforced plastics, polypropylene, impregnated paper, wood, cotton, mica, pressboards, Bakelite, Perspex, Ebonite, Teflon [164]
Introduction to HIgh Voltage [165]
Shielding Tech for builders
1mm lead shielding is equivalent to :3mm 304 stainless , ??mm sand, ??mm concrete,  ??mm standard glass ??mm leaded glass, external box with window cheap ideas?.
Argon gas cylinder needs to be protected from falling over, as long as their is some ventilation the argon gas is no problem, a 60 euro cylinder should provide 3000 chamber purges in window option design ( background info; oxygen 21% of air argon less than 1 %, if oxygen concentration falls below 17% than can effect ill people for healthy people its ok down till 12%, if trace element of CO2 is also present hyperventilation can be triggered which allows no ill effects down to 7% Oxygen. this C02 trace approach is added to argon fire extinguisher systems). For on beam path calculation target penetration based on NIST material testing calculater for 90KV 1.8 mm of lead gives 100% attenuation[166].
Other design options which other builders may choose to follow that we have rejected
Chamber & pumps & feedthroughs
Pumping options ; diaphragm pump no oil Dry
Link to details of High vacuum chamber (initially welded then glued)
  • Electrical feed-troughs ; For tungsten filament AC 10A 3V 30W ( NB SM8018 bulb for comparison is 6V 2.5A 15 W flat wound filament but nearly all energy is seen by gun where as only a 40th of ribbon is seen by gun but is 30W 2mm wide 50µ thick ( check)) 50/60Hz heater power supply electrical feed-through includes a oil immersed 100KV isolating transformer using a Pyrex and quartz tubing within CF pipe coupler with orings with oil imersion on outside [167] .By placing last stage of main 100KV power supply the cockcroftwalton ladder in its own vacuum chamber keeps all high voltage ( 100KV) within vacuum(except filament isolating transformer) which allows 15 KV sparkplug type electrical feedthroughs to be used [168] these are welded sparkplugs on CF flanges with out radio noise suppression carbon resistor . A further welded sparkplug type electrical feedthrough will be used for interconnection of 100KV from power supply sub vacuum chamber to main gun chamber. CF flange Electrical connectors, Other (1x 140KV 2KW , , 6x SEM PIN diode pickups low current low voltage,
  • Mechanical feed-troughs ; 45Nm torque oring or more leak resistant magnetic feed-throughs 3x 12mm Motor shaft Vacuum chamber motion feed through. 10-5 Torr Low torque version and high torque for 700W build platform motor.
  • a dry pump option is better for EBPVD but currently 10K plus euro so rely on back flow oil filtering. ( Aminor issue for metal printing but a problem for solar cell printing is the silicon oil vapor in to the chamber from the oil diffussion pump which will be cracked when in contact with tungsten filament (at 2600 C) producing oil by products that reduce the vacuum and affect the quality of EBPVD [169] melted metal depsoited layers (EBPVD summary by material [170]) .
  • Alternative roughing pump is use an oil diffusion pump, there is an existing home build design, see here: [171],[172] (use google translate) though some people have had success with using the chilling unit from an air conditioner in-between pump and chamber [173]. Other electrical feedthrough options includes 100KV sparkplugs with out radio noise suppression carbon resistor [174] with oil immersion on outside. But many commercial machines use the diffusion pumps and cope with the oil issues;The cooled condensation baffles in between the pump and the chamber is adequate to prevent any significant amount of oil getting in the chamber at these pressures. The best way to do wire coils is to seal them into a stainless steel can, and allow a cooling medium like air to ventilate the can. You cannot hope to dissipate much heat from a coil in vacuum, and you don't want the coil to outgas into your vacuum anyway. For the prototype we suggest one gun in a chamber that can be used to test either guns design( Melting gun and vision gun).Once we see the outcome of the test we can decide to try two separate guns again if necessary.
Powder Deposition
  • Upon beam heating material loss in the form of evaporation and melting is released in to the chamber redepositing itself on windows and light optics and even chemically react with filament ( a minor effect with most materials but a major effect if used in electron beam machining mode where a non metallic backing material or axillary material which is ignited leading to rapid expulsion of auxiliary material that pushes up through the partially mellted hole in the metal work piece above thus causing expulsion of molten metal in the hole, thus creating a cleaner hole shape See 26min in [175]), a slotted disk in combination with a pulsed beam operation and a slotted disk can protect these windows / optics surfaces. (another approach is to use replaceable and disposable glass sheet covers).
Power supply and power control options
  • Use power supply only approach, but with a refinement of 8 fixed value /position adjustable gun resistor so you can put beam current in suitable range to allow for filament change variations, instead of manual rotation ,use fet 4KV & 8x ldr/resistor gate matrix & 8 x led outside test tube. This would make the change of gun resistor automatic. Rejected due to difficulty of finding a FET small enough to go in test tube, ( 200W 4KV up to 30mA)
  • Current sensing methods; On transformer secondary (high voltage side) second FPGA on optical link via SFP gigabit modules can sit at -62.5KV and measure current via fixed 40K Ohm (40K non varying element of gun resistor it also has 0 to 140K ohm variable / or via 8 fixed resistors element in 20K ohm steps ) gun resistor their by gaining 30dB Signal noise, ( as opposed to second FPGA siting at 0V sensing beam current across gun resistor via two voltage dividers (-62.5KV to -2V voltage divider), as opposed to using separate (5W 100 ohm) current sensing resistor in earth return from chamber, even less noise but earthing complications with some motor types and requiring some low voltage secondary insulation of chamber) ( power to FPGA via low voltage rectifier and core less transformer via filament test tube ( same method as filament supply but additionally rectified).
  • by control of the bias on the Wehnelt voltage in gun ; 0V( full beam wehnelt has same voltage as cathode filament No bias ) to - 3KV pinch off (cut off where wehnelt is at the lowest voltage and cathode filament is 3KV more positive ( i.e. more like anode) ). This bias is achieved via E130L vacuum tube acting as a voltage divider of the main output voltage thereby in effect creating a second voltage supply, OR via 2nd transformer isolated power-supply providing up to 3KV bias. This approach has poor short circuit protection and poor repeatability due to main filament replacement alignment variation).
  • by control of the bias on the Wehnelt voltage in gun ; via a second power supply across cathode and Welneht. ( this option is not compatible with the o/p current sense via a ground path resistor as it places a parallel power supply, o/p current sense via a hall device Isolation via a led to photo-transistor 10cm light tube to bring signal to low voltage side/ FPGA side. High voltage side circuit powered by a second core-less transformer across glass test tube used in cathode filament assembly, primary is mains, secondary rectified 5V for LED driver circuit and 15 V for hall current sense device ).
  • limit the control option to pulsed operation; use FET series each 800V with transient voltage protection regulator circuit for an x-ray tube with transient voltage protection
  • A full high voltage drop across a tetrode ( triode limits bandwidth [176], this tetrode is a safety feature as it controls the current independently of gun but is expensive.
  • Push the parallel series converters resonant tank current by 30% so get higher voltage output of 73KV instead of 63 KV. This requires n=19 Cp=18nF Cs=57nF alpha=0.3125 Ls=13.5µH. fo= 181.5Khz. Max duty cycle 0..8. Stress on components increases as Zs Series impedance drops from 333 Ohms to 236 Ohms.
  • Voltage multiplier ladder version Cartesian 1kW gun power supply circuit construction will be based around 2 MOT serialized 100KV(1Kw) that gets feeded from a freqency controlled 3 phase switchmode powersupply range 100 Hz to 1 KHz and 8 stage Cockcroft walton ladder for the positive 15 Kv x8= 120KV un regulated, To avoid the need for both; expensive air tight 100KV connecters, and power supply oil immersion , the Cockcroft walton ladder will be situated within the vacuum tank (dead tank with the enclosure at earth potential) in a sub chamber sealed from the main chamber having its own small 8KV ion pump with some tantalum, slotted cathode cells for argon gas collection [177]. The intermediate wall between vacuum tank containing Cockroft walton ladder and main chamber containing gun will be constructed from copper with internal water cooling channels connected to exterior water supply to avoid Diode and resistor overheating problems. With the use of a one way valve between chambers the circuitry remains well insulated unaffected by vacuum loss in the main chamber. .( Cross linking machines already use this vacuum encased powersupply approach).
Cockcroft Walton ladder Calculator Help & Tool for any one who want's a fast overview [178]
Transformers and ladder 3 phases
Power supply functional diagram now full wave Cockcroft- Walton ladder
  • You take heat out of assemblies like this by incorporating water cooling. If you use high purity water (80 meg-ohm) it is reasonably non-conducting electrically, though initially tests will be air cooled vanes on high voltage feed through copper bar.
Deflector coil options
Driver circuit choice Coil position options 1)7 degrees at bottom of gun 2)nearer build table.
Practical Tasks for builders
Specific's
  • Put this type of bake able knife edge vacuum flange[179] in to freecad[180] for 1 inch 2 inch 6 inch and 14 inch pipe and upload the 3D result to the files and parts section on the site, owned by username ;...........likely finish date :.........emotional status..........
  • What motor power for build platform vertical motion see scale diagram below ? owned by username ;...........likely finish date :.........emotional status..........
  • Which diameter for extension rod inside moterdriven sleeve. I.D. & O.D. sleeve diameters, I.D. & O.D for extention shaft? owned by username ;...........likely finish date :.........emotional status..........
  • What motor size & minimum shaft O.D. for hopper X movement/powder deposition ? owned by username ;...........likely finish date :.........emotional status..........
  • What is the best Main Deflector Coil driver topology options ; a) Raster 30cmx30cm b) point and shoot owned by username ;...........likely finish date :.........emotional status..........
  • What solvent removes conductive coating on outside of salvaged TV tube? Best method to get a clear viewing / illumination window in CRT. Best way to cut hole in screen after pip breakage release of vacuum and capacitive discharge via shorting anode cap to earthing band on four corners of set ( use own cable as anode cable may have diode in[181][182][183]), be safe out there!. owned by username ;...........likely finish date :.........emotional status..........
Broader research (this is the difficult stuff) you need plenty of free time to do these
Your suggested task here (especially pleased if you are going to do it)
  • ....................................................................................................................................................................................owned by username ;...........likely finish date :.........emotional status..........
None of the processes in themselves are new, they have all been done in other contexts. What is new is that it may offer finished parts requiring no further machining, verification of parts tolerance and bring error correction to metal powder 3D printing for the first time, thus enabling full-strength finished dimensional parts production.
(add your username, your likely Task completion date , and emotional status comment ;(possibles include " its fun" " its challenging" "wow" "----" "I feel like Robinson Crusoe" " I am so alve" "I am going to be wealthy" .... )
Research Corner Welcomes Your Contribution
If these knowledge areas are new to you, remember to use your networking skills to talk to others, that friend or uncle may be just that expert!
Design/research questions:
  • A. Possible pit falls of running an SEM at 100W in four-source photometric stereo Ruderford back scatter mode?
  • B. Depth of field of measurements layer errors over 200µ height, typical SEM power is 0.1W?
  • C. Target metal surface temperature measurement would be a big advantage, Do you know of a electron bombardment based remote temperature measurement approach?.
  • D. Quantify relationship between cathode surface tolerances and electron gun performance, (spot size variation , 2nd order effects etc ) Quantify range of gun performance at cathode tolerances of IT 7.
  • E. Which pattern of beam movement a "fixed raster pattern (like a TV scan )" or "point and fire where needed" in a) preheat stage? ( taking temp up to 20 C below melting pointas (commercial printers preheat and infill print method)) b)melting/sintering by following part shape? (scanning coil eddy currents overcome with delays?,scanning blanked out areas leads to time wasting?, variable shaped beam more efficient?, Interference from other signals- X ray , secondary electrons , luminescence , beam induced currents?, Clear path for beam? (commercial printers do edges of parts in this method)
Design question feed back / discussion. Add your ideas here!
MetalicaRap Construction; Physics Principles/Disscussion
