Mendel X-axis
Revision as of 18:08, 11 October 2009 by Skinnyed (talk | contribs)
Carriage
BOM
Total # of assemblies: 1
Name Qty/assembly Total Qty Type
x-carriage-belt-clamp_2off 2 2 RP
x-carriage-lower_1off 1 1 RP
x-carriage-upper_1off 1 1 RP
m4-nut 12 12 Fastener
m4-nylock 10 10 Fastener
m4-washer 58 58 Fastener
m4x16-cap 6 6 Fastener
m4x40-cap 14 14 Fastener
x-flag 1 1 Thin sheet
RP parts
Assembly
Assemble the lower carriage first (1). Note trapped nuts.
Then assemble the upper carriage (2).
Assemble the two halves together (3) using 6 M4x40 caps (don't forget the optoflag!). Tighten the middle two caps, keep the outer two pairs loose. When fully assembled use a piece of ø8 mm bar to set the distances between the bearings. Slide the bar between the bearings and tighten/slacken the outer two pairs of M4x40 caps to achieve a smooth, low resistance, running fit.
Finally assemble the extruder (4).
Idler bracket
BOM
Total # of assemblies 1 ' '
x-180-z-bearing-plate_2off.par 2 2 RP
x-bar-clamp-m3_6off.par 2 2 RP
x-end-bracket_2off.par 1 1 RP
m3-capx20.par 4 4 Fastener
m3-nylock.par 4 4 Fastener
m3-washer.par 8 8 Fastener
m4-nylock.par 11 11 Fastener
m4-washer.par 36 36 Fastener
m4x16-cap.par 2 2 Fastener
m4x40-cap.par 9 9 Fastener
m5-mudguard-washer.par 2 2 Fastener
624-bearing.par 6 6 Bearing
RP parts
Assembly
Do not tighten the two adjuster bolts marked with a * in this diagram. These will be used to set the contact between the bearings and the Z shaft. If you attempt to tighten them now you may damage the bracket.
