MetalicaRap
Revision as of 16:50, 31 August 2010 by Rapatan (talk | contribs)
MetalicaRap
Release status: Experimental
documenting an electron beam sintering tool head and high vacuum chamber.(early development phase).
MetalicaRap Working Notes
This has 5 elemets; electron gun, High Vacuum chamber, roughing pump, oil diffusion pump and metal powder dispenser.
Design Discussion Electron gun 3KW hot cathode gun
High vacuum chamber Stainless steel High vacuum ten to the minus 5 Tor / (mm mercury) NiCr Alloy (10-16) Hexagonalx40 halfhexagonalx16 endpiecesx16 384 bolts copper wire, future ; airlock so print while repump, main door Viton O ring (Euro ).
Roughing pump Vane pump ( initially purchased)
Oil diffusion pump using existing EBS build design
metal powder dispenser options include ; screw/ trough design; feed chamber build chamber; others
A rough sketch made in Blender of a vacuum chamber made from hexagonal parts printed in a MetalicaRap. Anders Vacuumchamber.jpg
Forum thread?
http://dev.forums.reprap.org/
Current status
Electron gun test repstrap vacuum chamber including pumps and gauges maintenance. Current tech team; 3 software developers, Ultra high vacuum metal deposition specialist, High voltage system designer. We are particularly looking out for experienced accelerator/electronmicroscope designers for electron gun development.
Related Projects
Files and Parts
Sub Assemblies and Related
EBS=Elcectron beam sinterer.
sequence - electron gun parts repstrapped EBS. Assembled tested in repstrap vacuum chamber. Metal powder deposition mechanism parts repstraped EBS . Gun depoosition assembled tested. MetalicarapVacuumChamber parts Electron beam sintered by our system. MetalicarapVacuumchamber assembled tested. 5 Elements assembled and tested.
Downloads
Photos and Drawings
More Examples
May contain scaffolding.
This page may contain "scaffolding" - mediawiki text from the Example page that may not need to be there. It may help to delete the parts that you don't need. (more details)
