Mendel90 Build Manual
Revision as of 07:56, 18 March 2012 by Nophead (talk | contribs) (Printed parts)
Sheets
Printed parts
So far the parts have only been tested in ABS.
The latest STL files are on GitHub at github.com/nophead/Mendel90/tree/master/mendel/stls/printed. These are for the default "mendel" configuration. The STLs for the "sturdy" version are also there: github.com/nophead/Mendel90/tree/master/sturdy/stls/printed. For other configurations build the STL files from source using the scripts provided.
NopHead prints the gears, pulleys and cable clips with a 0.35mm nozzle using 0.3mm layers. The pulleys don't fit the belt well when printed with a bigger nozzle, even at the same layer height, because the teeth become too rounded. The gears can be printed with a 0.4mm nozzle but the M8 nut will be tight to press in because the corners of the hexagon get too rounded.
All the other parts are printed with a 0.4mm nozzle and 0.4mm layers. The W/T ratio is 1.5 in both cases. These parameters are defined in the config.scad file and affect the minimum horizontal and vertical feature sizes. Changing them will affect all the printed parts and sheet drawings slightly.
The relationship between nozzle size and maximum layer height depends on die swell, which in turn depends on the plastic and the length of the nozzle hole, so your mileage may vary.
The recommended infill density settings are as follows: -
Fixing blocks, Wades block, Wades idler block, Wades small gear 95%
Y bearing mounts, Z couplings 75%
Z motor brackets 75% hex
Bar clamps, Y belt anchors, Y idler bracket 50%
X carriage, Y motor bracket 50% hex
X idler bracket, X motor bracket 25% hex
Everything else 25%
Printed with these setting the parts weigh about 400g, a little less than a Prusa. There are a lot more parts, but most are a lot smaller.
Most of the holes are Polyholes, so they should come out the right size on a well calibrated printer. The pulley and small gear holes are deliberately undersized to allow them to be reamed to exactly 5mm. cal.stl is a calibration object for testing hole sizes.
Parts which have holes in surfaces where there is nothing underneath have a support membrane that needs removing. The 8mm holes in the X ends and Wades block plus the rectangular hole in the top of the X motor bracket are best removed with a small knife. The smaller holes in the Y belt anchors, Z couplers and the X carriage are best cleared with a 3mm drill.
General tips
File the ends of the rods to remove any burr, otherwise they can knock the balls out of the linear bearings.
Frame assembly
