Metal Gear System Extruder
Revision as of 16:00, 23 April 2012 by Jglauche (talk | contribs) (Created page with '{{Development |image = IMG 1072.JPG |status = Working |description = Nema 17 Extruder Drive with metal gears |license = GPLv3 |author = Joachim Glauche |reprap = Prusa |categorie…')
Release status: Working
GPLv3
This is an extruder drive that gears a Nema 17 stepper down using machined gears. Accepts many hotends that are mounted by groovemount.
Quantity Description Type Comments
1 Module 0.5 gear with 80 teeth Gears Maedler Item no. 21108000 ; needs set screw added
1 Module 0.5 gear with 14 teeth Gears Conrad item 213918
1 Module 0.5 gear with 20 teeth Gears Conrad item 213977 ; drives the filament
1 608 bearing Bearings
2 625 bearings Bearings
1 M8x20 grub screw Hardware For idler, alternatively use a piece of 20mm M8 threaded rod
1 M4x60 Hex head Hardware
1 M5x40 Hardware Gear shaft, use a grindstone to make a flat side
1 M4 wing nut Hardware
2 Washer A5,3 Hardware
3 M3x10 Hardware Motor mount
2 M3x20 Hardware X carriage mount
1 M3x25 Hardware Hinge mount
3 M3 nut Hardware
3 Spring Spring You will need a fairly strong spring (about 40-50N) that fits on a M4 bolt and is about 12-15mm long.
