Mendel parts more info
Revision as of 05:23, 13 November 2009 by Batist (talk | contribs)
The text has 10433 lines and a size of 342.0 KB.
The total build time is 585 s.
The total distance extruded is 8721.9 mm.
The total distance traveled is 9356.3 mm.
The version is 2009-10-14
The volume extruded is 1.71 cc.
The text has 17300 lines and a size of 569.0 KB.
The total build time is 668 s.
The total distance extruded is 6211.4 mm.
The total distance traveled is 10658.3 mm.
The volume extruded is 1.22 cc.
The text has 22620 lines and a size of 698.0 KB.
The total build time is 2976 s.
The total distance extruded is 37781.3 mm.
The total distance traveled is 47601.7 mm.
The volume extruded is 7.42 cc.
The text has 3538 lines and a size of 103.0 KB.
The total build time is 299 s.
The total distance extruded is 4082.3 mm.
The total distance traveled is 4781.7 mm.
The volume extruded is 0.802 cc.
The text has 12258 lines and a size of 378.0 KB.
The total build time is 646 s.
The total distance extruded is 7789.6 mm.
The total distance traveled is 10337.0 mm.
The volume extruded is 1.53 cc.
The text has 15921 lines and a size of 476.0 KB.
The total build time is 881 s.
The total distance extruded is 11099.7 mm.
The total distance traveled is 14093.0 mm.
The volume extruded is 2.18 cc.
The text has 21041 lines and a size of 671.0 KB.
The total build time is 614 s.
The total distance extruded is 7926.6 mm.
The total distance traveled is 9659.4 mm.
The volume extruded is 1.56 cc.
The text has 62975 lines and a size of 1932.0 KB.
The total build time is 7203 s.
The total distance extruded is 84878.7 mm.
The total distance traveled is 115149.4 mm.
The volume extruded is 16.7 cc.
The text has 44410 lines and a size of 1414.0 KB.
The total build time is 3233 s.
The total distance extruded is 37793.4 mm.
The total distance traveled is 51695.4 mm.
The text has 11871 lines and a size of 345.0 KB.
The total build time is 860 s.
The total distance extruded is 9918.2 mm.
The total distance traveled is 13720.7 mm.
The volume extruded is 1.95 cc.
The text has 11622 lines and a size of 339.0 KB.
The total build time is 823 s.
The total distance extruded is 9875.7 mm.
The total distance traveled is 13117.2 mm.
The volume extruded is 1.94 cc.
The text has 12015 lines and a size of 337.0 KB.
The total build time is 1130 s.
The total distance extruded is 13242.0 mm.
The total distance traveled is 18085.3 mm.
The volume extruded is 2.6 cc.
The text has 10400 lines and a size of 313.0 KB.
The total build time is 837 s.
The total distance extruded is 10722.6 mm.
The total distance traveled is 13377.8 mm.
The volume extruded is 2.11 cc.
The text has 4080 lines and a size of 124.0 KB.
The total build time is 158 s.
The total distance extruded is 1739.5 mm.
The total distance traveled is 2514.5 mm.
The volume extruded is 0.342 cc.
The text has 9448 lines and a size of 279.0 KB.
The total build time is 594 s.
The total distance extruded is 7148.1 mm.
The total distance traveled is 9502.4 mm.
The volume extruded is 1.4 cc.
The text has 85189 lines and a size of 2681.0 KB.
The total build time is 7445 s.
The total distance extruded is 88393.9 mm.
The total distance traveled is 119035.3 mm.
The volume extruded is 17.4 cc.
The text has 50136 lines and a size of 1621.0 KB.
The total build time is 4578 s.
The total distance extruded is 61267.1 mm.
The total distance traveled is 73217.3 mm.
The volume extruded is 12.0 cc.
The text has 28534 lines and a size of 871.0 KB.
The total build time is 2482 s.
The total distance extruded is 30420.2 mm.
The total distance traveled is 39669.8 mm.
The volume extruded is 5.97 cc.
The text has 13941 lines and a size of 452.0 KB.
The total build time is 454 s.
The total distance extruded is 6462.0 mm.
The total distance traveled is 7245.7 mm.
The volume extruded is 1.27 cc.
The text has 13478 lines and a size of 412.0 KB.
The total build time is 878 s.
The total distance extruded is 10189.6 mm.
The total distance traveled is 14035.9 mm.
The volume extruded is 2.0 cc.
The text has 40815 lines and a size of 1283.0 KB.
The total build time is 2911 s.
The total distance extruded is 37384.8 mm.
The total distance traveled is 46543.8 mm.
The volume extruded is 7.34 cc.
The text has 27306 lines and a size of 835.0 KB.
The total build time is 1855 s.
The total distance extruded is 23531.0 mm.
The total distance traveled is 29664.2 mm.
The volume extruded is 4.62 cc.
The text has 23864 lines and a size of 723.0 KB.
The total build time is 1321 s.
The total distance extruded is 15708.3 mm.
The total distance traveled is 21128.8 mm.
The volume extruded is 3.08 cc.
The text has 17425 lines and a size of 522.0 KB.
The total build time is 1770 s.
The total distance extruded is 22096.1 mm.
The total distance traveled is 28277.1 mm.
The volume extruded is 4.34 cc.
The text has 20333 lines and a size of 604.0 KB.
The total build time is 2240 s.
The total distance extruded is 27347.9 mm.
The total distance traveled is 35782.8 mm.
The volume extruded is 5.37 cc.
The text has 20452 lines and a size of 605.0 KB.
The total build time is 2170 s.
The total distance extruded is 27761.5 mm.
The total distance traveled is 34677.6 mm.
The volume extruded is 5.45 cc.
The text has 34932 lines and a size of 1076.0 KB.
The total build time is 3513 s.
The total distance extruded is 42829.7 mm.
The total distance traveled is 56159.9 mm.
The volume extruded is 8.41 cc.
The text has 38830 lines and a size of 1188.0 KB.
The total build time is 3954 s.
The total distance extruded is 48122.1 mm.
The total distance traveled is 63204.2 mm.
The volume extruded is 9.45 cc.
The text has 39149 lines and a size of 1200.0 KB.
The total build time is 3917 s.
The total distance extruded is 48122.9 mm.
The total distance traveled is 62637.3 mm.
The text has 7158 lines and a size of 212.0 KB.
The total build time is 480 s.
The total distance extruded is 6338.6 mm.
The total distance traveled is 7675.0 mm.
The volume extruded is 1.24 cc.
The text has 39228 lines and a size of 1221.0 KB.
The total build time is 4139 s.
The total distance extruded is 52310.9 mm.
The total distance traveled is 66224.6 mm.
The volume extruded is 10.3 cc.
The text has 76041 lines and a size of 2341.0 KB.
The total build time is 8929 s.
The total distance extruded is 114359.9 mm.
The total distance traveled is 142741.3 mm.
The volume extruded is 22.5 cc.
The text has 22671 lines and a size of 687.0 KB.
The total build time is 1938 s.
The total distance extruded is 24932.5 mm.
The total distance traveled is 30990.1 mm.
The volume extruded is 4.9 cc.
The text has 10497 lines and a size of 344.0 KB.
The total distance extruded is 9695.6 mm.
The total distance traveled is 10669.6 mm.
The volume extruded is 1.9 cc.
The text has 1159 lines and a size of 36.0 KB.
The total build time is 187 s.
The total distance extruded is 2779.3 mm.
The total distance traveled is 2993.8 mm.
The volume extruded is 0.546 cc.
The text has 86163 lines and a size of 2679.0 KB.
The total build time is 12144 s.
The total distance extruded is 154045.5 mm.
The total distance traveled is 194191.2 mm.
The volume extruded is 30.2 cc.
The text has 19900 lines and a size of 597.0 KB.
The total build time is 1532 s.
The total distance extruded is 19653.5 mm.
The total distance traveled is 24470.4 mm.
The volume extruded is 3.86 cc.
The text has 59060 lines and a size of 1817.0 KB.
The total build time is 8873 s.
The total distance extruded is 111791.3 mm.
The total distance traveled is 141882.2 mm.
The volume extruded is 22.0 cc.
The text has 9249 lines and a size of 285.0 KB.
The total build time is 567 s.
The total distance extruded is 7259.3 mm.
The total distance traveled is 9059.4 mm.
The volume extruded is 1.43 cc.
The text has 43638 lines and a size of 1311.0 KB.
The total build time is 7378 s.
The total distance extruded is 95416.5 mm.
The total distance traveled is 117950.4 mm.
The volume extruded is 18.7 cc.
