MetalicaRap
Revision as of 15:45, 20 November 2010 by Rapatan (talk | contribs) (Related Projects)
MetalicaRap
Release status: Experimental
Electron beam sintering tool head (EBS) and high vacuum chamber.(early development phase).
MetalicaRap Working Notes
Criteria ; Design a Metal 3D Printer , that produces dimensionally finished parts +- 1µ m over 20mm, largly self reproducing, electrical supply limited to single phase ( ie not 3 Phase,), minimum consumables beyond metal powder ( avoiding need for e.g.argon gas ... etc,),cost for parts less than a small car, buildrate can be slow i.e. .2KG per hour, no bigger than a wardrobe.
Due to lack of control in metal powder deposition in conventional ebeam 3D printing (e.g arcam 3d) a tolerance of 300µ in the Z axis is a typical with 10µ powder,( Lowder power sizes are prone to magnetic forces and typically unwieldy, though powder demagnetization and non ferrous construction is a possibility ), using multi pickup Scanning Electron Microscope (SEM) combined with image processing, the suedo stereo SEM picture data can be converted to true3D dimensional data, Enabling sub µ metal height measurement. Z axis dimensional mistakes in any particular layer can be found and corrected by removal of high points through Electron beam machining / ebeam vaporization of the metal. This brings the XYZ axis to 20µ error over 20mm (IT7). Future stage in development might include Ion beam etching gun to take dimensions to sub µ level(1µ over 20mmIT0).
This has 5 elements; electron gun, High Vacuum chamber, roughing pump, oil diffusion pump and metal powder dispenser.
Design Discussion
Electron gun
3KW 100 KV hot cathode gun
High vacuum chamber
Stainless steel High vacuum 10-5 Tor / (mm mercury) NiCr Alloy (10-16) Hexagonalx40 halfhexagonalx16 endpiecesx16 384 bolts copper wire, future ; airlock so print while repump, main door Viton O ring (Euro ).
Roughing pump
Vane pump ( initially purchased)
Oil diffusion pump
using existing EBS build design
options include ; screw/ trough design; feed chamber build chamber; others
A rough sketch made in Blender of a vacuum chamber made from hexagonal parts printed in a MetalicaRap. Anders
Forum thread
http://dev.forums.reprap.org/
Current status
Based in Copenhagen Denmark Labitat.dk Electron gun test repstrap vacuum chamber including pumps and gauges under electrical maintenance. Current tech team; 5 software developers, 1 Ultra high vacuum metal deposition specialist, 1 High voltage system designer, a theoretical physisist. We are particularly looking out for experienced electron gun designers (Electron beam welding/accelerator).
It would be great for another team to be set up in another part of the world to inspire each other!
Criteria ; Design a Metal 3D Printer , that produces dimensionally finished parts +- 1µ m , largly self reproducing, electrical supply limited to single phase ( ie not 3 Phase,), minimum consumables beyond metal powder ( avoiding need for e.g.argon gas ... etc,),cost for parts less than a small car, buildrate can be slow i.e. .2KG per hour, no bigger than a wardrobe.
Do get in touch if you want to build a team in your area.
Related Projects
Specialist Parts Chamber CF flange Electrical connectors, 1x 140KV 2KW , 2x140kV low current, 8x 30A 200V? coils , 8x SEM pickups low current low voltage, 3x 12mm Motor shaft vacuum seals. 10-4 Tor
Files and Parts
Sub Assemblies and Related
EBS=Electron beam sinterer/melting.
sequence - electron gun parts repstrapped EBS. Assembled tested in repstrap vacuum chamber. Metal powder deposition mechanism parts repstraped EBS . Gun depoosition assembled tested. MetalicarapVacuumChamber parts Electron beam sintered by our system. MetalicarapVacuumchamber assembled tested. 5 Elements assembled and tested.
Downloads
Photos and Drawings
More Examples
Practical manufacturing walk through Electricity is 2kwh per hour .5Euro/hr
Part A Stainless size 300x300x200mm 15Kg 10µ Stainless powder (40Euro/kg) melt print 100µ Z layer thickness
1 minute per Z 100µ each layer heated melting-point – 20 0C then printed by beam
3.4 minute per Every 10th layer Z axis correction ; SEM ( part assumed to occupy 1/9 of whole print area; 1/9* 300*300=10 000mm2 measurement at every 10µ, SEM picture 500x500 pixel so 5mmx5mm, So for 10,000mm2 need 400 SEM pictures 10,000/25= 400 4x pictures from 4 picups gives effect of different angles? for 3D picture reconstruction so real distances, 400 5mmx5mm pictures, 250ms a picture ( Risk of underestimate factor x100 ) 1.4min
Remove metal by Vaporization 1ms per 70µ diameter spot area 4000x10-6 mm2 ( 850µs duration & 150µs beam movement) 1/10 of part high(Risk of underestimate factor x2) ( 1/10*10 000mm2/ 4000x10-6 mm2= 1x105 spots 1x105 spots*1ms= 100Sec 2min Time so far 200* Z correction layers 3.4 Min each + 1800 printed layer 1min each = 2480 min ( 1.7 days)
To add a 40mmx4mm = 160mm2 bearing surface by removing up to 40µ to achieve 0.1µ specification Ion beam abrasion 20min per 1mm2 160*20min =3200min
Time total so far 200* Z correction layers 3.4 Min each 1800Min + 1800 printed layer 1min each 1800 = 2480 Min + ion beam bearing surface 3200= 5680( 4 days)
Cost 665 Euro materials 600Euro Electricity 65 Part B Aluminium size 300x300x20mm 1.5Kg Aluminium 15Euro 10µ powder
Time 20* Z correction layers 3.4 Min each + 180 printed layer 1min each = 248 Min 4 hours No ion beam surfacing Cost 25 Euro materials 22 Euro Electricity 3 Euro
Powder Stainless steal powder powder injection moulding
Aluminum powder 15 Euro/Kg 10µ metal injection moulding stainless steel powder, carbon chromium 40Euro a kg. 74µ 200mesh Aluminum powder 15 Euro/Kg 10µ
